10.13 High Sierra probleme MAJ High Sierra MBP 2011
tibotibo9
18 Octobre 2017
Bonjour à toutes et tous.
J'ai voulu effectuer la MAJ hier soir de High Sierra sur mon MBP oct 2011. J'ai téléchargé le pack hier soir, et j'ai voulu lancer l'installation ce matin... Impossible de redémarrer mon MBP ce matin. Au démarrage, il me demande mon mot de passe deux fois, et la deuxième fois, MBP bloqué, impossible de faire quoi que ce soit...
Si l'un de vous pouvait m'aider, je suis MAXI preneur :)
Merci d'avance.
Tibô
-bash-3.2# diskutil list
   0:      GUID_partition_scheme                        *500.1 GB   disk0
   2:          Apple_CoreStorage Macintosh SSD           499.1 GB   disk0s2
   3:                 Apple_Boot Recovery HD             784.2 MB   disk0s3
/dev/disk1 (disk image):
/dev/disk2 (disk image):
   0:                            untitled               +5.2 MB     disk2
/dev/disk3 (disk image):
   0:                            untitled               +524.3 KB   disk3
/dev/disk4 (disk image):
/dev/disk5 (disk image):
/dev/disk6 (disk image):
/dev/disk7 (disk image):
/dev/disk8 (disk image):
   0:                            untitled               +6.3 MB     disk8
/dev/disk9 (disk image):
   0:                            untitled               +2.1 MB     disk9
/dev/disk10 (disk image):
   0:                            untitled               +1.0 MB     disk10
/dev/disk11 (disk image):
   0:                            untitled               +2.1 MB     disk11
/dev/disk12 (disk image):
   0:                            untitled               +524.3 KB   disk12
/dev/disk13 (disk image):
   0:                            untitled               +524.3 KB   disk13
/dev/disk14 (disk image):
   0:                            untitled               +1.0 MB     disk14
/dev/disk15 (disk image):
   0:                            untitled               +6.3 MB     disk15
/dev/disk16 (disk image):
   0:                            untitled               +524.3 KB   disk16
Offline
                                 Logical Volume Macintosh SSD on disk0s2
                                 5AACB5A8-4500-4D47-8205-5A6840FBE077
                                 Locked Encrypted
-bash-3.2# diskutil cs list
CoreStorage logical volume groups (1 found)
+-- Logical Volume Group 317D5B78-F878-480B-A5E1-A862195FC993
    Status:       Online
    Size:         499113885696 B (499.1 GB)
    Free Space:   8486912 B (8.5 MB)
    +-< Physical Volume 12516AAC-6E0D-44D6-9C60-19AF3C8E2599
    |   Index:    0
    |   Disk:     disk0s2
    |   Status:   Online
    +-> Logical Volume Family 1160F592-D9DC-412B-A799-02C2D620FE0F
        Encryption Type:         AES-XTS
        Encryption Status:       Locked
        Conversion Status:       Complete
        High Level Queries:      Fully Secure
        |                        Passphrase Required
        |                        Accepts New Users
        |                        Has Visible Users
        |                        Has Volume Key
        +-> Logical Volume 5AACB5A8-4500-4D47-8205-5A6840FBE077
            Disk:                  -none-
            Status:                Locked
            Size (Total):          498753077248 B (498.8 GB)
            Revertible:            Yes (unlock and decryption required)
            LV Name:               Macintosh SSD
            Content Hint:          Apple_HFS
Et voilà d'autres petites informations qui pourraient vous être utiles... J'ai dévérouillé mon SSD dans utilitaires de disques et j'ai ensuite refait quelques commandes dont voici les résultats...
