iMac Localisation volume de démarrage sur Imac
indimages
9 Février 2018
117
63
J'ai entièrement réinstallé mac OS sur mon Imac 27 (fin 2015) avec un fusion drive.
Mais soucis: je n'arrive pas à voir si le système demarre bien sur le bon disque ssd.
Voila les infos :
   2:          Apple_CoreStorage Fusion                  121.0 GB   disk0s2
   3:                 Apple_Boot Boot OS X               134.2 MB   disk0s3
   0:      GUID_partition_scheme                        *3.0 TB     disk1
   2:          Apple_CoreStorage Fusion                  388.6 GB   disk1s2
   3:                 Apple_Boot Boot OS X               134.2 MB   disk1s3
   4:                 Apple_APFS Container disk3         1.8 TB     disk1s4
   5:          Apple_CoreStorage Fusion                  773.7 GB   disk1s5
   6:                 Apple_Boot Recovery HD             650.0 MB   disk1s6
/dev/disk2 (internal, virtual):
   0:                  Apple_HFS FREDERIQUE             +1.3 TB     disk2
                                 Logical Volume on disk0s2, disk1s2, ...
                                 A678F3D2-3BAB-42D3-BCDC-41D5122C97FE
                                 Unencrypted Fusion Drive
/dev/disk3 (synthesized):
   0:      APFS Container Scheme -                      +1.8 TB     disk3
                                 Physical Store disk1s4
   1:                APFS Volume Macintosh HD            217.8 GB   disk3s1
   2:                APFS Volume Preboot                 47.6 MB    disk3s2
   3:                APFS Volume Recovery                516.9 MB   disk3s3
   4:                APFS Volume VM                      17.2 GB    disk3s4
/dev/disk4 (external, physical):
   0:     FDisk_partition_scheme                        *1.0 TB     disk4
   1:                 DOS_FAT_32 PIERRE 2                1.0 TB     disk4s1
/dev/disk6 (external, physical):
   0:      GUID_partition_scheme                        *2.0 TB     disk6
   1:                        EFI EFI                     209.7 MB   disk6s1
   2:                  Apple_HFS Sauvegarde1             2.0 TB     disk6s2
et aussi les infos :
   Device Identifier:         disk3s1
   Device Node:               /dev/disk3s1
   Whole:                     No
   Part of Whole:             disk3
   Volume Name:               Macintosh HD
   Mounted:                   Yes
   Mount Point:               /
   Partition Type:            41504653-0000-11AA-AA11-00306543ECAC
   File System Personality:   APFS
   Type (Bundle):             apfs
   Name (User Visible):       APFS
   Owners:                    Enabled
   OS Can Be Installed:       Yes
   Booter Disk:               disk3s2
   Recovery Disk:             disk3s3
   Media Type:                Generic
   Protocol:                  SATA
   SMART Status:              Verified
   Volume UUID:               3915787B-E43F-4E9A-AB21-4A41BCC515AF
   Disk / Partition UUID:     3915787B-E43F-4E9A-AB21-4A41BCC515AF
   Disk Size:                 1.8 TB (1836493012992 Bytes) (exactly 3586900416 512-Byte-Units)
   Device Block Size:         4096 Bytes
   Volume Total Space:        1.8 TB (1836493012992 Bytes) (exactly 3586900416 512-Byte-Units)
   Volume Used Space:         237.4 GB (237408686080 Bytes) (exactly 463688840 512-Byte-Units) (12.9%)
   Volume Free Space:         1.6 TB (1599084326912 Bytes) (exactly 3123211576 512-Byte-Units) (87.1%)
   Allocation Block Size:     4096 Bytes
   Read-Only Media:           No
   Read-Only Volume:          No
   Device Location:           Internal
   Removable Media:           Fixed
   Solid State:               No
   Hardware AES Support:      No
Bonjour indimages
Le volume de démarrage est le volume apfs Macintosh HD. Si on va à sa recherche dans le tableau des disques --> il apparaît en tant que membre de ce Conteneur apfs disk3 :
  • sachant qu'un Conteneur apfs est un espace-disque virtualisé à partir d'une partition primaire de disque (ou de plus d'un disque si l'on a affaire à un Fusion Drive apfs introduit par l'OS Mojave) --> on lit dans le haut du tableau ci-dessus que le Conteneur disk3 est virtualisé à partir du magasin de stockage physique Physical Store de la partition disk1s4.
