10.12 Sierra Impossible de réinstaller macOS Sierra _ Pb via OS X Base System
Oui j'ai un macbook pro avec moi.
Je précise que j'ai du redémarrer l'ordinateur + cmd R pour avoir accès aux 4 utilitaires, sinon j'étais bloqué avec l'installeur et j'avais accès au terminal mais pas à Safari (pour transmettre les retours à mon autre mac)
Voici les retours :
-bash-3.2# diskutil list
   0:      GUID_partition_scheme                        *640.1 GB   disk0
   2:                  Apple_HFS Macintosh HD            639.3 GB   disk0s2
/dev/disk1 (disk image):
   0:     Apple_partition_scheme                        *1.0 TB     disk2
   1:        Apple_partition_map                         32.3 KB    disk2s1
   2:             Apple_Driver43                         65.5 KB    disk2s2
   3:           Apple_Driver_ATA                         65.5 KB    disk2s3
   4:             Apple_FWDriver                         114.7 KB   disk2s4
   5:                  Apple_HFS HUGO                    1.0 TB     disk2s6
/dev/disk3 (disk image):
/dev/disk4 (disk image):
/dev/disk5 (disk image):
/dev/disk6 (disk image):
/dev/disk7 (disk image):
/dev/disk8 (disk image):
/dev/disk9 (disk image):
   0:                            untitled               +6.3 MB     disk9
/dev/disk10 (disk image):
   0:                            untitled               +2.1 MB     disk10
/dev/disk11 (disk image):
   0:                            untitled               +1.0 MB     disk11
/dev/disk12 (disk image):
   0:                            untitled               +524.3 KB   disk12
/dev/disk13 (disk image):
   0:                            untitled               +524.3 KB   disk13
/dev/disk14 (disk image):
   0:                            untitled               +1.0 MB     disk14
/dev/disk15 (disk image):
   0:                            untitled               +6.3 MB     disk15
-bash-3.2#
-bash-3.2# df -H
Filesystem     Size   Used  Avail Capacity   iused     ifree %iused  Mounted on
/dev/disk1s1   2.0G   1.3G   715M    65%    316342    174624   64%   /
devfs          202k   202k     0B   100%       684         0  100%   /dev
/dev/disk3     5.2M   2.3M   2.9M    45%       568       710   44%   /private/var/log
/dev/disk4     524k   147k   377k    29%        34        92   27%   /Volumes
/dev/disk5     524k   143k   381k    28%        33        93   26%   /private/var/tmp
/dev/disk6     524k   160k   365k    31%        37        89   29%   /private/var/run
/dev/disk7     524k   147k   377k    29%        34        92   27%   /System/Installation
/dev/disk8     524k   258k   266k    50%        61        65   48%   /private/var/db
/dev/disk9     6.3M   3.3M   3.0M    53%       803       731   52%   /private/var/folders
/dev/disk10    2.1M   2.1M     0B   100%       510         0  100%   /private/var/root/Library
/dev/disk12    524k   168k   356k    33%        39        87   31%   /Library/Preferences
/dev/disk13    524k   164k   360k    32%        38        88   30%   /Library/Preferences/SystemConfiguration
/dev/disk14    1.0M   143k   905k    14%        33       221   13%   /Library/Keychains
/dev/disk15    6.3M   176k   6.1M     3%        41      1493    3%   /private/var/tmp/RecoveryTemp
/dev/disk2s6   1.0T   487G   513G    49% 119017589 125172955   49%   /Volumes/HUGO
/dev/disk0s2   639G   296G   343G    47%  72227738  83845324   46%   /Volumes/Macintosh HD
/dev/disk0s3   650M   524M   120M    82%    129403     29287   82%   /Volumes/Image
Il y a 513 Go d'espace disponible dans le volume HUGO. Type de partition "Apple_HFS" => donc format jhfs+ vraisemblable du volume.
- l'inconvénient est que le disque entier a une table de partition APM (Apple_Partition_Map) : table désuète qui est remplacée actuellement par une GPT (GUID_Partition_Table). Le volume HUGO est certes repartitionnable (non destructivement) avec cette table > mais je ne doute fort qu'El Capitan soit installable à la destination du nouveau volume créé. Car le programme d'installation va s'apercevoir de la supercherie (absence de GPT) - ne serait-ce que parce qu'il manque une petite partition EFI (de 209 Mo) qui se crée par défaut au 1er rang des partitions avec une table GPT.​
Si tu as un autre Mac actuellement => il serait plus judicieux d'explorer une alternative : confectionner une clé d'installation démarrable d'El Capitan. Ce qui permettrait de démarrer ton Mac planté sur la clé et de lancer l'installation depuis la clé.
- qu'en penses-tu ?​
Je peux également finir de vider mon DDE et le reformater avec une table GPT ?
Ou sinon la clé USB comme tu le proposes.
A vrai dire je suis un peu (complêtement) perdu à ce stade là, je fais plutôt confiance à ton jugement ! ^^
Après n'oublions pas que j'ai des sauvegardes Time Machine, ça me gène de te donner autant de travail alors que je pourrais faire une récup Time Machine et recommencer le travail de nettoyage que j'avais fait avant de planter le mac.
EDIT : je ne vois pas comment supprimer ce doublon ...