-bash-3.2# ls /Volumes/"Macintosh SSD"
.DS_Store
.DocumentRevisions-V100
.IAProductInfo
.MobileBackups
.PKInstallSandboxManager-SystemSoftware
.Spotlight-V100
.TALRestoreApps
.TemporaryItems
.Trashes
.apdisk
.dbfseventsd
.file
.fseventsd
.vol
Applications
Civ IV Colonization
Guides de l???utilisateur et informations
Library
MAU 1.1.2 Update Log
Network
System
Users
Volumes
bin
cores
default.profraw
dev
etc
home
installer.failurerequests
macOS Install Data
net
private
sbin
tmp
usr
var
-bash-3.2# diskutil info /Volumes/"Macintosh SSD"
   Device Identifier:        disk17
   Device Node:              /dev/disk17
   Whole:                    Yes
   Part of Whole:            disk17
   Device / Media Name:      CT500BX100SSD1
   Volume Name:              Macintosh SSD
   Mounted:                  Yes
   Mount Point:              /Volumes/Macintosh SSD
   Content (IOContent):      Apple_HFS
   File System Personality:  Journaled HFS+
   Type (Bundle):            hfs
   Name (User Visible):      Mac OS Extended (Journaled)
   Journal:                  Journal size 40960 KB at offset 0xe8e000
   OS Can Be Installed:      Yes
   Recovery Disk:            disk0s3
   Protocol:                 SATA
   Volume UUID:              57B3A908-6EA0-3D65-AD49-1C18A6F1DA94
   Disk / Partition UUID:    5AACB5A8-4500-4D47-8205-5A6840FBE077
   Disk Size:                498.8 GB (498761564160 Bytes) (exactly 974143680 512-Byte-Units)
   Device Block Size:        512 Bytes
   Volume Total Space:       498.8 GB (498761564160 Bytes) (exactly 974143680 512-Byte-Units)
   Volume Used Space:        452.5 GB (452525199360 Bytes) (exactly 883838280 512-Byte-Units) (90.7%)
   Volume Available Space:   46.2 GB (46236364800 Bytes) (exactly 90305400 512-Byte-Units) (9.3%)
   Read-Only Media:          No
   Read-Only Volume:         No
   Removable Media:          Fixed
   Solid State:              Yes
   Virtual:                  Yes
   OS 9 Drivers:             No
   Low Level Format:         Not supported
   This disk is a Core Storage Logical Volume (LV).  Core Storage Information:
   LV UUID:                  5AACB5A8-4500-4D47-8205-5A6840FBE077
   LVF UUID:                 1160F592-D9DC-412B-A799-02C2D620FE0F
   LVG UUID:                 317D5B78-F878-480B-A5E1-A862195FC993
   PV UUID (disk):           12516AAC-6E0D-44D6-9C60-19AF3C8E2599 (disk0s2)
   Fusion Drive:             No
   Encrypted:                Yes
Bonjour tibotibo
Bravo pour les tableaux : ce qui s'appelle fournir les informations sur un plateau !
Alors 2 choses sont déjà à noter :
  • il n'y a pas plus de High Sierra que de beurre en broche (comme tu as un SSD > le système de stockage CoreStorage Chiffré aurait dû être converti à l'APFS > ce qui n'est pas le cas. Donc l'OS de ton volume Macintosh SSD doit toujours être l'OS installé auparavant (tu n'as pas dit lequel c'était).
  • le volume n'est pas verrouillé au montage en lecture seule > mais monte en lecture et écriture. Il est donc manipulable et non bloqué.
Ensuite > le dossier d'installation de High Sierra est en place dans le volume sous l'intitulé macOS Install Data. Ce doit être ce dossier qui te bloque, car le programme d'installation que tu as lancé a dû inscrire en NVRAM une adresse de démarrage automatique pour l'EFI sur le démarreur boot.efi de l'OS d'installation recelé dans ce dossier. Et plus au démarreur de l'OS en place dans le volume Macintosh SSD.
Donc par une commande :
rm -rf /Volumes/"Macintosh SDD"/"macOS Install Data"
tu supprimes ce dossier parasite (il n'y a pas d'espace entre SDD" et /"macOS--).
Comme tu as des chances, si ton OS était «El Capitan 10.11» ou «Sierra 10.12», d'avoir le SIP activé (sécurisation de l'OS qui verrouille aussi l'adressage de boot en NVRAM) --> passe la commande (si besoin était) :
csrutil disable
qui désactive le SIP. Il te faut re-démarrer une fois derrière > en rebootant en mode Recovery > pour que la désactivation soit complète.
Dans l'«Utilitaire de Disque» > re-déverrouille et remonte le volume Macintosh SSD.
Passe alors la commande :
bless --folder /Volumes/"Macintosh SDD"/System/Library/CoreServices --file /Volumes/"Macintosh SDD"/System/Library/CoreServices/boot.efi
  • qui remet l'adresse de boot automatique pour l'EFI sur le démarreur de l'OS en place dans le volume Macintosh SSD.
=> re-démarre normalement > et vois si, après déverrouillage de l'écran initial, l'OS se charge et si tu peux ouvrir ta session.
Sinon > mode Recovery encore > déverrouillage et remontage du volume dans l'«Utilitaire de Disque» > puis dans la fenêtre des 4 Utilitaires OS X (ou macOS) --> option : "Ré-installer OS X (ou macOS)" à destination de Macintosh SSD.
