10.14 Mojave Problème de stockage ?
  • Créateur du sujet Créateur du sujet sonof
Volontiers, ça fait du bien de faire de la place ! Le forum et la communauté Mac a de la chance de t'avoir ! Tu es très réactif, pédagogue, et une véritable encyclopédie, merci !
Passe la commande :
sudo du -sh /Lib*/*
  • qui mesure (en Gi) les sous-dossiers de la Bibliothèque
Poste le retour.
1,7G    /Library/Application Support
2,6M    /Library/Audio
212K    /Library/Automator
676M    /Library/Caches
  0B    /Library/ColorPickers
124K    /Library/ColorSync
  0B    /Library/Components
  0B    /Library/Compositions
  0B    /Library/Contextual Menu Items
  0B    /Library/CoreAnalytics
576K    /Library/CoreMediaIO
836M    /Library/Desktop Pictures
369M    /Library/Developer
  0B    /Library/DirectoryServices
7,4M    /Library/Documentation
4,9M    /Library/Extensions
  0B    /Library/Filesystems
334M    /Library/Fonts
794M    /Library/Frameworks
  0B    /Library/GPUBundles
4,0K    /Library/Google
  0B    /Library/Graphics
 22M    /Library/Image Capture
  0B    /Library/Input Methods
200M    /Library/Internet Plug-Ins
719M    /Library/Java
  0B    /Library/Keyboard Layouts
 17M    /Library/Keychains
 32K    /Library/LaunchAgents
 56K    /Library/LaunchDaemons
202M    /Library/Logs
104K    /Library/MessageTracer
 36K    /Library/Messages
 92K    /Library/Modem Scripts
  0B    /Library/OpenDirectory
432K    /Library/PDF Services
316K    /Library/Perl
  0B    /Library/PreferencePanes
1,2M    /Library/Preferences
655M    /Library/Printers
2,6M    /Library/PrivilegedHelperTools
104M    /Library/Python
 24M    /Library/QuickLook
 92K    /Library/QuickTime
 50M    /Library/Receipts
960K    /Library/Ruby
  0B    /Library/Sandbox
 48K    /Library/Screen Savers
 76K    /Library/ScriptingAdditions
1,5M    /Library/Scripts
 48K    /Library/Security
  0B    /Library/Speech
4,1M    /Library/Spotlight
4,9M    /Library/StagedExtensions
  0B    /Library/StartupItems
8,8M    /Library/SystemMigration
  0B    /Library/SystemProfiler
 56K    /Library/TeX
8,3G    /Library/Updates
 21M    /Library/User Pictures
  0B    /Library/Video
9,1M    /Library/WebServer
 32M    /Library/Widgets
Et voici, y'a surtout le dossier updates qui est lourd
Oui : Updates 8,3 Gi = 9 Go.
- tu peux aller voir avec le Finder dans ce dossier --> ce qui pèse autant ?​
Il s'agit de paquets d'installation de mises-à-jour de l'OS - sous forme d'itérations de dossiers que je ne sais pas interpréter.
- as-tu fait toutes les mises-à-jour de ton OS ?​
Tu pourrais bien sûr déplacer les dossiers à la corbeille (sans la vider) > puis redémarrer une fois pour voir l'effet produit...
- mais tu as dit que tu ne voulais pas actuellement redémarrer.​
Alors, j'ai regardé dans les mise à jour, et j'avais des mise à jour de sécurité de Mojave en attente. Je l'ai fait, l'ordi a du redemarrer, et en regardant ensuite le dossier update, le dernier à disparu (un qui datait de fin avril). Les autres datent d'avant, entre juillet 2020 et Fevrier 2021. Surement des mises à jour non appliquées donc...
Par contre si j'essaie de les déplacer dans la corbeille:
Tu n'as qu"à redémarrer une fois en mode secours (via ⌘R) et passer la commande :
csrutil disable
  • (qui désactive le SIP) dans le Terminal présent au menu Utilitaires de la barre de menus supérieure de l'écran.
De retour dans ta session > repasse la commande :
  • qui mesure (en Gi) les objets de 1er rang du volume démarré. Tu n'auras plus de dénis d'accès : "Operation not permitted".
Poste le nouveau tableau => qu'on voie où tu en es.
