Bonjour, je souhaite créer un script qui me permettrait avec un simple click de changer la langue du systeme de mon mac ainsi que le clavier associer.
Je n'aurait besoins que de 3 langues: francais, allemand et espagnole.
J'ai beaucoup chercher mais la seule chose que j'ai trouvé c'est ce script qui ne donne que la langue actuelle du systeme.
# Example call.
set activeKbdLayout to my getActiveKeyboardLayout() # ->, e.g., "U.S."
on getActiveKeyboardLayout()
# Surprisingly, using POSIX-style paths (even with '~') works with
# the
set plistPath to "~/Library/Preferences/com.apple.HIToolbox.plist"
# !! First, ensure that the plist cache is flushed and that the
# !! *.plist file contains the current value; simply executing
# !! key - does that.
try
do shell script "defaults read " & plistPath & " dummy"
end try
tell application "System Events"
repeat with pli in property list items of ¬
property list item "AppleSelectedInputSources" of ¬
property list file plistPath
# Look for (first) entry with key "KeyboardLayout Name" and return
# its value.
# Note: Not all entries may have a 'KeyboardLayout Name' key,
# so we must ignore errors.
try
return value of property list item "KeyboardLayout Name" of pli
end try
end repeat
end tell
end getActiveKeyboardLayout
# Example call.
# the
property list file type.set plistPath to "~/Library/Preferences/com.apple.HIToolbox.plist"
default read against the file - even with a dummy# !! key - does that.
try
end try
# its value.
try
end try
end repeat
end tell
