Last login: Thu Oct 4 14:43:31 on ttys000
macbook-air-de-maxime:~ Max$ diskutil list
#: TYPE NAME SIZE IDENTIFIER
1: EFI EFI 209.7 MB disk0s1
2: Apple_APFS Container disk1 121.1 GB disk0s2
/dev/disk1 (synthesized):
0: APFS Container Scheme - +121.1 GB disk1
Physical Store disk0s2
1: APFS Volume Macintosh HD 73.6 GB disk1s1
2: APFS Volume Preboot 20.2 MB disk1s2
3: APFS Volume Recovery 517.8 MB disk1s3
4: APFS Volume VM 2.1 GB disk1s4
0: FDisk_partition_scheme *16.0 GB disk2
1: Windows_FAT_32 MASKIME 16.0 GB disk2s1
0: FDisk_partition_scheme *1.0 TB disk3
1: DOS_FAT_32 MAX 1.0 TB disk3s1
macbook-air-de-maxime:~ Max$ df -H /
Filesystem Size Used Avail Capacity iused ifree %iused Mounted on
/dev/disk1s1 121G 74G 45G 63% 1159150 9223372036853616657 0% /
macbook-air-de-maxime:~ Max$ sudo find -x / -d 1 -regex '.*[^\.\].*' -exec sudo du -shx {} +
Password:
find: /private/var/db/ConfigurationProfiles/Store: Operation not permitted
find: /private/var/folders/zz/zyxvpxvq6csfxvn_n00000y800007k/0/com.apple.nsurlsessiond: Operation not permitted
find: /private/var/folders/cy/hrvwybs97771vl0973r1kflh0000gn/0/SafariFamily: Operation not permitted
find: /private/var/folders/cy/hrvwybs97771vl0973r1kflh0000gn/0/com.apple.LaunchServices.dv: Operation not permitted
find: /private/var/folders/cy/hrvwybs97771vl0973r1kflh0000gn/0/com.apple.nsurlsessiond: Operation not permitted
find: /private/var/folders/cy/hrvwybs97771vl0973r1kflh0000gn/0/com.apple.routined: Operation not permitted
0B /.HFS+ Private Directory Data
1,0K /home
469M /usr
439M /.Spotlight-V100
1,0K /net
12K /.DS_Store
0B /.PKInstallSandboxManager
0B /.PKInstallSandboxManager-SystemSoftware
2,6M /bin
4,0K /installer.failurerequests
0B /Network
1,2M /sbin
0B /.file
0B /etc
0B /var
4,1G /Library
0B /.Trashes
5,9G /System
1,0G /vm
348K /.fseventsd
du: /private/var/db/ConfigurationProfiles/Store: Operation not permitted
du: /private/var/folders/zz/zyxvpxvq6csfxvn_n00000y800007k/0/com.apple.nsurlsessiond: Operation not permitted
du: /private/var/folders/cy/hrvwybs97771vl0973r1kflh0000gn/0/SafariFamily: Operation not permitted
du: /private/var/folders/cy/hrvwybs97771vl0973r1kflh0000gn/0/com.apple.LaunchServices.dv: Operation not permitted
du: /private/var/folders/cy/hrvwybs97771vl0973r1kflh0000gn/0/com.apple.nsurlsessiond: Operation not permitted
du: /private/var/folders/cy/hrvwybs97771vl0973r1kflh0000gn/0/com.apple.routined: Operation not permitted
3,8G /private
18M /.DocumentRevisions-V100
0B /.vol
29G /Users
22G /Applications
5,0K /dev
72K /Volumes
0B /tmp
0B /cores
macbook-air-de-maxime:~ Max$ tmutil listlocalsnapshots /