On trouve cette partition disk1s4 localisée sur ce disque-ci du tableau des disques -->
  • au rang n°4 de ce tableau de partitionnement particulièrement complexe (et rare) --> on trouve en effet la partition apfs primaire à partir de laquelle se trouve virtualisé l'espace-disque secondaire du Conteneur disk3 -->
  • à ta question initiale :
  • la réponse sans ambages est : c'est uniquement sur une partition n°4 de ton HDD (disque rotatif de 3 To) --> que se trouve installé le système de stockage apfs dont dépend ton volume de démarrage Macintosh HD. Il ne bénéficie donc absolument pas des services du SSD de 121 Go qui existe en parallèle. La vitesse exécutive doit donc être limitée aux 100 Mo/s permis par ce disque de 3 To tournant à 7200 tr/mn.
Je suis bien loin d'avoir épuisé le sujet présent > car ton Mac présente un dispositif matériel rare > qui recevait d'usine de la part d'Apple une configuration logique elle-même très rare et d'une grande complexité.
Je me suis abstenu dans ce 1er message d'entrer dans l'analyse de ce dispositif sophistiqué.
Merci pour toutes ces réponses exhaustives. Serait-il possible en ce cas de m'aider, étape par étape, à réinstaller le système sur le ssd ? J'en suis incapable tout seul.
Toutes mes données sont sauvegardées sur un Time machine et je veux bien tenter la chose.
Passe la commande :
df -H
  • qui mesure l'occupation des volumes montés
Poste le tableau --> que je voie combien il y a dans les volumes qui dépendent des 2 disques internes.
Voilà ce que ça donne :
df -H
Filesystem                                             Size   Used  Avail Capacity iused               ifree %iused  Mounted on
/dev/disk3s1                                           1.8T   449G   1.4T    25% 1159113 9223372036853616694    0%   /
devfs                                                  210k   210k     0B   100%     712                   0  100%   /dev
/dev/disk3s4                                           1.8T    17G   1.4T     2%       1 9223372036854775806    0%   /private/var/vm
/dev/disk2                                             1.3T   772M   1.3T     1%      83          4294967196    0%   /Volumes/FREDERIQUE
map -hosts                                               0B     0B     0B   100%       0                   0  100%   /net
map auto_home                                            0B     0B     0B   100%       0                   0  100%   /home
/dev/disk6s2                                           2.0T   1.4T   603G    70%  361547          4294605732    0%   /Volumes/Sauvegarde1
/dev/disk4s1                                           1.0T   856G   144G    86%       0                   0  100%   /Volumes/PIERRE 2
/dev/disk5s2                                           1.2T    49G   1.2T     5%  817442          4294149837    0%   /Volumes/Time machine
/dev/disk5s3                                           800G   184G   615G    24% 1858986          4293108293    0%   /Volumes/Time machine2
com.apple.TimeMachine.2019-01-25-182750@/dev/disk3s1   1.8T   448G   1.4T    25% 1208365 9223372036853567442    0%   /Volumes/com.apple.TimeMachine.localsnapshots/Backups.backupdb/imac pro/2019-01-25-182750/Macintosh HD
C'est sans doute plus clair comme ça : j'ai ejecté deux disques externe. Il y en a un autre mais c'est un time machine avec deux partitions que je ne peux pas retirer parce que je fais une sauvegarde
/dev/disk3s1                                           1.8T   449G   1.4T    25% 1159341 9223372036853616466    0%   /
/dev/disk5s2                                           1.2T    49G   1.2T     5%  817738          4294149541    0%   /Volumes/Time machine
Hé ! le volume FREDERIQUE est vide (772 Mo). On peut le supprimer déjà et récupérer son espace.
