Last login: Wed Dec 6 23:51:14 on ttys000
MacBook-Pro-de-maxime-2:~ cltmtr$ is
-bash: is: command not found
MacBook-Pro-de-maxime-2:~ cltmtr$ rm Library/LaunchAgents/com.apple.CSConfigDotMacCer*
Last login: Wed Dec 6 23:55:59 on ttys000
MacBook-Pro-de-maxime-2:~ cltmtr$ sudo rm /Library/LaunchDaemons/com.adobe.fpsaud.plist
Password:
rm: /Library/LaunchDaemons/com.adobe.fpsaud.plist: No such file or directory
MacBook-Pro-de-maxime-2:~ cltmtr$ sudo trimforce enable
IMPORTANT NOTICE: This tool force-enables TRIM for all relevant attached
devices, even though such devices may not have been validated for data
integrity while using TRIM. Use of this tool to enable TRIM may result in
unintended data loss or data corruption. It should not be used in a commercial
operating environment or with important data. Before using this tool, you
should back up all of your data and regularly back up data while TRIM is
enabled. This tool is provided on an “as is” basis. APPLE MAKES NO WARRANTIES,
EXPRESS OR IMPLIED, INCLUDING WITHOUT LIMITATION THE IMPLIED WARRANTIES OF
NON-INFRINGEMENT, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE,
REGARDING THIS TOOL OR ITS USE ALONE OR IN COMBINATION WITH YOUR DEVICES,
SYSTEMS, OR SERVICES. BY USING THIS TOOL TO ENABLE TRIM, YOU AGREE THAT, TO THE
EXTENT PERMITTED BY APPLICABLE LAW, USE OF THE TOOL IS AT YOUR SOLE RISK AND
THAT THE ENTIRE RISK AS TO SATISFACTORY QUALITY, PERFORMANCE, ACCURACY AND
EFFORT IS WITH YOU.
Are you sure you wish to proceed (y/N)? y
Your system will immediately reboot when this is complete.
Is this OK (y/N)? y
Enabling TRIM...
Operation succeeded. Your system will reboot momentarily, please wait...
[Restauré 7 déc. 2017 à 00:03:14]
Last login: Thu Dec 7 00:03:12 on console
Restored session: Jeu 7 déc 2017 00:02:12 CET
EtreCheck version : 3.4.6 (460)
Rapport créé le 2017-12-07 00:09:22
Télécharger EtreCheck chez https://etrecheck.com
Temps d’exécution : 2:07
La vitesse : Excellente
Cliquez sur les liens [Rechercher] pour plus d’informations à partir des Communautés d’assistance Apple.
Cliquez sur les liens [Détails] pour plus d’informations sur cette ligne.
Problème : L‘ordinateur est trop lent
Informations matérielles : ⓘ
MacBook Pro (13 pouces, mi-2012)
[Les caractéristiques techniques] - [Le guide de l’utilisateur] - [Garantie & service]
MacBook Pro - modèle : MacBookPro9,2
1 2,9 GHz Intel Core i7 (i7-3520M) CPU: 2-core
8 GB RAM Extensible - [Instructions]
BANK 0/DIMM0
4 GB DDR3 1600 MHz ok
BANK 1/DIMM0
Handoff/Airdrop2: disponible
Réseau sans fil : en1 : 802.11 a/b/g/n
Batterie : Santé = Satisfaisant - Nombre de cycles = 387
Quota iCloud : 4.84 Go disponible
Informations vidéo : ⓘ
Intel HD Graphics 4000 - VRAM : 1536 Mo
Color LCD 1280 x 800
Informations des disques : ⓘ
OCZ-AGILITY3 disk1: (120,03 Go) (SSD - TRIM: Oui)
[Afficher le rapport SMART]
EFI (disk1s1 - MS-DOS FAT32) <non monté> [EFI] : 210 Mo
