10.12 Sierra 70 Go de stockage occupé par le système ?
(partie 2)
128K    /Users/carolineyan/Library/Application Support/com.GoPro.goproapp.GoProAnalyticsService
40K    /Users/carolineyan/Library/Application Support/com.GoPro.goproapp.GoProDeviceService
  0B    /Users/carolineyan/Library/Application Support/com.GoPro.goproapp.GoProExporterService
8,0K    /Users/carolineyan/Library/Application Support/com.GoPro.goproapp.GoProIDService
4,0K    /Users/carolineyan/Library/Application Support/com.GoPro.goproapp.GoProMediaFolderService
76K    /Users/carolineyan/Library/Application Support/com.GoPro.goproapp.GoProMediaService
  0B    /Users/carolineyan/Library/Application Support/com.GoPro.goproapp.GoProMsgBus
412M    /Users/carolineyan/Library/Application Support/com.GoPro.goproapp.GoProMusicService
4,0K    /Users/carolineyan/Library/Application Support/com.GoPro.goproapp.GoProPushNotificationService
  0B    /Users/carolineyan/Library/Application Support/com.GoPro.goproapp.GoProShareService
  0B    /Users/carolineyan/Library/Application Support/com.GoPro.goproapp.GoProUpdateService
6,4M    /Users/carolineyan/Library/Application Support/com.apple.ProtectedCloudStorage
68K    /Users/carolineyan/Library/Application Support/com.apple.TCC
8,0K    /Users/carolineyan/Library/Application Support/com.apple.backgroundtaskmanagementagent
1,5M    /Users/carolineyan/Library/Application Support/com.apple.sbd
308K    /Users/carolineyan/Library/Application Support/com.apple.sharedfilelist
336K    /Users/carolineyan/Library/Application Support/com.apple.spotlight
8,0K    /Users/carolineyan/Library/Application Support/com.apple.spotlight.Shortcuts
1,1M    /Users/carolineyan/Library/Application Support/com.apple.touristd
4,0K    /Users/carolineyan/Library/Application Support/com.baidu.BaiduNetdisk-mac
  0B    /Users/carolineyan/Library/Application Support/com.cube.cube
4,0K    /Users/carolineyan/Library/Application Support/com.malwarebytes.mbam.frontend.agent
4,0K    /Users/carolineyan/Library/Application Support/com.malwarebytes.mbam.frontend.application
20M    /Users/carolineyan/Library/Application Support/com.nordvpn.osx
4,0K    /Users/carolineyan/Library/Application Support/com.paragon-software.ntfs.fsapp
4,0K    /Users/carolineyan/Library/Application Support/com.paragon-software.ntfs.notification-agent
16K    /Users/carolineyan/Library/Application Support/com.tobyfox.undertale
2,5M    /Users/carolineyan/Library/Application Support/com.youdagames.gop3multiplayer
124M    /Users/carolineyan/Library/Application Support/discord
  0B    /Users/carolineyan/Library/Application Support/dmd
24K    /Users/carolineyan/Library/Application Support/dr.fone
620K    /Users/carolineyan/Library/Application Support/dr.fone-Transfer
228M    /Users/carolineyan/Library/Application Support/dr.fone-Transférer
8,0K    /Users/carolineyan/Library/Application Support/iCloud
  0B    /Users/carolineyan/Library/Application Support/iLifeMediaBrowser
4,0K    /Users/carolineyan/Library/Application Support/icdd
4,0K    /Users/carolineyan/Library/Application Support/org.videolan.vlc
8,0K    /Users/carolineyan/Library/Application Support/unity.8floor.Business Tour
20K    /Users/carolineyan/Library/Application Support/unity.Blacklight Interactive.Golf With Your Friends
24K    /Users/carolineyan/Library/Application Support/unity.Blizzard Entertainment.Hearthstone
8,0K    /Users/carolineyan/Library/Application Support/unity.DefaultCompany.PhysicsAnimationSystem 3.0
104K    /Users/carolineyan/Library/Application Support/videosubscriptionsd
  0B    /Users/carolineyan/Library/Application Support/wondershare
Il doit y avoir dans un des libellés de sous-dossiers --> un intitulé qui a activé un filtre des forums (qui sait pourquoi) ?