Il est tout récent c'est Catalina
Sinon j'ai aussi l'imac que tu m'avais aidé à réparer début janvier avec High Sierra dessus
J'ai également la clé USB d'installation de OSX Sierra que j'avais créé avec toi (j'avais ensuite fait la mise à niveau vers High Sierra)
Et j'ai différents installeurs sauvegardés dans mon MBP :
Avec ton iMac > utilise cette page : ☞Procédure de mise à niveau vers OS X El Capitan☜. À la rubrique 4 (Télécharger OS X El Capitan) > tu as un lien : Obtenir OS X El Capitan > qui va te faire récupérer une image-disque : InstallMacOSX.dmg.
- il faudra que tu montes son volume > puis que tu double-cliques le paquet d'installation inclus => pour créer un installateur Installer OS X El Capitan dans les Applications.​
=> préviens si tu as pu récupérer l'installateur (via cette opération à 2 étapes qu'Apple a compliquée de manière pénible).
Je viens d'essayer avec l'image disque que je possédais déjà (voir mon post précédent que j'ai édité pendant que tu me répondais)
J'ai ce message d'erreur :
Je vais essayer sur mon autre imac et pendant ce temps je télécharge l'image disque sur le lien que tu m'as donné.
(PS : il y a un bug avec les images, impossible de les afficher en miniatures)
    436,8 KB · Affichages: 151
Tu as double-cliqué le InstallMacOSX.dmg contenu dans le dossier El Capitan ? - et c'est le message d'erreur consécutif ?
Ça ne peut pas marcher dans l'environnement de Catalina (OS trop avancé - ou Mac trop récent).
- copie le dmg dans une clé USB > branche la clé à l'iMac > copie le dmg sur ton Bureau > et effectue le double-clic dans l'environnement High Sierra. Ça pourra marcher sans que tu aies à retélécharger tout le bazar.​
Réactions: litobar71
C'est en cours, mais 20mn pour copier 6go sur la clé! :bored:
Je fais les manipulation sitôt fini et je reviens .
J'ai donc copié le dmg téléchargé sur le site d'Apple (pas celui que j'avais déjà mais qui est certainement le même)
Puis depuis l'imac avec High Sierra je l'ai ouvert et cliqué sur le pkg > cela ne fait pas apparaitre l'installateur dans les applications mais lance le programme d'installation :
Est-ce que tu as pressé le bouton : "Installer" ? -->
- il s'agit d'installer ... l'installateur dans les Applications.​
Ah non en effet, je pensais que ça allait lancer l'installation directement sur mon ordinateur. J'essaye.
J'ai bien l'installateur dans le dossier Applications maintenant.
Je dois le copier sur la clé ? Ou créer une clé bootable ?
Branche ta clé au Mac. Passe la commande :
diskutil list
  • et poste le tableau des disques => que je voie la clé. Je pourrais te passer la commande de configuration.
J'ai effacé le contenu de la clé.
Voici le retour :
iMac-CHAMBRE:~ hugues$ diskutil list
   2:                  Apple_HFS Macintosh HD            999.3 GB   disk0s2
/dev/disk1 (external, physical):
   0:     FDisk_partition_scheme                        *15.6 GB    disk1
   1:                  Apple_HFS CLE JULIEN              15.6 GB    disk1s1
Passe la commande (copier-coller) :
diskutil eraseDisk jhfs+ CLE gpt disk1 ; diskutil list disk1
  • la commande reparamètre la clé : table GPT > format jhfs+ > volume CLE ; puis affiche la nouvelle configuration de la clé
Poste le retour.
Note : la table de partition (qui décrit les partitions du disque) est une MBR (type Windows - désignée ici par FDisk_partition_ scheme). Pour une clé démarrable > il faut une GPT (GUID_Partition_Table).
Voici le retour :
iMac-CHAMBRE:~ hugues$ diskutil eraseDisk jhfs+ CLE gpt disk1 ; diskutil list disk1
Started erase on disk1
Unmounting disk
Creating the partition map
Waiting for partitions to activate
Formatting disk1s2 as Mac OS Extended (Journaled) with name CLE
Initialized /dev/rdisk1s2 as a 14 GB case-insensitive HFS Plus volume with a 8192k journal
Mounting disk
Finished erase on disk1
   0:      GUID_partition_scheme                        *15.6 GB    disk1
   2:                  Apple_HFS CLE                     15.3 GB    disk1s2
Clé bien paramétrée. Passe la commande (copier-coller - copie-la bien jusqu'au --nointeraction final) :
sudo /App*/Install*\ Cap*/C*/R*/createinstallmedia --volume /Vol*/CLE --applicationpath /App*/Install*\ Cap* --nointeraction
  • à validation > une demande de password s'affiche (commande sudo) => tape ton mot-de-passe de session admin en aveugle - aucun caractère ne se montrant à la frappe - et revalide
  • la commande configure le volume CLE en volume d'installation démarrable d'El Capitan. CLE va être reformaté > renommé Install OS X El Capitan > cloné de l'installateur (6,2 Go) > des fichiers de démarrage de l'OS d'installation inclus créés > enfin un chemin de démarrage inscrit sur l'en-tête du volume. Ce qui va prendre plusieurs minutes.
Poste le retour quand tu auras récupéré l'invite de commande : iMac-CHAMBRE:~ hugues$ en signal de fin.
Enfin ! J'ai cru qu'il y avait un bug !
Voici le retour :
iMac-CHAMBRE:~ hugues$ sudo /App*/Install*\ Cap*/C*/R*/createinstallmedia --volume /Vol*/CLE --applicationpath /App*/Install*\ Cap* --nointeraction
Password:
Erasing Disk: 0%... 10%... 20%... 30%...100%...
Copying installer files to disk...
Copy complete.
Making disk bootable...
Copying boot files...
Copy complete.
Done.
