10.13 High Sierra SSD ne boot plus - point d'interrogation au démarrage
jelmouss
10 Avril 2016
107
46
Bonjour et par avance merci à tous pour votre aide.
Probléme soudain ce week-end sur mon SSD (roue infinie allant et venant)
Les rares fois ou j'arrive à booter sur le disque après action sur nappe, il se bloque après quelques minutes.
test des partitions
OS semble OK
Data semble KO et impossible à réparer / remonter
ci joint quelques informations
MacBookPro mi 2012
-bash-3.2# diskutil list
   0:      GUID_partition_scheme                        *500.1 GB   disk0
   2:                  Apple_HFS MX500_HD                298.6 GB   disk0s2
   3:          Apple_CoreStorage MX500_OSX               200.4 GB   disk0s3
   4:                 Apple_Boot Recovery HD             650.0 MB   disk0s4
/dev/disk1 (disk image):
/dev/disk2 (internal, virtual):
   0:                  Apple_HFS MX500_OSX              +200.0 GB   disk2
                                 Logical Volume on disk0s3
                                 140D606F-1DCB-4433-83F8-C325EC9E5470
                                 Unencrypted
/dev/disk3 (disk image):
/dev/disk4 (external, physical):
   0:     FDisk_partition_scheme                        *2.0 TB     disk4
   1:                  Apple_HFS MyPassport              2.0 TB     disk4s1
/dev/disk5 (disk image):
/dev/disk6 (disk image):
/dev/disk7 (disk image):
/dev/disk8 (disk image):
   0:                            untitled               +2.1 MB     disk8
/dev/disk9 (disk image):
/dev/disk10 (disk image):
   0:                            untitled               +524.3 KB   disk10
/dev/disk11 (disk image):
   0:                            untitled               +12.6 MB    disk11
/dev/disk12 (disk image):
   0:                            untitled               +4.2 MB     disk12
/dev/disk13 (disk image):
   0:                            untitled               +1.0 MB     disk13
/dev/disk14 (disk image):
   0:                            untitled               +2.1 MB     disk14
/dev/disk15 (disk image):
/dev/disk16 (disk image):
   0:                            untitled               +524.3 KB   disk16
/dev/disk17 (disk image):
   0:                            untitled               +1.0 MB     disk17
/dev/disk18 (disk image):
/dev/disk19 (disk image):
   0:                            untitled               +6.3 MB     disk19
/dev/disk20 (disk image):
   0:                            untitled               +524.3 KB   disk20
/dev/disk21 (disk image):
   0:                            untitled               +2.1 MB     disk21
-bash-3.2# df -H
Filesystem     Size   Used  Avail Capacity iused      ifree %iused  Mounted on
/dev/disk1s1   2.0G   1.3G   719M    64%   45162 4294922117    0%   /
devfs          207k   207k     0B   100%     700          0  100%   /dev
/dev/disk3     5.2M   733k   4.5M    14%      19 4294967260    0%   /private/var/log
/dev/disk5     524k   147k   377k    29%       6 4294967273    0%   /Volumes
/dev/disk6     524k   147k   377k    29%       7 4294967272    0%   /private/var/tmp
/dev/disk7     524k   160k   365k    31%      12 4294967267    0%   /private/var/run
/dev/disk8     2.1M   143k   2.0M     7%       2 4294967277    0%   /private/tmp
/dev/disk9     524k   143k   381k    28%       2 4294967277    0%   /System/Installation
/dev/disk10    524k   299k   225k    58%      20 4294967259    0%   /private/var/db
/dev/disk11     13M   3.2M   9.4M    26%      65 4294967214    0%   /private/var/folders
/dev/disk12    4.2M   209k   4.0M     5%      22 4294967257    0%   /private/var/root/Library
