Comment désinstaller complétement smcFanControl ?
loucy26
28 Juin 2009
9
Bonjours,
J'ai prêter mon iMac 2011 à un ami. Il m'a installer smcFanControl mais je souhaite le désinstaller et revenir au paramètre par défaut de mes ventilateurs. Comment dois-je procéder ?
Cordialement :zen:
RTFM… :mouais:
"How do install and uninstall smcFanControl?
smcFanControl is just an application. So after downloading, and unzipping it, drag it to wherever you want (e.g. the Application Folder). To uninstall it, just drag it into the trash. smcFanControl installs no permanent background processes or daemons.
All changes smcFanControl does to the fan controlling get lost after you shutdown your computer (power off, not restart) or enter standby mode (as far as you don't have smcFanControl running) . Minimum fan speed then falls back to the system defaults values."
