10.12 Sierra Impossible de réinstaller macOS Sierra _ Pb via OS X Base System
# diskutil list
   2:                  Apple_HFS Untitled                999.3 GB   disk0s2
/dev/disk1 (internal):
   0:      GUID_partition_scheme                         24.0 GB    disk1
   1:                        EFI EFI                     314.6 MB   disk1s1
   2:                  Apple_HFS Untitled                23.6 GB    disk1s2
/dev/disk2 (disk image):
   0:      GUID_partition_scheme                        +2.1 GB     disk2
   1:                  Apple_HFS OS X Base System        2.0 GB     disk2s1
/dev/disk4 (disk image):
   0:                            untitled               +5.2 MB     disk4
/dev/disk5 (external, physical):
   0:      GUID_partition_scheme                        *500.1 GB   disk5
   1:                        EFI EFI                     209.7 MB   disk5s1
   2:                  Apple_HFS Clone                   499.7 GB   disk5s2
/dev/disk6 (disk image):
/dev/disk7 (disk image):
/dev/disk8 (disk image):
/dev/disk9 (disk image):
   0:                            untitled               +2.1 MB     disk9
/dev/disk10 (disk image):
   0:                            untitled               +524.3 KB   disk10
/dev/disk11 (disk image):
   0:                            untitled               +524.3 KB   disk11
/dev/disk12 (disk image):
   0:                            untitled               +12.6 MB    disk12
/dev/disk13 (disk image):
   0:                            untitled               +4.2 MB     disk13
/dev/disk14 (disk image):
   0:                            untitled               +1.0 MB     disk14
/dev/disk15 (disk image):
   0:                            untitled               +2.1 MB     disk15
/dev/disk16 (disk image):
   0:                            untitled               +524.3 KB   disk16
/dev/disk17 (disk image):
   0:                            untitled               +524.3 KB   disk17
/dev/disk18 (disk image):
   0:                            untitled               +1.0 MB     disk18
/dev/disk19 (disk image):
   0:                            untitled               +6.3 MB     disk19
/dev/disk20 (disk image):
   0:                            untitled               +6.3 MB     disk20
/dev/disk21 (disk image):
   0:                            untitled               +524.3 KB   disk21
/dev/disk22 (disk image):
   0:                            untitled               +2.1 MB     disk22
-bash-3.2#
Suppression réussie. À présent > recréation du Fusion Drive en 2 étapes.
1ère étape : le "sous-bassement" --> passe la commande :
diskutil cs createLVG Fusion disk1s2 disk0s2
  • la commande inscrit un magasin de stockage Physical Volume dans les 2 partitions principales > et crée un Conteneur CoreStorage qui les importe.
Poste l'affichage retourné par la commande.
je pense que la 1ere étape est good :
-bash-3.2# diskutil cs createLVG Fusion disk1s2 disk0s2
Started CoreStorage operation
Unmounting disk1s2
Touching partition type on disk1s2
Adding disk1s2 to Logical Volume Group
Unmounting disk0s2
Touching partition type on disk0s2
Adding disk0s2 to Logical Volume Group
Creating Core Storage Logical Volume Group
Switching disk1s2 to Core Storage
Switching disk0s2 to Core Storage
Waiting for Logical Volume Group to appear
Discovered new Logical Volume Group "20DADCAB-906C-4032-91F0-D1CB9F10F705"
Core Storage LVG UUID: 20DADCAB-906C-4032-91F0-D1CB9F10F705
Finished CoreStorage operation
-bash-3.2#
En effet.
2è étape : les "superstructures" --> passe la commande :
diskutil cs createLV 20DADCAB-906C-4032-91F0-D1CB9F10F705 jhfs+ "Macintosh HD" 100%
  • le plus commode encore est que tu viennes la copier ici avant de la coller dans le Terminal
  • la commande crée la paire : Famille de Volumes Logiques (pilotage) > Volume Logique (disque virtuel) + inscrit un système de fichiers jhfs+ sur le Volume Logique > montant un volume standard Macintosh HD
Poste l'affichage retourné et le retour d'un nouveau :
diskutil list
2e étape réalisée avec succés :
-bash-3.2# diskutil cs createLV 20DADCAB-906C-4032-91F0-D1CB9F10F705 jhfs+ "Macintosh HD" 100%
Waiting for Logical Volume to appear
Formatting file system for Logical Volume
Initialized /dev/rdisk3 as a 952 GB case-insensitive HFS Plus volume with a 81920k journal
Mounting disk
Core Storage LV UUID: F4DBDF30-8B57-4094-B66C-2DC12F184D4A
Core Storage disk: disk3
-bash-3.2
# diskutil list
   2:          Apple_CoreStorage Fusion                  999.3 GB   disk0s2
   3:                 Apple_Boot Boot OS X               134.2 MB   disk0s3
   2:          Apple_CoreStorage Fusion                  23.6 GB    disk1s2
   3:                 Apple_Boot Boot OS X               134.2 MB   disk1s3
/dev/disk3 (internal, virtual):
   0:                  Apple_HFS Macintosh HD           +1.0 TB     disk3
                                 Logical Volume on disk1s2, disk0s2
                                 Unencrypted Fusion Drive
le disk3 fusion drive a été créé !
la suite du diskutil list :
-bash-3.2#
Parfait : Fusion Drive recréé.