/dev/disk14    2.1M   143k   2.0M     7%       2 4294967277    0%   /private/var/root/Library/Containers
/dev/disk15    524k   180k   344k    35%      11 4294967268    0%   /Library/Preferences
/dev/disk16    524k   164k   360k    32%       6 4294967273    0%   /Library/Preferences/SystemConfiguration
/dev/disk17    1.0M   184k   864k    18%       6 4294967273    0%   /Library/Keychains
/dev/disk18    6.3M   176k   6.1M     3%       2 4294967277    0%   /private/var/tmp/RecoveryTemp
/dev/disk19    6.3M   176k   6.1M     3%       2 4294967277    0%   /private/var/tmp/OSISPredicateUpdateProductTemp
/dev/disk20    524k   143k   381k    28%       2 4294967277    0%   /private/var/tmp/InstallerCookies
/dev/disk21    2.1M   143k   2.0M     7%       2 4294967277    0%   /Library/Logs/DiagnosticReports
/dev/disk2     200G    82G   118G    41%  835527 4294131752    0%   /Volumes/MX500_OSX
/dev/disk4s1   2.0T   1.8T   201G    90%   49623 4294917656    0%   /Volumes/MyPassport
/dev/disk0s1   206M    24M   182M    12%       0          0  100%   /Volumes/EFI
-bash-3.2# diskutil info /dev/disk0s2
   Device Identifier:        disk0s2
   Device Node:              /dev/disk0s2
   Whole:                    No
   Part of Whole:            disk0
   Volume Name:              MX500_HD
   Mounted:                  No
   Partition Type:           Apple_HFS
   File System Personality:  Journaled HFS+
   Type (Bundle):            hfs
   Name (User Visible):      Mac OS Extended (Journaled)
   Journal:                  Unknown (not mounted)
   Owners:                   Disabled
   OS Can Be Installed:      No
   Protocol:                 SATA
   SMART Status:             Verified
   Volume UUID:              0B217A6E-ABEB-3AAF-8F31-B2BC802540E4
   Disk / Partition UUID:    C269D7BF-3B19-4822-913B-FB15CD83BCCD
   Partition Offset:         209735680 Bytes (409640 512-Byte-Device-Blocks)
   Disk Size:                298.6 GB (298593120256 Bytes) (exactly 583189688 512-Byte-Units)
   Device Block Size:        512 Bytes
   Volume Total Space:       0 B (0 Bytes) (exactly 0 512-Byte-Units)
   Volume Free Space:        0 B (0 Bytes) (exactly 0 512-Byte-Units)
   Read-Only Media:          No
   Read-Only Volume:         Not applicable (not mounted)
   Removable Media:          Fixed
   Solid State:              Yes
   Hardware AES Support:     No
Question :
  • Possible de tenter de remonter /dev/disk0s2 (même en lecture seule)
  • Possible de tenter de reparer le disque
  • Disque crucial MX500 encore sous garantie (je pense)
Merci pour votre aide.
Est-ce que le disque ssd boot, une fois placé dans un boitier usb externe (et le firmware du SSD est à jour) ?
Cdlt
MacBookPro mi 2012
Ah le fameux MBP 2012 et son problème récurrent lors d'un changement du disque dur d'origine. La première chose à faire est de démonter le SSD, de l'installer dans un boîtier USB, de le connecter à ton MBP, de démarrer en maintenant la touche alt. Si tu vois l'icône de ton SSD et que tu arrives sans problème dans ta session de travail, il te faudra impérativement changer la nappe SATA.
Pourquoi ? A l'époque Apple ne faisait pas installer de SSD en boîtier 2,5", ce qui est toujours le cas actuellement, la qualité de la nappe SATA répondait aux exigences des taux d'écritures/lectures et tout allait pour le mieux. Avec un SSD, il n'en va pas de même, les taux de lectures/écritures sont à minima cinq fois supérieurs et il y a un moment ou à un autre un blocage. Ce problème peut arriver tout de suite après l'installation, après 1 jour, 1 semaine, 1 mois, 1 année, etc, mais il arrivera.