- je vais faire une pause et je reviendrai dans ton fil tout à l'heure pour des explications.​
Oui il est vide c'est normal. Je comptais mettre des fichiers dedans mais j'attends que tout soit réparé. Je partitionnerai quand tout sera OK. On peut faire ce qu'on veut avec.
Je reviens sur la configuration de tes 2 disques -->
  • tu remarques qu'il y a 3 partitions de type Apple_CoreStorage : la disk0s2 (121 Go) du SSD & les disk1s2 (388 Go) + disk1s5 (773 Go) du HDD. L'actuelle partition Apple_APFS disk1s4 (1,8 To) du HDD a été créée par rétrécissement de la partition disk1s2 du HDD. Donc la partition originelle disk1s2 du HDD faisait près de 2,2 To. Voici donc quel était le dispositif primitif tel que créé d'usine par Apple :
   2:          Apple_CoreStorage Fusion                  2.2 TB     disk1s2
   4:          Apple_CoreStorage Fusion                  773.7 GB   disk1s4
   5:                 Apple_Boot Recovery HD             650.0 MB   disk1s5
  • tu remarques que chaque partition de type Apple_CoreStorage se trouve flanquée d'une partition subalterne qui a les fonctions de « booter » : prédémarreur du Volume Logique (espace-disque virtuel commun) que chaque partition contribue à exporter. Les 2 premières partitions à fonction de « booter » ont un volume Boot OS X de 134 Mo > la dernière un volume Recovery HD de 650 Mo > car ce dernier volume joue double jeu : rôle de « booter » de la dernière partition Apple_CoreStorage + réceptacle de l'OS de secours démarrable via ⌘R (ce qui explique la taille plus grande de cette partition).
Pourquoi un tel bi-partionnement du HDD > càd. pourquoi un Fusion Drive de type CoreStorage à 3 partitions en tout ? - c'est parce que tu as un HDD de 3 To > et qu'à l'époque de sortie de ton Mac il était toujours question de pouvoir (éventuellement) installer Windows-7.
Or Windows-7 est un OS qui démarre en mode dit "Legacy" : via une émulation de BIOS créée à la volée par l'EFI > BIOS lisant sur le bloc 0 (1er bloc) du disque de résidence de la partition BOOTCAMP --> une table de partition HMBR (Hybrid_MBR) décrivant au plus 3 partitions du disque en mode MBR > et accédant par là au démarreur bootmgr Legacy de W-7 dans le volume BOOTCAMP. Donc la table de partition utilisée pour booter Windows-7 était une doublure alternative de la table de partition GPT principale (résidant sur les 32 blocs suivants du disque).
Or une table de partition MBR (comme la HMBR) ne peut cartographier avec ses descripteurs de partitions que 2,2 To au plus de blocs et rien au-delà. D'où l'astuce Apple pour un iMac associant en Fusion Drive un SSD de 121 Go et un HDD de 3 To > de subdiviser le HDD en 2 partitions de 2,2 To + 800 Go > les 3 associées ensemble dans un système de stockage CoreStorage. Dans un tel dispositif en effet > tout repartitionnement demandé s'effectue toujours exclusivement à partir de la seule partition de tête du HDD : celle des 2,2 To. Tu en as la preuve avec la partition Apple_APFS qui a été créée manifestement à partir de la partition CoreStorage de tête du HDD. Ses 1,8 To additionnés à la taille de près de 400 Go de la partition CoreStorage donnent bien les 2,2 To.
C'est une partition BOOCAMP que tu aurais pu créer à la place de ton actuelle partition Apple_APFS : créée par rétrécissement d'une partition de tête du HDD allant jusqu'à la limite des 2,2 To de blocs du HDD et pas au-delà > toute partition BOOTCAMP se trouvait assurée de rester toujours dans la limite de ce que la table HMBR du HDD pouvait décrire --> ce qui fait que le Windows-7 installé dans le volume BOOTCAMP était toujours bootable.
