Ok, ça a l'air fâcheux... Dis moi, dans cette procédure, je  risque pas de perdre des applications en licence, des paramètres, préférences, réglages où autres types de données, c'est certain ?
   2:          Apple_CoreStorage Macintosh HD            120.5 GB   disk0s2
/dev/disk1 (internal, virtual):
   0:                  Apple_HFS Macintosh HD           +120.1 GB   disk1
                                 Logical Volume on disk0s2
                                 F8761934-10DC-458B-9ECB-63D686D4E152
                                 Unencrypted
   0:      GUID_partition_scheme                        *500.1 GB   disk2
   1:                        EFI EFI                     209.7 MB   disk2s1
   2:                  Apple_HFS DDEXT LEO               499.2 GB   disk2s2
   3:                 Apple_Boot Recovery HD             650.0 MB   disk2s3
	diskutil reformat disk1
sudo mdutil -E /
	Le système fait toujours 44 Go cependant...
	sudo du -d 0 -hx /
df -H /
	diskutil cs list
	sudo du -d 0 -hx /
78G    /
	df -H /
Filesystem   Size   Used  Avail Capacity iused      ifree %iused  Mounted on
/dev/disk1   120G    85G    35G    72% 1116469 4293850810    0%   /
	diskutil cs list
CoreStorage logical volume groups (1 found)
+-- Logical Volume Group 9D6DB5B2-188D-4A43-AA5D-734BEEA89B4B
    Status:       Online
    Size:         120473067520 B (120.5 GB)
    Free Space:   18948096 B (18.9 MB)
    +-< Physical Volume A607363F-5C73-4CDB-9C1E-96CAFD2B3C81
    |   Index:    0
    |   Disk:     disk0s2
    |   Status:   Online
    +-> Logical Volume Family B4AAABA2-E0D5-4C72-B7BF-E5E0B320E89F
        Encryption Type:         None
        +-> Logical Volume F8761934-10DC-458B-9ECB-63D686D4E152
            Disk:                  disk1
            Status:                Online
            Size (Total):          120101797888 B (120.1 GB)
            Revertible:            Yes (no decryption required)
            LV Name:               Macintosh HD
            Volume Name:           Macintosh HD
            Content Hint:          Apple_HFS
	diskutil coreStorage revert F8761934-10DC-458B-9ECB-63D686D4E152
	diskutil info disk0s2
	 Device Identifier:        disk0s2
   Device Node:              /dev/disk0s2
   Whole:                    No
   Part of Whole:            disk0
   Mounted:                  Yes
   Mount Point:              /
   Partition Type:           Apple_HFS
   File System Personality:  Journaled HFS+
   Type (Bundle):            hfs
   Name (User Visible):      Mac OS Extended (Journaled)
   Journal:                  Journal size 16384 KB at offset 0x381000
   OS Can Be Installed:      Yes
   Recovery Disk:            disk0s3
   Protocol:                 SATA
   SMART Status:             Verified
   Volume UUID:              56687837-289B-327C-80AB-AE3C5E644AFD
   Disk / Partition UUID:    1D4D5346-2F9A-4A4C-B90C-07B63C09A29B
   Disk Size:                120.5 GB (120473067520 Bytes) (exactly 235298960 512-Byte-Units)
   Device Block Size:        512 Bytes
   Volume Total Space:       120.5 GB (120473067520 Bytes) (exactly 235298960 512-Byte-Units)
   Volume Used Space:        86.1 GB (86140743680 Bytes) (exactly 168243640 512-Byte-Units) (71.5%)
   Volume Available Space:   34.3 GB (34332323840 Bytes) (exactly 67055320 512-Byte-Units) (28.5%)
   Read-Only Media:          No
   Read-Only Volume:         No
   Removable Media:          Fixed
   Solid State:              Yes
	Utilitaires         espace total       espace occupé          espace libre
   Stockage         120,1 GB           84,35 GB               35,75 GB
   diskutil         120,5 GB           86,1 GB                34,3 GB
         df         120 GB             85 GB                  35 GB
         du         120 GB             78 GB                  42 GB
         du         120 GB             83,75 GB               36,25 GB
