diskutil eraseVolume jhfs+ BOOT disk21s2
-bash-3.2# diskutil eraseVolume jhfs+ BOOT disk21s2
Started erase on disk21s2 InstallESD
Unmounting disk
Erasing
Error: -69877: Couldn't open device
-bash-3.2#
diskutil eraseDisk jhfs+ BOOT gpt disk21
-bash-3.2# diskutil list
#: TYPE NAME SIZE IDENTIFIER
1: EFI EFI 209.7 MB disk0s1
2: Apple_APFS Container disk1 121.1 GB disk0s2
/dev/disk1 (synthesized):
0: APFS Container Scheme - +121.1 GB disk1
Physical Store disk0s2
1: APFS Volume Preboot 39.6 MB disk1s2
2: APFS Volume Recovery 517.8 MB disk1s3
3: APFS Volume VM 3.2 GB disk1s4
4: APFS Volume Macintosh 20.5 KB disk1s5
5: APFS Volume Mac essai 20.5 KB disk1s6
6: APFS Volume Macintosh HD 5.2 GB disk1s1
/dev/disk2 (disk image):
0: GUID_partition_scheme +2.1 GB disk2
1: Apple_HFS OS X Base System 2.0 GB disk2s1
/dev/disk3 (disk image):
0: untitled +5.2 MB disk3
/dev/disk4 (disk image):
0: untitled +524.3 KB disk4
/dev/disk5 (disk image):
0: untitled +524.3 KB disk5
/dev/disk6 (disk image):
0: untitled +524.3 KB disk6
/dev/disk7 (disk image):
0: untitled +2.1 MB disk7
/dev/disk8 (disk image):
0: untitled +524.3 KB disk8
/dev/disk9 (disk image):
0: untitled +524.3 KB disk9
/dev/disk10 (disk image):
0: untitled +12.6 MB disk10
/dev/disk11 (disk image):
0: untitled +4.2 MB disk11
/dev/disk12 (disk image):
0: untitled +1.0 MB disk12
/dev/disk13 (disk image):
0: untitled +2.1 MB disk13
/dev/disk14 (disk image):
0: untitled +524.3 KB disk14
/dev/disk15 (disk image):
0: untitled +524.3 KB disk15
/dev/disk16 (disk image):
0: untitled +1.0 MB disk16
/dev/disk17 (disk image):
0: untitled +6.3 MB disk17
/dev/disk18 (disk image):
0: untitled +6.3 MB disk18
/dev/disk19 (disk image):
0: untitled +524.3 KB disk19
/dev/disk20 (disk image):
0: untitled +2.1 MB disk20
/dev/disk21 (disk image):
0: GUID_partition_scheme +9.3 GB disk21
1: EFI EFI 209.7 MB disk21s1
2: Apple_HFS InstallESD 9.0 GB disk21s2
-bash-3.2#
diskutil ap resizeContainer disk1 116g jhfs+ BOOT 0b
-bash-3.2# diskutil ap resizeContainer disk1 116g jhfs+ BOOT 0b
Started APFS operation
Aligning shrink delta to 5 123 072 000 bytes and targeting a new physical store size of 115 999 997 952 bytes
Determined the minimum size for the targeted physical store of this APFS Container to be 9 466 388 480 bytes
Resizing APFS Container designated by APFS Container Reference disk1
The specific APFS Physical Store being resized is disk0s2
Verifying storage system
Using live mode
Performing fsck_apfs -n -x -l /dev/disk0s2
Checking volume
Checking the space manager
Checking the object map
Checking the fsroot tree
Checking the extent ref tree
Checking the snapshots
Verifying allocated space
warning: Overallocation Detected on Main device: (27231336+1) bitmap address (40244)
The volume /dev/disk0s2 appears to be OK
Shrinking APFS Physical Store disk0s2 from 121 123 069 952 to 115 999 997 952 bytes
Shrinking APFS data structures
Shrinking partition
Modifying partition map
Initialized /dev/rdisk0s3 as a 5 GB case-insensitive HFS Plus volume with a 8192k journal
Mounting disk
1 new disk created or changed due to APFS operation
Disk from APFS operation: disk0s3
Finished APFS operation
-bash-3.2#
asr restore --s / --t /Volumes/BOOT --erase --noprompt
-bash-3.2# asr restore --s / --t /Volumes/BOOT --erase --noprompt
Validating target...done
Validating source...done
Validating sizes...done
Restoring ....10....20....30....40....50....60....70....80....90....100
Verifying ....10....20....30....40....50....60....70....80....90....100
Remounting target volume...done
-bash-3.2#
diskutil list
2: Apple_APFS Container disk1 116.0 GB disk0s2
3: Apple_HFS OS X Base System 5.0 GB disk0s3
0: APFS Container Scheme - +116.0 GB disk1
1: APFS Volume Macintosh HD 5.2 GB disk1s1
2: APFS Volume Preboot 39.6 MB disk1s2
3: APFS Volume Recovery 517.8 MB disk1s3
4: APFS Volume VM 3.2 GB disk1s4
5: APFS Volume Macintosh 20.5 KB disk1s5
6: APFS Volume Mac essai 20.5 KB disk1s6
0: untitled +5.2 MB disk2
0: FDisk_partition_scheme *4.0 GB disk3
1: DOS_FAT_32 MUDAM 4.0 GB disk3s1
-bash-3.2#
diskutil ap deleteContainer disk1 "Macintosh HD"
-bash-3.2# diskutil ap deleteContainer disk1 "Macintosh HD"
Started APFS operation on disk1
Deleting APFS Container with all of its APFS Volumes
Unmounting Volumes
Unmounting Volume "Macintosh HD" on disk1s1
Unmounting Volume "Preboot" on disk1s2
Unmounting Volume "Recovery" on disk1s3
Unmounting Volume "VM" on disk1s4
Unmounting Volume "Macintosh" on disk1s5
Unmounting Volume "Mac essai" on disk1s6
Deleting Volumes
Deleting Container
Wiping former APFS disks
Switching content types
Reformatting former APFS disks
Initialized /dev/rdisk0s2 as a 108 GB case-insensitive HFS Plus volume with a 16384k journal
Mounting disk
Disk from APFS operation: disk0s2
Finished APFS operation on disk1
-bash-3.2#
diskutil list