Il est possible dans l'état de lieux de remodeler le partitionnement de ton HDD > et par des procédés de clonage internes au Mac de conserver ton OS Mojave démarrable avec tes données. Il va falloir examiner la question ensemble. Ce long message de ma part avait une fonction purement explicative des prouesses d'ingéniérie qui ont donné la configuration logique des disques de ton iMac.
Merci, c'est une explication claire, je comprends mieux la complexité et le fait que ce dispositif a été mis en place à l'époque pour pouvoir installer des partition windows,via bootcamp;, entre autre. Alors remodelons comme tu le dis. Par contre on peut supprimer toutes les données s'il le faut car j'ai tout sauvegardé.
Le volume actuel FREDERIQUE qui est vide > est le volume logique exporté en commun par les 3 partitions CoreStorage du Fusion Drive. Autant dire que le Fusion Drive actuel ne te sert de rien. Je te propose donc de le supprimer dans un 1er temps > ce qui va libérer les 2 disques de leur association improductive > et créer 3 volumes Untitled sur les 3 partitions CoreStorage reformatées en jhfs+.
La partition de type Apple_APFS et l'espace-disque du Conteneur virtualisé (avec le volume Macintosh HD démarré) --> ne seront absolument pas impliqués dans cette suppression.
Juste une question avant cela --> tu n'as pas l'intention (je présume) de jamais vouloir réinstaller Windows-7 dans une partition BOOTCAMP (j'ai bien dit : Windows-7 - l'OS Legacy) ?
Alors passe la commande :
diskutil cs list
  • qui affiche le tableau détaillé du CoreStorage
Poste ce tableau.
Voici
CoreStorage logical volume groups (1 found)
+-- Logical Volume Group 28007678-1F9C-41B9-B198-A69FE0A79592
    Status:       Online
    Size:         1283279065088 B (1.3 TB)
    Free Space:   24576 B (24.6 KB)
    +-< Physical Volume 2574449B-C6D8-4512-A30A-B6354BD6856B
    |   Index:    0
    |   Disk:     disk0s2
    |   Status:   Online
    |   Size:     120988852224 B (121.0 GB)
    +-< Physical Volume CCBC699E-DE50-4E78-BA87-B6226DEDFF79
    |   Index:    1
    |   Disk:     disk1s2
    |   Status:   Online
    |   Size:     388589514752 B (388.6 GB)
    +-< Physical Volume DB297FDC-8CBA-4166-9B82-745922D587EF
    |   Index:    2
    |   Disk:     disk1s5
    |   Status:   Online
    |   Size:     773700698112 B (773.7 GB)
    +-> Logical Volume Family CABCA2C4-8241-44D3-860F-B26D64B86BB9
        Encryption Type:         None
        +-> Logical Volume A678F3D2-3BAB-42D3-BCDC-41D5122C97FE
            Disk:                  disk2
            Status:                Online
            Size (Total):          1275673575424 B (1.3 TB)
            Revertible:            No
            LV Name:               FREDERIQUE
            Volume Name:           FREDERIQUE
            Content Hint:          Apple_HFS
            LVG Type:              Fusion, Sparse
Passe la commande (copier-coller) :
diskutil coreStorage deleteLVG 28007678-1F9C-41B9-B198-A69FE0A79592 ; diskutil list
  • la commande supprime le CoreStorage (et par là le Fusion Drive) > ce qui reformate les 3 partitions en remontant 3 volumes Untitled séparés > puis affiche le tableau des disques
Poste l'ensemble de l'affichage retourné.
pierrerich$ diskutil coreStorage deleteLVG 28007678-1F9C-41B9-B198-A69FE0A79592 ; diskutil list
Started CoreStorage operation
Unmounting Logical Volumes
The volume "FREDERIQUE" on disk2 couldn't be unmounted
Error: -69888: Couldn't unmount disk
   1:                APFS Volume Macintosh HD            453.9 GB   disk3s1
Le volume FREDERIQUE n'a pas pu être démonté --> ce qui a bloqué la commande.
Passe la commande :
diskutil umountDisk force disk2
  • qui démonte le volume logique
Poste le retour.
Bon. Repasse alors la commande :
  • et poste le retour (ça devrait marcher cette fois).