Il n'y a pas d'autres choix que de changer la nappe SATA. Pour en acheter une de qualité, mieux vaut la commander chez MacWay. Attention, sur Amazon ou boutique en ligne similaire, si le prix est attractif, la qualité n'est pas du tout au rendez-vous et bingo il faut en acheter une de qualité.
Merci pour vos réponses.
Je n'ai pas vérifié pour le firmware du SSD (faut encore que je demande à google)
Par contre le SSD est démonté et relié sur boitier USB et semble plutôt bien réagir. A confirmer après quelques heures, jours d'utilisation.
J'ai même vérifié le volume qui ne renvoie pas d'erreur.
❯  diskutil list
/dev/disk0 (external, physical):
/dev/disk1 (external, virtual):
   0:                  Apple_HFS MX500_OSX              +200.0 GB   disk1
                                 Unencrypted
   0:     FDisk_partition_scheme                        *124.2 GB   disk2
   1:                  Apple_HFS UltraFit_120            124.2 GB   disk2s1
❯  diskutil verifyVolume /dev/disk0s2
Started file system verification on disk0s2 MX500_HD
Verifying file system
Volume was successfully unmounted
Performing fsck_hfs -fn -x /dev/rdisk0s2
Checking Journaled HFS Plus volume
Checking extents overflow file
Checking catalog file
Checking multi-linked files
Checking catalog hierarchy
Checking extended attributes file
Checking volume bitmap
Checking volume information
The volume MX500_HD appears to be OK
File system check exit code is 0
Restoring the original state found as mounted
Finished file system verification on disk0s2 MX500_HD
❯  diskutil verifyVolume /dev/disk0s3
Started file system verification on disk0s3
Verifying storage system
Performing fsck_cs -n -x --lv --uuid 4EA0217C-0360-4018-B554-2452EEFE6241
Checking volume
disk0s3: Scan for Volume Headers
disk0s3: Scan for Disk Labels
Logical Volume Group 4EA0217C-0360-4018-B554-2452EEFE6241 on 1 device
disk0s3: Scan for Metadata Volume
Logical Volume Group has a 24 MB Metadata Volume with double redundancy
Start scanning metadata for a valid checkpoint
Load and verify Segment Headers
Load and verify Checkpoint Payload
Load and verify Transaction Segment
Incorporate 0 newer non-checkpoint transactions
Load and verify Virtual Address Table
Load and verify Segment Usage Table
Load and verify Metadata Superblock
Load and verify Logical Volumes B-Trees
Logical Volume Group contains 1 Logical Volume
Load and verify 84D6ADD5-9D09-4F62-A4E3-41986AB7F2A0
Load and verify 140D606F-1DCB-4433-83F8-C325EC9E5470
Load and verify Freespace Summary
Load and verify Block Accounting
Load and verify Live Virtual Addresses
Newest transaction commit checkpoint is valid
Load and verify Segment Cleaning
The volume 4EA0217C-0360-4018-B554-2452EEFE6241 appears to be OK
Finished file system verification on disk0s3
Je vais effectivement suivre ton avis Locke à savoir encore reprendre une nappe sata chez macway.
Je vous tiens au courant.
et encore merci.
Si après 10 redémarrages successifs tu as accès à ta session de travail depuis le boitier USB, tu peux changer d'office la nappe SATA.
Merci Locke.
Je vais continuer à test, Il semble bien trouver le systéme au redémarrage par contre, il viens encore de passer en mode "roue infinie" plusieurs minutes et le seul moyen de le récupérer à a été de rebooter brutalement.
... Je ne suis pas sur que cela soit ou juste un problème de nappe
Possible de confirer cela / pousser les tests ?
Par défaut, il faut prendre en considération que si lors d'un démarrage tu arrives dans ta session de travail, tu peux changer la nappe SATA. On se fiche de la roue colorée, c'est un autre problème qui généralement est dû à une version de macOS brinquebalante. Donc, si chaque démarrage depuis le boîtier SSD est un succès, change la nappe SATA.
