GPT fdisk (gdisk) version 1.0.8
Warning: Devices opened with shared lock will not have their
partition table automatically reloaded!
Partition table scan:
  MBR: hybrid
  BSD: not present
  APM: not present
  GPT: present
Found valid GPT with hybrid MBR; using GPT.
Command (? for help): x
Expert command (? for help):Expert command (? for help):nGPT fdisk (gdisk) version 1.0.8
  MBR: hybrid
  BSD: not present
  APM: not present
  GPT: present
Expert command (? for help): n
Expert command (? for help):wExpert command (? for help): w
Final checks complete. About to write GPT data. THIS WILL OVERWRITE EXISTING
PARTITIONS!!
Do you want to proceed? (Y/N):yDo you want to proceed? (Y/N): Y
OK; writing new GUID partition table (GPT) to /dev/disk0.
Warning: The kernel may continue to use old or deleted partitions.
You should reboot or remove the drive.
The operation has completed successfully.sudo gpt show disk0Last login: Thu Jun 24 12:11:40 on ttys000
iMac-de-Jimmy:~ jimmy$ sudo gpt disk0
Password:
gpt: unknown command: disk0
iMac-de-Jimmy:~ jimmy$sudo gpt show disk0       start        size  index  contents
           0           1         PMBR
           1           1         Pri GPT header
           2          32         Pri GPT table
          34           6
          40      409600      1  GPT part - C12A7328-F81F-11D2-BA4B-00A0C93EC93B
      409640   386718752      2  GPT part - 7C3457EF-0000-11AA-AA11-00306543ECAC
   387128392         952
   387129344  1565343744      3  GPT part - EBD0A0A2-B9E5-4433-87C0-68B6B72699C7
  1952473088     1048576      4  GPT part - DE94BBA4-06D1-4D40-A16A-BFD50179D6AC
  1953521664        3471
  1953525135          32         Sec GPT table
  1953525167           1         Sec GPT header           0           1         PMBROK je vous retourne au plus vite le résultat. Merci merci merci mille fois Macomaniac et Locke pour votre aideVoici -->
Bloc de code:0 1 PMBR
- tout ça pour ça... :hilarious:
Tu n'as qu'à relancer ton Assistant BootCamp et voir si tu es débloqué pour l'installation de W-10.
