Macbook Pro 2012 panique tout seul
guideb
31 Août 2019
30
36
je viens vers vous car j'aimerais comprendre qu'est ce qui cloche dans mon macbook pro de 2012 2.5ghz 16go ram et 480go ssd (rempli à 80%). Lorsque je le ferme, il vide la batterie. je dois le rebrancher pour pouvoir l'allumer et voici le rapport qu'il me donne :
Sleep Wake failure in EFI
Failure code:: 0x01710875 0x0000001f
Please IGNORE the below stackshot
Date/Time: 2023-02-12 17:57:06 +0100
OS Version: ??? ??? (Build ???)
Architecture: x86_64
Report Version: 29
Data Source: Stackshots
Shared Cache: 0x93c2000 A012C025-7DAC-3FE0-893E-6C3F20336957
Event: Sleep Wake Failure
Duration: 0.00s
Steps: 1
Time Awake Since Boot: 24s
Process: swd [344]
Footprint: 400 KB
Start time: 2023-02-12 17:57:06 +0100
End time: 2023-02-12 17:57:06 +0100
Num samples: 1 (1)
Thread 0x7ff 1 sample (1) priority 4 (base 4)
<thread QoS background (requested background), thread darwinbg, process darwinbg, IO tier 2>
1 start + 1 (libdyld.dylib + 109769) [0x7fff702bbcc9] 1
1 ??? [0x1081d5454] 1
1 ??? [0x1081d51dd] 1
1 __stack_snapshot_with_config + 10 (libsystem_kernel.dylib + 135846) [0x7fff7041d2a6] 1
*1 ??? [0xffffff80002c2206] 1
*1 ??? [0xffffff8000983517] 1
*1 ??? [0xffffff800089bf91] 1
*1 ??? [0xffffff80002e59b7] (running) 1
Binary Images:
0x7fff702a1000 - 0x7fff702d7fff libdyld.dylib (750.7) <AB99C9EE-7127-3451-89AB-339F8F2CEE61> /usr/lib/system/libdyld.dylib
0x7fff703fc000 - 0x7fff70428fff libsystem_kernel.dylib (6153.141.66) <FF081F3A-F653-3F8F-9E64-9F34792EEDB3> /usr/lib/system/libsystem_kernel.dylib
Model: MacBookPro9,2, BootROM 429.0.0.0.0, 2 processors, Dual-Core Intel Core i5, 2,5 GHz, 16 GB, SMC 2.2f44
Graphics: kHW_IntelHD4000Item, Intel HD Graphics 4000, spdisplays_builtin
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x859B, 0x43543130323436344246313630422E433136
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x859B, 0x435438473353313630424D2E4D3136464544
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xF5), Broadcom BCM43xx 1.0 (7.21.190.33 AirPortDriverBrcm4360-1601.1)
Bluetooth: Version 7.0.6f8, 3 services, 18 devices, 1 incoming serial ports
Serial ATA Device: Samsung SSD 850 EVO 500GB, 500,11 GB
Serial ATA Device: CT240BX200SSD1, 240,06 GB
USB Device: USB 3.0 Bus
USB Device: USB 2.0 Bus
USB Device: Hub
USB Device: Hub
USB Device: Apple Internal Keyboard / Trackpad
USB Device: IR Receiver
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: Hub
USB Device: FaceTime HD Camera (Built-in)
Thunderbolt Bus: MacBook Pro, Apple Inc., 25.1
J'ai paramétré pour qu'il ne sorte pas de veille "lors de l'acces reseau" et j'ai aussi remarqué que le hibernate mode etait sur OFF. Ma batterie n'est pas d'origine, je me demande s'il ne se coupe pas à cause de cela bien que j'ai fais les reset habituels "PRAM et NVRAM"..
Pensez vous qu'il s'agit d'un problème matériel ?
Réglages d’alimentation du système :
Alimentation secteur :
Minuterie de suspension d’activité du système (minutes) : 29
Minuterie de suspension d’activité du disque (minutes) : 10
Minuterie de suspension d’activité du moniteur (minutes) : 29
Réactivation par un changement de tension : Non
Réactivation par l’ouverture du boîtier : Non
Réactivation par le réseau : Non
AutoPowerOff Delay : 259200
AutoPowerOff Enabled : 0
Source d’alimentation actuelle : Oui
Mise en veille du moniteur par réduction de l’intensité : Oui
Hibernate Mode : 25
High Standby Delay : 5
PrioritizeNetworkReachabilityOverSleep : 0
Standby Battery Threshold : 40
Standby Delay : 5
Standby Enabled : 0
Alimentation par batterie :
Minuterie de suspension d’activité du système (minutes) : 15
Minuterie de suspension d’activité du moniteur (minutes) : 15
AutoPowerOff Delay : 14400
Hibernate Mode : 25
Réduction de la luminosité : Non
Standby Delay : 5
Standby Enabled : 1
Merci pour votre aide !
