Help Help - MacGimp veut pô marcher
_gromit_
15 Mai 2000
458
5
42
Valence
softomatic.macdk.com
Alors je me suis tapé les 186 Mo de MacGIMP avec mon p'tit 56k
j'ai installé X-Free 4.1 et le MacGimp, mais ça marche pô...
Quand j'essaie de lancer The Gimp par l'application Run MacGIMP™, la chose suivante s'affiche dans la console :
<BLOCKQUOTE><font size="1" face="Verdana, Geneva">quote:</font><HR>Unrecognized option: -rootless
use: X [:&lt;display&gt;] [option]
-a # mouse acceleration (pixels)
-ac disable access control restrictions
-audit int set audit trail level
-auth file select authorization file
bc enable bug compatibility
+bs enable any backing store support
-bs disable any backing store support
-c turns off key-click
c # key-click volume (0-100)
-cc int default color visual class
-co file color database file
-core generate core dump on fatal error
-dpi int screen resolution in dots per inch
dpms enables VESA DPMS monitor control
-dpms disables VESA DPMS monitor control
-deferglyphs [none|all|16] defer loading of [no|all|16-bit] glyphs
-f # bell base (0-100)
-fc string cursor font
-fn string default font name
-fp string default font path
-help prints message with these options
-I ignore all remaining arguments
-ld int limit data space to N Kb
-lf int limit number of open files to N
-ls int limit stack space to N Kb
-nolock disable the locking mechanism
-logo enable logo in screen saver
nologo disable logo in screen saver
-nolisten string don't listen on protocol
-p # screen-saver pattern duration (minutes)
-pn accept failure to listen on all ports
-nopn reject failure to listen on all ports
-r turns off auto-repeat
r turns on auto-repeat
-s # screen-saver timeout (minutes)
-sp file security policy file
-su disable any save under support
-t # mouse threshold (pixels)
-terminate terminate at server reset
-to # connection time out
-tst disable testing extensions
ttyxx server started from init on /dev/ttyxx
v video blanking for screen-saver
-v screen-saver without video blanking
-wm WhenMapped default backing-store
-x string loads named extension at init time
+xinerama Enable XINERAMA extension
-xinerama Disable XINERAMA extension
-query host-name contact named host for XDMCP
-broadcast broadcast for XDMCP
-indirect host-name contact named host for indirect XDMCP
-port port-num UDP port number to send messages to
-from local-address specify the local address to connect from
-once Terminate server after one session
-class display-class specify display class to send in manage
-displayID display-id manufacturer display ID for request
The X Keyboard Extension adds the following arguments:
-kb disable the X Keyboard Extension
+kb enable the X Keyboard Extension
[+-]accessx [ timeout [ timeout_mask [ feedback [ options_mask] ] ] ]
enable/disable accessx key sequences
-ar1 set XKB autorepeat delay
-ar2 set XKB autorepeat interval
-noloadxkb don't load XKB keymap description
-xkbcomp default keymap compiler
-xkbdb file that contains default XKB keymaps
-xkbmap XKB keyboard description to load on startup
Device Dependent Usage:
-fakebuttons : fake a three button mouse with Command and Option keys.
-nofakebuttons : don't fake a three button mouse.
-keymap &lt;file&gt; : read the keymapping from a file instead of the kernel.
-version : show the server version.
-quartz : run in parallel with Mac OS X Quartz window server.
IOKit specific options (ignored with -quartz):
-screen &lt;0,1,...&gt; : use this screen number.
-size &lt;height&gt; &lt;width&gt; : use a screen resolution of &lt;height&gt; x &lt;width&gt;.
-depth &lt;8,15,24&gt; : use this bit depth.
-refresh &lt;rate&gt; : use a monitor refresh rate of &lt;rate&gt; Hz.
giving up.
xinit: No such file or directory (errno 2): unable to connect to X server
xinit: No such process (errno 3): Server error.
<HR></BLOCKQUOTE>
et rien ne se passe...
lorsque je souhaite lancer X-Free par le terminal avec un startx -- -rootless, ça me retourne la chose suivante :
<BLOCKQUOTE><font size="1" face="Verdana, Geneva">quote:</font><HR>xinit: No such file or directory (errno 2): no server "X" in PATH
Use the -- option, or make sure that /usr/X11R6/bin is in your path and
that "X" is a program or a link to the right type of server
for your display. Possible server names include:
XFree86 XFree86 displays
XDarwin Darwin/Mac OS X IOKit displays
XDarwinQuartz Mac OS X Quartz displays
XDarwinStartup Auto-select between XDarwin and XDarwinQuartz
giving up.
<HR></BLOCKQUOTE>
quelqu'un a une idée, ou une solution à me proposer, parce que là, je suis vraiment deçu