(disk1s2) <non monté> [Conteneur APFS]: 119.82 Go
Crucial_CT750MX300SSD1 disk0: (750,16 Go) (SSD - TRIM: Oui)
EFI (disk0s1 - MS-DOS FAT32) <non monté> [EFI] : 210 Mo
Crucial Max (disk0s2 - HFS+ journalisé) /Volumes/Crucial Max : 749.30 Go (647.30 Go libre)
Recovery HD (disk0s3 - HFS+ journalisé) <non monté> [Recovery] : 650 Mo
Informations USB : ⓘ
USB20Bus
hub_device
hub_device
Apple Inc. Apple Internal Keyboard / Trackpad
Apple Computer, Inc. IR Receiver
Apple Inc. BRCM20702 Hub
Apple Inc. Bluetooth USB Host Controller
USB20Bus
hub_device
Apple Inc. FaceTime HD Camera (Built-in)
USB30Bus
Informations Thunderbolt : ⓘ
Apple Inc. thunderbolt_bus
Disques virtuels : ⓘ
OCZ Max (disk2s1 - APFS) / [Startup] : 119.82 Go (66.54 Go libre)
Disque physique : disk1s2 119.82 Go (66.54 Go libre)
(disk2s2) <non monté> [Preboot]: 119.82 Go
(disk2s3) <non monté> [Recovery]: 119.82 Go
(disk2s4) /private/var/vm [VM]: 119.82 Go
Logiciels du système : ⓘ
macOS High Sierra 10.13.1 (17B1003) - Temps écoulé depuis le démarrage : moins d’une heure
Gatekeeper : ⓘ
Mac App Store et développeurs identifiés
Extensions du noyau : ⓘ
/Applications/Toast 11 Titanium/Spin Doctor.app
[Désengagé] com.hzsystems.terminus.driver (4) [Rechercher]
/Applications/Toast 11 Titanium/Toast Titanium.app
[Désengagé] com.roxio.BluRaySupport (1.1.6) [Rechercher]
~/Library/Services/ToastIt.service/Contents/MacOS
[Désengagé] com.roxio.TDIXController (2.0) [Rechercher]
Agents de lancement systèmes : ⓘ
[Désengagé] 8 tâches d’Apple
[Engagé] 181 tâches d’Apple
[En marche] 99 tâches d’Apple
Daemons de lancement systèmes : ⓘ
[Désengagé] 36 tâches d’Apple
[Engagé] 184 tâches d’Apple
[En marche] 111 tâches d’Apple
Agents de lancement : ⓘ
[En marche] com.brother.LOGINserver.plist (? a1772de2 41ad4933 - installé 2015-11-30) [Rechercher]
Daemons de lancements : ⓘ
[Désengagé] com.apple.installer.cleanupinstaller.plist (? 1963bf56 0 - installé 2017-11-26)
[Engagé] com.malwarebytes.HelperTool.plist (Malwarebytes Corporation - installé 2017-12-06) [Rechercher]
Agents de lancement pour l’utilisateur : ⓘ
[Engagé] com.bittorrent.uTorrent.plist (BitTorrent, Inc - installé 2016-03-17) [Rechercher]
Éléments Ouverture : ⓘ
Garmin Express Service Application (Garmin International - installé 2017-11-26)
(/Applications/Garmin Express.app/Contents/Library/LoginItems/Garmin Express Service.app)
iTunesHelper Application (Apple, Inc. - installé 2017-11-01)
(/Applications/iTunes.app/Contents/MacOS/iTunesHelper.app)
Modules internets : ⓘ
FlashPlayer-10.6: 26.0.0.131 (installé 2017-07-03) [Rechercher]
QuickTime Plugin: 7.7.3 (installé 2017-10-25)
Flash Player: 26.0.0.131 (installé 2017-07-03) Obsolète ! Mettre à jour
SharePointBrowserPlugin: 14.1.0 (installé 2012-11-28) [Rechercher]
Extensions de Safari : ⓘ
[Activée] AdBlock - BetaFish, Inc. - https://getadblock.com (installé 2017-11-15)