- il faudra donc patienter...
Note du modérateur de service (ici Aliboron) :
Voilà, voilà, j'arrive ! :coucou:
Voici les localisations principalement occupées dans Application Support -->
Intego Backup Assistant : 4,5 Gi = 5 Go
Steam : 14 Gi = 15 Go
  • Intego Backup Assistant me fait penser à un antivirus ; Steam à des jeux ?
Le mieux serait que tu ailles voir en quoi consistent ces fichiers avec le Finder > et pour cela il faut démasquer ta Bibliothèque actuellement invisible -->
- ouvre une fenêtre du Finder affichant l'espace global de ton dossier de compte carolineyan. Cela fait > va à la barre de menus du Finder : Présentation > Afficher les options de présentation (en bas) --> dans la palette qui s'affiche > coche la case : "Afficher le dossier Bibliothèque" (en bas encore). En résultat : un nouveau dossier intitulé Bibliothèque est visible dans l'espace global de ton dossier de compte carolineyan.​
=> entres-y > va au sous-dossier : Application Support --> et de là aux 2 dossiers subalternes : Intego Backup Assistant & Steam.
Intego Backup Assistant est un logiciel qui me permet de faire des sauvegardes sur mon DDE et Steam ce sont bien des jeux
À toi de voir s'il y a des fichiers supprimables dans les 2 localisations que je t'ai indiquées.
- sinon > si tu veux alléger l'occupation de ton volume --> je ne vois qu'une copie de fichiers volumineux (comme ceux de ton sous-dossier Vidéos) => dans le volume d'un DDE USB > suivie de la suppression des originaux.​
Bonjour à tous, j'ai moi aussi un système à 109 Go ... embêtant !
Voici donc le retour de la commande "diskutil list" :
   2:                 Apple_APFS Container disk1         121.1 GB   disk0s2
/dev/disk1 (synthesized):
   0:      APFS Container Scheme -                      +121.1 GB   disk1
                                 Physical Store disk0s2
   1:                APFS Volume Macintosh HD            112.3 GB   disk1s1
   2:                APFS Volume Preboot                 20.5 MB    disk1s2
   3:                APFS Volume Recovery                520.9 MB   disk1s3
La commande concernant les snapshots de renvoie rien, et mon SIP est par ailleurs activé.
Je n'ai pas osé aller plus loin dans les manips, merci pour votre attention !
PS: Je suis sous High Sierra 10.13, faudrait-il que je passe sous Mojave avant ?
Bonjour Oskarpolo
Il y a effectivement 112,3 Go de blocs occupés par le volume Macintosh HD + 2,6 Go par les volumes auxiliaires => presque 115 Go en tout. Ce qui ne laisse plus beaucoup d'espace disponible.
Pour désactiver le SIP > redémarre > les 2 touches ⌘R (cmd R) tenues pressées de l'écran noir => à la  = démarrage sur l'OS de secours. Tu obtiens un écran affichant une fenêtre de 4 Utilitaires macOS. Va à la barre de menus supérieure de l'écran > Menu Utilitaires > sous-menu : Terminal.
Lance-le et passe la commande :
csrutil disable
  • qui désactive le SIP
Cela fait > quitte le Terminal > va à : Menu  > Disque de démarrage > sélectionne Macintosh HD > redémarre dessus.
De retour dans ta session > passe la commande (copier-coller) :
  • à validation > une demande de password s'affiche (commande sudo) --> tape ton mot-de-passe de session admin en aveugle - aucun caractère ne se montrant à la frappe - et revalide
  • la commande mesure (en Gi = gibibytes : base 2) les objets de 1er rang du volume de démarrage (fichiers ou dossiers / visibles ou cachés). Elle est très lente d'exécution : attends le retour de l'invite de commande terminée par ton nomcourt$ en signal de fin.
Poste le tableau dans une fenêtre de code.
Merci pour ta rapidité !
