Gros problème Boot camp
memel6969
23 Juin 2015
5
Bonjour à tous
depuis une manipulation, je n'arrive plus à ouvrir l'application boot camp ( elle ne demarre même pas, directement un message d'erreur)
voici ce qui est indiqué en dessous..
je suis novice !
merci à vous
Process: Boot Camp Assistant [445]
Path: /Applications/Utilities/Boot Camp Assistant.app/Contents/MacOS/Boot Camp Assistant
Identifier: com.apple.bootcampassistant
Version: ???
Build Info: BootCampAssistant-5868000000000000~2
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Boot Camp Assistant [445]
User ID: 501
Date/Time: 2015-06-23 00:44:16.733 +0200
OS Version: Mac OS X 10.10.3 (14D136)
Report Version: 11
Anonymous UUID: BD66BF09-84D4-2B80-14C4-4154AD6F16B2
Time Awake Since Boot: 90 seconds
Crashed Thread: 0
Exception Type: EXC_CRASH (Code Signature Invalid)
Exception Codes: 0x0000000000000000, 0x0000000000000000
kernel messages:
VM Regions Near 0x7fff779980a0 (cr2):
__LINKEDIT 00007fff6903b000-00007fff6904f000 [ 80K] r--/rwx SM=COW /usr/lib/dyld
--> Submap 00007fff70000000-00007fff80000000 [256.0M] r--/rwx SM=PRV process-only VM submap
unused shlib __DATA 00007fff76d4a000-00007fff79346000 [ 38.0M] rw-/rw- SM=COW system shared lib __DATA not used by this process
Thread 0 Crashed:
0 dyld 0x00007fff68fcc000 _dyld_start + 0
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x000000000000000d rbx: 0x0000000000000000 rcx: 0x0000000000000000 rdx: 0x0000000000000000
rdi: 0x0000000000000000 rsi: 0x0000000000000000 rbp: 0x0000000000000000 rsp: 0x00007fff540a8c80
r8: 0x0000000000000000 r9: 0x0000000000000000 r10: 0x0000000000000000 r11: 0x0000000000000000
r12: 0x0000000000000000 r13: 0x0000000000000000 r14: 0x0000000000000000 r15: 0x0000000000000000
rip: 0x00007fff68fcc000 rfl: 0x0000000000000201 cr2: 0x00007fff779980a0
Logical CPU: 0
Error Code: 0x020000f4
Trap Number: 133
Binary Images:
0x7fff68fcb000 - 0x7fff69001837 dyld (???) <65DCCB06-339C-3E25-9702-600A28291D0E> /usr/lib/dyld
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 230
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=300K resident=220K(73%) swapped_out_or_unallocated=80K(27%)
Writable regions: Total=8416K written=0K(0%) resident=12K(0%) swapped_out=0K(0%) unallocated=8404K(100%)
REGION TYPE VIRTUAL
STACK GUARD 56.0M
Stack 8192K
VM_ALLOCATE 8K
VM_ALLOCATE (reserved) 4K reserved VM address space (unallocated)
__DATA 228K
__LINKEDIT 80K
__TEXT 220K
mapped file 248K
shared memory 4K
TOTAL 64.8M
TOTAL, minus reserved VM space 64.8M
Model: MacBookAir6,2, BootROM MBA61.0099.B18, 2 processors, Intel Core i5, 1.4 GHz, 4 GB, SMC 2.13f15
Graphics: Intel HD Graphics 5000, Intel HD Graphics 5000, Built-In
Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1600 MHz, 0x80AD, 0x483943434E4E4E384A544D4C41522D4E544D
Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1600 MHz, 0x80AD, 0x483943434E4E4E384A544D4C41522D4E544D
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x117), Broadcom BCM43xx 1.0 (7.15.166.24.3)
Bluetooth: Version 4.3.4f4 15601, 3 services, 18 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Serial ATA Device: APPLE SSD SD0128F, 121,33 GB
USB Device: Internal Memory Card Reader
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
Thunderbolt Bus: MacBook Air, Apple Inc., 23.6
A par une Apple Watch, quel est ton matériel, année, modèle, OS X en cours, bref un maximum d'informations. :)
Mais je crois que le mieux, à l'instar d'une mise à jour combinée qui je pense ne résoudra pas le problème, serait de faire une réinstallation. Tu redémarres en maintenant les touches cmd + R, tu ne formates pas ton disque dur, tu te contentes de faire une installation par dessus, ça n'effacera pas tes fichiers, dossiers ou données personnelles.
Un grand merci ca a fonctionné !!!
je me permet de te poser encore une autre question car depuis tantot j'essaye de formater mon disque dur externe, qui fonctionnait par le passé sans problème, je voulais le formater pour utiliser boot camp mais impossible de le formater, j'ai déjà essayé énormément de chose mais voici les messages d'erreurs
"impossible d'écrire sur le dernier bloc du disque"
merci
Tu oublies cette possibilité, car Boot Camp ne peut fonctionner que dans un disque dur interne sans partition.
Dans quel format, pour Mac ou pour Windows ?
Essaye avec un autre Mac, s'il est visible avec Utilitaire de disque, commence par faire un formatage en ExFAT et tu le teste dans ton Mac.
Ah ok, et donc je dois utiliser une simple clé usb ? Vraiment deso je n y connais rien
J'ai essayé avec un autre mac il ne le reconnaît pas non plus
Quand j'ignore le message j'essaie de le formater au format exfat mais le même message d'erreur
Windows ne le reconnaît plus non plus :(
Pourquoi faire une clé USB ?
Question déjà posée et sans réponse. A la base ce disque USB était dans quel format, pour Mac ou pour Windows ?
Très mauvais signe, le voyant s'allume et tu entends le plateau tourner ?
Je ne sais pas j'ai l image Iso car pas de lecteur dvd pour utiliser bootcamp et il me demande d'insérer un usb. .
Mon disque dur est neuf, je l'ai directement utilisé sur mon mac sans passe par Windows avant