[Activée] Evernote Web Clipper - Evernote Corp. - http://evernote.com (installé 2017-11-06)
[Activée] Adblock Plus - Eyeo GmbH - https://adblockplus.org/ (installé 2016-12-22)
[Activée] DuckDuckGo - DuckDuckGo - http://duckduckgo.com (installé 2017-07-26)
[Activée] TimeSaver - Cristian Negoita - http://www.extensionsweb.com (installé 2016-03-09)
Panneaux de préférences tiers : ⓘ
Flash Player (installé 2017-06-15) [Rechercher]
Perian (installé 2011-07-23) [Rechercher]
Time Machine : ⓘ
Sauvegardes mobiles : Désactivé
Sauvegarde automatique : OUI
Disques sauvegardés :
OCZ Max : Taille du disque : 119.82 Go Disque utilisé : 53.28 Go
Destinations :
D.D Secondaire [Local]
Taille totale : 0 o
Nombre total de sauvegardes : 0
Sauvegarde la plus ancienne : -
Dernière sauvegarde : -
Taille du disque de sauvegarde : Trop petite
Taille de la sauvegarde 0 o > (Disque utilisé 53.28 Go X 3)
Sans titre [Local]
Taille totale : 1.05 To
Nombre total de sauvegardes : 3
Sauvegarde la plus ancienne : 29/11/2017 19:12
Dernière sauvegarde : 29/11/2017 21:20
Taille du disque de sauvegarde : Excellent
Taille de la sauvegarde 1.05 To > (Taille du disque 119.82 Go X 3)
Utilisation du processeur par opération : ⓘ
8% WindowServer
6% kernel_task
1% locationd
0% fontd
0% ps
Utilisation de la RAM par opération : ⓘ
845 Mo Safari
708 Mo kernel_task
652 Mo com.apple.WebKit.WebContent
129 Mo cfprefsd
126 Mo mds_stores
Utilisation du réseau par opération : ⓘ
Entrée Sortie Nom de l’opération
233 Ko 6 Ko locationd
38 Ko 36 Ko mDNSResponder
8 Ko 11 Ko apsd
7 Ko 2 Ko cloudd
5 Ko 979 o com.apple.Safari.SafeBrowsing.Service
Utilisation de l’énergie par opération : ⓘ
15.00 WindowServer
0.18 nsurlsessiond
0.14 SystemUIServer
0.06 cloudd
Informations de la mémoire virtuelle : ⓘ
4.03 Go RAM disponible
2.42 Go RAM libre
3.97 Go RAM utilisée
1.61 Go Fichiers en cache
0 o Fichier d’échange utilisé
Installations de logiciel (30 derniers jours) : ⓘ
Garmin Express: (installé 2017-11-26)
La liste des installations peut ne pas être complète.
Événements du diagnostic (3 dernier jours si pas grave): ⓘ
2017-12-06 23:57:34 com.apple.WebKit.WebContent Taux d’usage du CPU élevé [Ouvrir] [Les détails]
Fichiers enlevés par EtreCheck : ⓘ
2017-12-06 20:14:53 - ~/Library/LaunchAgents/spid-uninstall.plist - Inconnu
2017-12-06 20:15:56 - ~/Library/LaunchAgents/com.apple.CSConfigDotMacCert-[expurgé]@me.com-SharedServices.Agent.plist - Inconnu
2017-12-06 20:15:56 - ~/Library/LaunchAgents/spid.plist - Inconnu
2017-12-06 20:16:16 - /Library/LaunchDaemons/com.adobe.fpsaud.plist - Inconnu
Mais encore....bonjour jean effectivement, je ne comprends pas grand chose mis a part le fait de réinitialiser le contenu de la library....
j'ai installé ublock et viré le reste....vraiment merci pour ton aide t'es le meilleur!.
Pas au démarrage ...., mais pour la saisie de texte c’est parfait!Mais encore....
Ça c'est amélioré ?
