10.13 High Sierra probleme de lancement imac2009 27"
part 1/2( trop de signes)
-bash-3.2# diskutil list
   2:                  Apple_HFS DD MAC                  500.0 GB   disk0s2
   4:                  Apple_HFS Clone                   499.2 GB   disk0s4
/dev/disk1 (external, physical):
   0:      GUID_partition_scheme                        *8.1 GB     disk1
   2:                  Apple_HFS OS X Base System        7.7 GB     disk1s2
   0:     FDisk_partition_scheme                        *2.0 TB     disk2
   1:                 DOS_FAT_32 ANNE COPIE2             2.0 TB     disk2s1
   0:      GUID_partition_scheme                        *32.0 GB    disk3
   2:                  Apple_HFS TEST                    31.2 GB    disk3s2
   3:                 Apple_Boot Recovery HD             650.0 MB   disk3s3
/dev/disk4 (disk image):
   0:      GUID_partition_scheme                        +2.1 GB     disk4
   1:                  Apple_HFS OS X Base System        2.0 GB     disk4s1
/dev/disk5 (disk image):
   0:                            untitled               +5.2 MB     disk5
/dev/disk6 (disk image):
/dev/disk7 (disk image):
/dev/disk8 (disk image):
/dev/disk9 (disk image):
   0:                            untitled               +2.1 MB     disk9
/dev/disk10 (disk image):
   0:                            untitled               +524.3 KB   disk10
/dev/disk11 (disk image):
part 2/2
disk11
/dev/disk12 (disk image):
   0:                            untitled               +12.6 MB    disk12
/dev/disk13 (disk image):
   0:                            untitled               +4.2 MB     disk13
/dev/disk14 (disk image):
   0:                            untitled               +1.0 MB     disk14
/dev/disk15 (disk image):
   0:                            untitled               +2.1 MB     disk15
/dev/disk16 (disk image):
   0:                            untitled               +524.3 KB   disk16
/dev/disk17 (disk image):
   0:                            untitled               +524.3 KB   disk17
/dev/disk18 (disk image):
   0:                            untitled               +1.0 MB     disk18
/dev/disk19 (disk image):
   0:                            untitled               +6.3 MB     disk19
/dev/disk20 (disk image):
   0:                            untitled               +6.3 MB     disk20
/dev/disk21 (disk image):
   0:                            untitled               +524.3 KB   disk21
/dev/disk22 (disk image):
   0:                            untitled               +2.1 MB     disk22
-bash-3.2#
Passe la commande :
diskutil eraseDisk jhfs+ DDE2TO gpt disk2
  • la commande initialise "Mac" le disque du DDE de 2 To : table GPT > format jhfs+ > nom de volume DDE2TO
Poste le retour.
-bash-3.2# diskutil eraseDisk jhfs+ DDE2TO gpt disk2
Started erase on disk2
Unmounting disk
Creating the partition map
Waiting for partitions to activate
Formatting disk2s2 as Mac OS Extended (Journaled) with name DDE2TO
Initialized /dev/rdisk2s2 as a 2 TB case-insensitive HFS Plus volume with a 155648k journal
Mounting disk
Finished erase on disk2
-bash-3.2#
Parfait ! - alors voici l'idée générale de la manœuvre -->
- tu relances une installation > à destination du volume DD2TO cette fois-ci​
- à la fin de l'installation > le Mac va redémarrer sur l'OS installé proprement dans le volume DD2TO
- si le démarrage va à son terme cette fois-ci => hop ! quand tu as l'écran te proposant de récupérer des données > tu choisis : "À partir d'un Mac etc." et Clone en source et tu vois si tu peux ouvrir une session en externe à la fin​
=> tu n'auras qu'à rendre compte de ton expérience.
Bon... encore une fois le redémarrage ne va pas à son terme . L’os a pourtant bien était installé.
Je ne comprends pas ce qui peut ainsi le bloquer???
J’espérais ne pas en arriver là... mais bon je pense qu’on a tout tenté.
Je vais voir quel magasin il y a sur Toulouse.
Je te tiendrais au courant si tu veux.
Je débranche les 2 clés usb
Et le DD externe.
Merci bcp pour ton guidage et ta connaissance sur l’outil mac .
Belle soirée
