@macomaniac ok disque monté ! Voilà les infos obtenues avec tes trois commandes
-bash-3.2# diskutil info /Volumes/"Mactintosh HD"
Could not find disk: /Volumes/Mactintosh HD
-bash-3.2# diskutil info /Volumes/"Macintosh HD"
Device Identifier: disk2s1
Device Node: /dev/disk2s1
Whole: No
Part of Whole: disk2
Volume Name: Macintosh HD
Mounted: Yes
Mount Point: /Volumes/Macintosh HD
Partition Type: 41504653-0000-11AA-AA11-00306543ECAC
File System Personality: APFS
Type (Bundle): apfs
Name (User Visible): APFS
Owners: Enabled
OS Can Be Installed: Yes
Booter Disk: disk2s2
Recovery Disk: disk2s3
Media Type: Generic
Protocol: PCI
SMART Status: Not Supported
Volume UUID: 003CD4DB-644D-37A0-AAEE-01B61841BDAE
Disk / Partition UUID: 003CD4DB-644D-37A0-AAEE-01B61841BDAE
Disk Size: 250.8 GB (250790436864 Bytes) (exactly 489825072 512-Byte-Units)
Device Block Size: 4096 Bytes
Volume Total Space: 250.8 GB (250790436864 Bytes) (exactly 489825072 512-Byte-Units)
Volume Used Space: 205.7 GB (205692432384 Bytes) (exactly 401743032 512-Byte-Units) (82.0%)
Volume Available Space: 45.1 GB (45098004480 Bytes) (exactly 88082040 512-Byte-Units) (18.0%)
Allocation Block Size: 4096 Bytes
Read-Only Media: No
Read-Only Volume: No
Device Location: Internal
Removable Media: Fixed
Solid State: Yes
-bash-3.2# ls /Volumes/"Macintosh HD"
.DS_Store Users
.DocumentRevisions-V100 Volumes
.HFS+ Private Directory Data? bin
.IAProductInfo cores
.PKInstallSandboxManager dev
.PKInstallSandboxManager-SystemSoftware etc
.Spotlight-V100 home
.Trashes installer.failurerequests
.dbfseventsd macOS Install Data
.file model
.fseventsd net
.vol private
Applications sbin
Informations sur l’utilisateur tmp
Library usr
Network var
System
-bash-3.2# bless --info /Volumes/"Macintosh HD"
416 => Blessed System File is <Preboot>/003CD4DB-644D-37A0-AAEE-01B61841BDAE/com.apple.installer/boot.efi
67 => Blessed System Folder is <Preboot>/003CD4DB-644D-37A0-AAEE-01B61841BDAE/com.apple.installer
The blessed volume in this APFS container is "/Volumes/Macintosh HD"
-bash-3.2#