Voici le résultat de la "sudo find -x / -d 1 -regex '.*[^\.\].*' -exec sudo du -shx {} +" :
1,0K    /home
459M    /usr
130M    /.Spotlight-V100
1,0K    /net
12K    /.DS_Store
  0B    /.PKInstallSandboxManager
2,6M    /bin
4,0K    /installer.failurerequests
  0B    /Network
1,1M    /sbin
  0B    /.file
  0B    /etc
  0B    /var
7,6G    /Library
  0B    /.Trashes
9,1G    /System
128K    /.fseventsd
43G    /private
7,5M    /.DocumentRevisions-V100
  0B    /.vol
41G    /Users
2,1G    /Applications
4,5K    /dev
8,0M    /Volumes
  0B    /tmp
  0B    /cores
Je comptabilise 103,4 Gi = 111 Go de fichiers catalogués. Presque la même valeur que les blocs occupés (112,3 Go) --> on va dire qu'il n'y a pas d'espace occupé fantôme.
Ces 111 Go de fichiers peuvent se répartir en mode binaire ainsi -->
- fichiers dédiés à l'utilisateur : 41 Gi Users + 2,1 Gi Application => 43,1 Gi = 46 Go
- fichiers-Système (au sens strict) : le reste soit 111 Go - 46 Go = 65 Go
Bilan : le Système (au sens strict) fait normalement dans les 25 Go (plus ou moins). Ici il fait 65 Go > soit un excédent d'environ 40 Go -->
- la raison de cette hypertrophie est aisée à repérer : le répertoire-Système invisible : private --> fait 43 Gi = 46 Go. Alors qu'on l'attendrait à 4 Go maximum. Il y a donc ici un excédent de 42 Go environ.
Par ailleurs > le panneau Stockage comptabilise en fichiers-Système (dans un sens étendu) --> les fichiers de la Bibliothèque (graphiquement invisible) du compte de l'utilisateur -->
- cette mesure doit également participer clandestinement à une évaluation du "Système" (étendu) à 109 Go > pour peu qu'il y ait également une hypertrophie dans ta Bibliothèque.​
On va donc mener une enquête bicéphale : dans private et dans les comptes d'utilisateurs.
Passe les 3 commandes (séparément) :
sudo du -sh /private/*
sudo du -sh /Users/*
sudo du -sh ~/*
  • la 1ère mesure (en Gi) les sous-dossiers de private
  • la 2è fait de même pour Users (= Utilisateurs : on a parfois des surprises avec le dossier Partagé)
  • la 3è de même pour les sous-dossiers de ton dossier de compte (dont la Bibliothèque)
Poste les retours.
Voici pour la première :
2,6M    /private/etc
  0B    /private/tftpboot
  0B    /private/tmp
44G    /private/var
Et la troisième :
 20K    /Users/Sim/Applications
8,0K    /Users/Sim/Desktop
15M    /Users/Sim/Documents
114M    /Users/Sim/Downloads
9,3G    /Users/Sim/Library
  0B    /Users/Sim/MacKeeper Backups
16K    /Users/Sim/Movies
526M    /Users/Sim/Music
11M    /Users/Sim/Pictures
  0B    /Users/Sim/Public
672K    /Users/Sim/iCloud Drive (archive)
Je vois qu'il y a 30 Go chez l'utilisateur Flavie, auquel j'ai accès. Le calcul du stockage indiquait pourtant 4 Go et quelques chez cet utilisateur ...
Les 44 Gi = 47 Go de private sont monopolisés par le sous-dossier var.
Dans les Utilisateurs > il y a 1,1 Gi = 1,2 Go dans Partagé > 9,9 Gi = 10,7 Go dans Sim > 30 Gi = 32 Go dans flavie.
Ta session ouverte est celle de l'utilisateur Sim : les sous-dossiers sont vides de données personnelles > c'est la Bibliothèque cachée qui fait 9,3 Gi = 10 Go.
L'enquête se ramifie donc. Passe les commandes :
sudo du -sh /private/var/*
sudo du -sh /Users/flavie/*
sudo du -sh ~/Library/*
  • la 1ère mesure (en Gi = gibibytes : base 2 - la seule mesure connue de la commande du) les sous-contenus de var
  • la 2è --> les sous-dossiers du compte flavie
  • la 3è --> les contenus de ta Bibliothèque (compte Sim)
Poste les retours.
Note : regarde avec le Finder dans Utilisateurs > Partagé --> de quoi se coposent les 1,2 Go de données.
