10.13 High Sierra Mise jour sécurité 2019-002 Problème
Repasse alors la commande :
df -H
  • et poste le tableau de l'occupation des volumes montés. Il permettra de comparer (quantitativement) Clone et Macintosh HD.
salut macomaniac
-bash-3.2# df -H
Filesystem     Size   Used  Avail Capacity iused      ifree %iused  Mounted on
/dev/disk1s1   2.0G   1.3G   718M    64%   45155 4294922124    0%   /
devfs          206k   206k     0B   100%     696          0  100%   /dev
/dev/disk3     5.2M   512k   4.7M    10%      19 4294967260    0%   /private/var/log
/dev/disk4     524k   147k   377k    29%       6 4294967273    0%   /Volumes
/dev/disk5     524k   147k   377k    29%       7 4294967272    0%   /private/var/tmp
/dev/disk6     524k   160k   365k    31%      12 4294967267    0%   /private/var/run
/dev/disk7     2.1M   143k   2.0M     7%       2 4294967277    0%   /private/tmp
/dev/disk8     524k   147k   377k    29%       3 4294967276    0%   /System/Installation
/dev/disk9     524k   299k   225k    58%      20 4294967259    0%   /private/var/db
/dev/disk10     13M   3.1M   9.5M    25%      58 4294967221    0%   /private/var/folders
/dev/disk11    4.2M   205k   4.0M     5%      21 4294967258    0%   /private/var/root/Library
/dev/disk13    2.1M   143k   2.0M     7%       2 4294967277    0%   /private/var/root/Library/Containers
/dev/disk14    524k   188k   336k    36%      11 4294967268    0%   /Library/Preferences
/dev/disk15    524k   160k   365k    31%       5 4294967274    0%   /Library/Preferences/SystemConfiguration
/dev/disk16    1.0M   180k   868k    18%       6 4294967273    0%   /Library/Keychains
/dev/disk17    6.3M   176k   6.1M     3%       2 4294967277    0%   /private/var/tmp/RecoveryTemp
/dev/disk18    6.3M   176k   6.1M     3%       2 4294967277    0%   /private/var/tmp/OSISPredicateUpdateProductTemp
/dev/disk19    524k   143k   381k    28%       2 4294967277    0%   /private/var/tmp/InstallerCookies
/dev/disk20    2.1M   143k   2.0M     7%       2 4294967277    0%   /Library/Logs/DiagnosticReports
/dev/disk2s2   500G   443G    57G    89% 1002488 4293964791    0%   /Volumes/Clone
/dev/disk0s3   650M   540M   103M    84%      18 4294967261    0%   /Volumes/Image Volume
/dev/disk0s2   999G   388G   611G    39% 1116388 4293850891    0%   /Volumes/Macintosh HD
-bash-3.2#
443 Go dans Clone vs 388 Go dans Macintosh HD --> la consommation de blocs pour l'écriture des fichiers a augmenté nettement dans Clone : +55 Go !
- on peut passer à la suite des opérations si tu es prêt (reformatage > réinstallation > récupération).​
Réactions: Romain46
Passe la commande :
diskutil eraseVolume jhfs+ "Macintosh HD" disk0s2
  • mets "Macintosh HD" avec les "" ; le 0 de disk0s2 est un zéro
  • la commande reformate le volume Macintosh HD (verrouillé en lecture seule)
Poste l'affichage retourné.
Si tu cliques : "Add Website" et si tu renseignes ton mot-de-passe de session (ou un mot-de-passe bidon genre : root) --> est-ce que tu es débloqué ?
- sinon > ne t'embête pas : poste une photo du tableau du Terminal (tu as un bouton : "Transférer un fichier" en bas de cette pafe - à droite du bouton orange : "Poster votre réponse").​
Note : il arrive qu'un contrôle parental s'enclenche - je n'ai jamais su pourquoi - pour le Safari de la session de secours.
quand je clic dessus il me relance la meme page.
En bas de la premiere page y a la boite de dialogue pour ecrire;) est je regarde tes messages sur l'ipad
-bash-3.2# diskutil eraseVolume jhfs+ "Macintosh HD" disk0s2
Started erase on disk0s2 Macintosh HD
Unmounting disk
Erasing
Initialized /dev/rdisk0s2 as a 931 GB case-insensitive HFS Plus volume with a 81920k journal
Mounting disk
Finished erase on disk0s2 Macintosh HD
-bash-3.2#
Le formatage est bien passé. Finalisation du sauvetage à présent (ce qui va prendre du temps) -->
  • a) dans la fenêtre des 4 Utilitaires macOS > lance l'option : "Ré-installer macOS" --> à destination du volume Macintosh HD reformaté > ce qui va donner une installation propre.
  • b) en fin d'installation > une page te propose de récupérer des données --> coche la case : "À partir d'un Mac, d'une sauvegarde Time Machine..." > et choisis le volume Clone en "source". L'«Assistant de migration» va te proposer de récupérer ton compte > des applications > des réglages --> n'exclus rien et lance. S'il te propose en chemin une mise-à-jour d'iTunes --> refuse > car ça plante la migration. Une récupération par l'«Assistant de migration» est toujours très lente > avec un débit de copie très variable.
=> tu n'auras qu'à dire si tu as pu ré-ouvrir ta session à la fin.
Réactions: Romain46
Presse le bouton "Redémarrer" --> est-ce que ça change quelque chose ?
- question : tu n'as pas eu un long délai de téléchargement ? - tu as la fibre ?​
Réactions: Romain46
