Message codé , comment décoder ?
omni
17 Mars 2007
1 249
45
Je reçois parfois des messages qui semblent codés via mail :
Dans l'entête du message j'ai ceci : "--Apple-Mail-6--74967856 Content-Type: text/html; charset=US-ASCII Content-Transfer-Encoding: quoted-printable
P1060285.JPG"
Puis le message donne cela (je ne mets qu'un extrait...) : "/9j/4SScRXhpZgAATU0AKgAAAAgADAEPAAIAAAAKAAAAngEQAAIAAAAJAAAAqAESAAMAAAABAAEA AAESAAMAAAABAAEAAAEaAAUAAAABAAAAsgEbAAUAAAABAAAAugEoAAMAAAABAAIAAAExAAIAAAAQ AAAAwgEyAAIAAAAUAAAA0gE8AAIAAAAQAAAA5gITAAMAAAABAAIAAIdpAAQAAAABAAAA9gAAGUxQ YW5hc29uaWMARE1DLUZaMjAAAABIAAAAAQAAAEgAAAABAABRdWlja1RpbWUgNy42LjQAMjAwOTox MDoxMSAxMjozNjo0MgBNYWMgT1MgWCAxMC41LjgAACCCmgAFAAAAAQAAAnyCnQAFAAAAAQAAAoSI IgADAAAAAQACAACIJwADAAAAAQBQAACQAAAHAAAABDAyMjCQAwACAAAAFAAAAoyQBAACAAAAFAAA AqCRAQAHAAAABAECAwCRAgAFAAAAAQAAArSSBAAKAAAAAQAAArySBQAFAAAAAQAAAsSSBwADAAAA AQAFAACSCAADAAAAAQAAAACSCQADAAAAAQAQAACSCgAFAAAAAQAAAsySfAAHAAAWcAAAAtSgAAAH AAAABDAxMDCgAQADAAAAAQABAACgAgAEAAAAAQAACACgAwAEAAAAAQAABgCiFwADAAAAAQACAACj AAAHAAAAAQMAAACjAQAHAAAAAQEAAACkAQADAAAAAQAAAACkAgADAAAAAQAAAACkAwADAAAAAQAA AACkBAAFAAAAAQAAGUSkBQADAAAAAQFiAACkBgADAAAAAQAAAACkCAADAAAAAQAAAACkCQADAAAA AQAAAACkCgADAAAAAQAAAAAAAAAAAAAACgAABkAAAAAcAAAACjIwMDk6MTA6MTEgMTE6MDc6MTIA MjAwOToxMDoxMSAxMTowNzoxMgAAAAAEAAAAAQAAAAAAAABkAAAAHgAAAAoAAAJNAAAAClBhbmFz b25pYwAAABgAAQADAAEAAAACAAAAAgAHAAQAAAAAAQAQAwADAAEAAAABAAAABwADAAEAAAABAAAA DwABAAIAAAAQAAAAGgADAAEAAAAEAAAAHAADAAEAAAACAAAAHwADAAEAAAAEAAAAIAADAAEAAAAC AAAAIQAHADIVAACyBAAAIgADAAEAAAAAAAAAIwADAAEAAAAAAAAAJAADAAEAAAAAAAAAJQAHABAA AADkGQAAJgAHAAQAAAAwMTAwJwADAAEAAAAAAAAAKAADAAEAAAABAAAAKQAEAAEAAABRCAAAKgAD AAEAAAAAAAAAKwAEAAEAAAAAAAAALAADAAEAAAAAAAAALQADAAEAAAAAAAAALgADAAEAAAABAAAA LwADAAEAAAABAAAARFYBAkVQAQDwP0RCpgPwP0FGbgBgR4iAYkcRgWRHAABmRwAATkc2AHJHAQB0 RwAAekcdAHxH/P9+R/X/QEdHAkJHQRpMRyOEXEeoAHZHoAB4R0AAUkeBAVZHdgBUR40AjEcAAI5H AQGKR0MakEcBAJJHAQCURwEAlkcAAPA/U1Q+AKRGAACmRgAAqEYAAKpGAACsRgAArkYAALBGAACy "
Je précise que c'est dans le corps du message et non une pièce jointe...
Y-a-til moyen de décoder ?? ?
merci à vous de vos lumières
j'y ai bien pensé... Mais comment la retransformer en image alors ?
Encore une fois, ce n'est pas une pièce jointe mais inclu dans le corps du message, du coup je ne sais pas comment m'en sortir...
:heu:
sans certitudes aucunes, j'essayerai de copier l'ensemble du fichier dans un editeur et le sauver sous file.jpg et essayer de l'ouvrir avec apercu...
Un éditeur ????quesaco Merci
ben un editeur, comme son nom l'indique, ça permet d'éditer :D
par exemple, pour éditer du texte, tu utilise certainement textEdit
tu peux d'ailleurs peut-être essayer avec ça..
sinon, pour info, il existe un editeur que je trouve bien pour programmer : Smultron
tu dois pouvoir le trouver facilement et essayer avec si ça marche pas avec textEdit...
J'ai donc copier coller ce "message" codé dans texedit et dans smultron... essayé de mettre différente extension dont JPG... Mais rien à faire = cela ne s'ouvre pas...
ben je sais pas alors...
tu peux pas demander à celui qui t'a envoyé le mail si il a fait un truc spécial (genre mettre la pièce jointe dans le corps du mail) et si il ne peux pas te le réenvoyer correctement?