La première :
  0B    /private/var/agentx
4,0K    /private/var/at
15M    /private/var/audit
  0B    /private/var/backups
3,1G    /private/var/db
  0B    /private/var/empty
39G    /private/var/folders
  0B    /private/var/install
  0B    /private/var/jabberd
  0B    /private/var/lib
161M    /private/var/log
  0B    /private/var/ma
  0B    /private/var/mail
4,0K    /private/var/msgs
  0B    /private/var/netboot
1,5M    /private/var/networkd
858M    /private/var/root
  0B    /private/var/rpc
36K    /private/var/run
  0B    /private/var/rwho
2,8M    /private/var/spool
180K    /private/var/tmp
1,0G    /private/var/vm
  0B    /private/var/yp
La deuxième :
395M    /Users/flavie/Desktop
816M    /Users/flavie/Documents
6,8G    /Users/flavie/Downloads
1,9G    /Users/flavie/Library
17G    /Users/flavie/Movies
35M    /Users/flavie/Music
3,4G    /Users/flavie/Pictures
  0B    /Users/flavie/Public
Et la troisième :
2,0M    /Users/Sim/Library/Accounts
  0B    /Users/Sim/Library/Application Scripts
2,3G    /Users/Sim/Library/Application Support
356K    /Users/Sim/Library/Assistant
  0B    /Users/Sim/Library/Assistants
  0B    /Users/Sim/Library/Audio
6,5G    /Users/Sim/Library/Caches
1,6M    /Users/Sim/Library/Calendars
  0B    /Users/Sim/Library/CallServices
  0B    /Users/Sim/Library/ColorPickers
  0B    /Users/Sim/Library/Colors
  0B    /Users/Sim/Library/Compositions
246M    /Users/Sim/Library/Containers
3,9M    /Users/Sim/Library/Cookies
48K    /Users/Sim/Library/CoreFollowUp
148K    /Users/Sim/Library/Dictionaries
  0B    /Users/Sim/Library/Family
  0B    /Users/Sim/Library/Favorites
24K    /Users/Sim/Library/FileProvider
28K    /Users/Sim/Library/FontCollections
236K    /Users/Sim/Library/Fonts
  0B    /Users/Sim/Library/Fonts Disabled
  0B    /Users/Sim/Library/GameKit
8,0K    /Users/Sim/Library/Google
1,8M    /Users/Sim/Library/Group Containers
180K    /Users/Sim/Library/IdentityServices
  0B    /Users/Sim/Library/Input Methods
  0B    /Users/Sim/Library/Internet Plug-Ins
80K    /Users/Sim/Library/Keyboard
  0B    /Users/Sim/Library/Keyboard Layouts
420K    /Users/Sim/Library/KeyboardServices
5,0M    /Users/Sim/Library/Keychains
516K    /Users/Sim/Library/LanguageModeling
12K    /Users/Sim/Library/LaunchAgents
10M    /Users/Sim/Library/Logs
63M    /Users/Sim/Library/Mail
  0B    /Users/Sim/Library/Maps
2,3M    /Users/Sim/Library/Messages
43M    /Users/Sim/Library/Metadata
1,0M    /Users/Sim/Library/Mobile Documents
216K    /Users/Sim/Library/Passes
112K    /Users/Sim/Library/Personas
  0B    /Users/Sim/Library/PreferencePanes
24M    /Users/Sim/Library/Preferences
492K    /Users/Sim/Library/Printers
200K    /Users/Sim/Library/PubSub
60M    /Users/Sim/Library/Safari
  0B    /Users/Sim/Library/SafariSafeBrowsing
716K    /Users/Sim/Library/Saved Application State
  0B    /Users/Sim/Library/Screen Savers
8,5M    /Users/Sim/Library/Services
8,0K    /Users/Sim/Library/Sharing
  0B    /Users/Sim/Library/Sounds
20K    /Users/Sim/Library/Spelling
21M    /Users/Sim/Library/Suggestions
716K    /Users/Sim/Library/SyncedPreferences
  0B    /Users/Sim/Library/Voices
736K    /Users/Sim/Library/WebKit
132K    /Users/Sim/Library/com.apple.internal.ck
  0B    /Users/Sim/Library/iMovie
  0B    /Users/Sim/Library/iTunes