Et pour finir --> finalisation du sauvetage (ce qui va prendre du temps) -->
  • a) dans la fenêtre des 4 Utilitaires macOS > lance l'option : "Ré-installer macOS" --> à destination du volume Macintosh HD vide > ce qui va donner une installation propre.
  • b) en fin d'installation > une page te propose de récupérer des données --> coche la case : "À partir d'un autre Mac ou d'une sauvegarde Time Machine" > et choisis le volume Clone en "source". L'«Assistant de migration» va te proposer de récupérer ton compte > des applications > des réglages --> n'exclus rien et lance. S'il te propose en chemin une mise-à-jour d'iTunes --> refuse > car ça plante la migration. Une récupération par l'«Assistant de migration» est toujours très lente > avec un débit de copie très variable.
=> tu n'auras qu'à dire si tu as pu ré-ouvrir ta session à la fin.
Aïe aïe aïe! Tout ne pouvait trop bien fonctionner.
À mon retour (après la nuit d’install), une fenêtre affichait :
« MacOS n’a pas pu être installé sur votre ordinateur
Requête non valide
Quittez le programme d’installation pour redémarrer votre ordinateur puis réessayez. »
J’ai donc cliqué le bouton « redémarrer » sous ce message.
Après un redémarrage (en mode recovery semble-t-il), la fenêtre s’est ré affichée avec le message :
Les ressources du programme d’installation sont introuvables.
Alors passe la commande :
ls /Volumes/Mac*
  • qui liste les éléments présents dans le volume Macintosh HD
Poste ce qui est retourné.
macOS Install Data est le dossier contenant les ressources d'installation de High Sierra.
Passe la commande :
df -H /Volumes/Mac*
  • qui mesure l'occupation du volume Macintosh HD
Poste le tableau. C'est pour vérifier si les 5,2 Go de ressources d'installation se sont bien téléchargées.
cela semble OK :
Filesystem   Size   Used  Avail Capacity iused     ifree %iused  Mounted on
/dev/disk3   1.0T   6.2G   1.0T     1% 1525818 247825732    1%   /Volumes/Macintosh HD
Le téléchargement a bien abouti. Je ne comprends pas pourquoi l'installation ne s'est pas lancée.
Je te propose de supprimer le dossier d'installation > puis te retenter une installation.
Passe la commande :
diskutil eraseVolume jhfs+ "Macintosh HD" disk3
  • la commande reformate le volume terminal Macintosh HD
Relance ensuite l'option : "Réinstaller macOS" --> à destination du volume Macintosh HD. Tu n'auras qu'à dire si l'installation s'est bien effectuée > ou s'il y a eu de nouveau un blocage.
J’ai redémarré (CMD+R), ça a fait automatiquement un redémarrage Internet et ça ne me propose que de réinstaller OS X.
Si tu démarres par ⌘R (commande qui déclenche en principe un démarrage sur l'OS de secours du disque) > vu qu'il n'y a pas de partition de secours sur le HDD actuellement --> la commande est reconvertie à ⌘⌥⇧R qui fait démarrer par internet > télécharger en RAM un OS de secours correspondant à l'OS d'usine du Mac et démarrer le Mac sur cet OS de secours d'usine.
C'est en démarrant spécifiquement par ⌘⌥R > que tu déclenches un démarrage par internet alternatif : téléchargement en RAM d'un OS de secours 10.13 > et démarrage du Mac sur cet OS de secours correspondant à High Sierra.
Tu peux donc engager ce 2è démarrage et tenter l'option : "Réinstaller macOS" à destination de Macintosh HD --> à toi de dire si l'installation de High Sierra se sera bien effectuée > avec récupération des données par l'«Assistant de migration» à partir du volume Clone à la fin.
En cas d'échec > après un nouveau reformatage du volume --> il sera possible de réinstaller l'OS d'usine (sans récupération de données provisoirement) > et si l'installation s'effectue bien --> de faire les mises à niveau à El Capitan 10.11 > puis High Sierra 10.13 (via un installateur complet) --> et si ça marche > avec récupération des données de Clone à la fin.
Finalement j’ai opté pour réinstaller OS X El Capitan et ça a marché!!!
Je vais faire l’upgrade High sierra.
Tant pis pour les données, ça va me permettre de refaire une install bien propre.
Encore merci beaucoup, je fais signe pour la suite (bonne ou mauvaise).
Une fois revenu à High Sierra --> tu pourras utiliser l'«Assistant de migration» (Applications > Utilitaires) pour récupérer les données du volume Clone.
