| -bash-3.2# diskutil list /dev/disk0 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: GUID_partition_scheme +2.1 GB disk0 1: Apple_HFS OS X Base System 2.0 GB disk0s1 /dev/disk1 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +5.2 MB disk1 /dev/disk2 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +524.3 KB disk2 /dev/disk3 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +524.3 KB disk3 /dev/disk4 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +524.3 KB disk4 /dev/disk5 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +2.1 MB disk5 /dev/disk6 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +524.3 KB disk6 /dev/disk7 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +524.3 KB disk7 /dev/disk8 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +12.6 MB disk8 /dev/disk9 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +4.2 MB disk9 /dev/disk10 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +1.0 MB disk10 /dev/disk11 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +2.1 MB disk11 /dev/disk12 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +524.3 KB disk12 /dev/disk13 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +524.3 KB disk13 /dev/disk14 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +1.0 MB disk14 /dev/disk15 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +6.3 MB disk15 /dev/disk16 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +6.3 MB disk16 /dev/disk17 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +524.3 KB disk17 /dev/disk18 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +2.1 MB disk18 /dev/disk19 (external, physical): #: TYPE NAME SIZE IDENTIFIER 0: FDisk_partition_scheme *15.5 GB disk19 1: DOS_FAT_32 UNTITLED 15.5 GB disk19s1 /dev/disk20 (external, physical): #: TYPE NAME SIZE IDENTIFIER 0: FDisk_partition_scheme *30.8 GB disk20 1: Windows_FAT_32 NO NAME 30.8 GB disk20s1 /dev/disk21 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: DownloadCache +41.9 MB disk21 /dev/disk22 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: GUID_partition_scheme +61.4 MB disk22 1: Apple_HFS iBoysoft Data Recovery 61.4 MB disk22s1 -bash-3.2# diskutil eraseVolume jhfs+ "Macintosh HD" disk0s2 Unable to find disk for disk0s2 -bash-3.2# diskutil eraseVolume jhfs+ "Macintosh HD" disk0 Started erase on disk0 Unmounting disk Error: -69888: Couldn't unmount disk |
Il s’agit d’un MacBook Pro 13" Core 2 Duo 2,4 GHz - HDD 250 Go RAM 4 Go AZERTY je ne connais pas son année.Bonjour Fathy
Il n'y a que des images-disques formées en RAM affichées dans le tableau. Le disque dur interne n'est pas connecté.
- quels sont le modèle et l'année de ton Mac ?
En effet quelques chose semble être HS car le disque reste introuvable. Les branchements semblaient correct mais j’ai qd même rebrancher. Que faire maintenant. Merci encore pour votre aide.Cela semble un MacBook Pro 13" mi-2010.
- regarde ce tuto iFixit : ☞Remplacement du disque dur du MacBook Pro 13" Unibody mi-2010☜. Avec un tournevis cruciforme 00 > tu peux dévisser les vis de la plaque du fond du Mac > puis vérifier si la nappe (câble plat type ruban qui relie le disque à la carte-mère) est bien branchée au connecteur du disque. Si tu t'aperçois qu'il y avait un mauvais branchement > rebranche > referme le Mac > vérifie si le HDD se trouve connecté et listé.- sinon : soit le HDD est HS > soit la nappe SATA est HS.
Non je n’en ai pas je vais essayer de m’en procurer un demain. Cependant, en vaudrait il le coup de faire réparer l’ordinateur par un professionnel?Afin de savoir si c'est le disque ou la nappe qui est HS --> il te faudrait pouvoir brancher le disque en USB externe via un câble SATA <=> USB. Je ne sais pas si tu en disposes ?
0: GUID_partition_scheme *1.0 TB disk0
1: EFI EFI 209.7 MB disk0s1
2: Apple_HFS OS X Base System 999.3 GB disk0s2
3: Apple_Boot Recovery HD 650.0 MB disk0s3
Bonjour à tous je suis actuellement le fil du forum et je viens de copier le code désolé pour le mauvais copier coller.Bloc de code:/dev/disk0 (internal, physical): #: TYPE NAME SIZE IDENTIFIER 0: GUID_partition_scheme *1.0 TB disk0 1: EFI EFI 209.7 MB disk0s1 2: Apple_HFS OS X Base System 999.3 GB disk0s2 3: Apple_Boot Recovery HD 650.0 MB disk0s3 /dev/disk1 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +5.2 MB disk1 /dev/disk2 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +524.3 KB disk2 /dev/disk3 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +524.3 KB disk3 /dev/disk4 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +524.3 KB disk4 /dev/disk5 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +2.1 MB disk5 /dev/disk6 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +524.3 KB disk6 /dev/disk7 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +524.3 KB disk7 /dev/disk8 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +12.6 MB disk8 /dev/disk9 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +4.2 MB disk9 /dev/disk10 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +1.0 MB disk10 /dev/disk11 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +2.1 MB disk11 /dev/disk12 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +524.3 KB disk12 /dev/disk13 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +524.3 KB disk13 /dev/disk14 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +1.0 MB disk14 /dev/disk15 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +6.3 MB disk15 /dev/disk16 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +6.3 MB disk16 /dev/disk17 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +524.3 KB disk17 /dev/disk18 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +2.1 MB disk18
