10.13 High Sierra Problème d’installation de High Sierra
Ok merci pour toutes ces explications, je vais suivre tes recommandations à la lettre!
-bash-3.2# diskutil info /Volumes/"Macintosh HD 1"
   Device Identifier:        disk22
   Device Node:              /dev/disk22
   Whole:                    Yes
   Part of Whole:            disk22
   Device / Media Name:      APPLE HDD HTS545050A7E362
   Volume Name:              Macintosh HD
   Mounted:                  Yes
   Mount Point:              /Volumes/Macintosh HD 1
   Content (IOContent):      Apple_HFS
   File System Personality:  Journaled HFS+
   Type (Bundle):            hfs
   Name (User Visible):      Mac OS Extended (Journaled)
   Journal:                  Journal size 40960 KB at offset 0x1a387000
   OS Can Be Installed:      Yes
   Booter Disk:              disk0s3
   Recovery Disk:            disk0s3
   Protocol:                 SATA
   Volume UUID:              EB10782F-0F73-3203-AD06-9A3ADA6A5960
   Disk / Partition UUID:    D471B905-8B0B-48EB-9CA9-BF092127C063
   Disk Size:                498.9 GB (498887294976 Bytes) (exactly 974389248 512-Byte-Units)
   Device Block Size:        512 Bytes
   Volume Total Space:       498.9 GB (498887294976 Bytes) (exactly 974389248 512-Byte-Units)
   Volume Used Space:        268.0 GB (268042694656 Bytes) (exactly 523520888 512-Byte-Units) (53.7%)
   Volume Available Space:   230.8 GB (230844600320 Bytes) (exactly 450868360 512-Byte-Units) (46.3%)
   Read-Only Media:          No
   Read-Only Volume:         No
   Removable Media:          Fixed
   Solid State:              No
   Virtual:                  Yes
   OS 9 Drivers:             No
   Low Level Format:         Not supported
   This disk is a Core Storage Logical Volume (LV).  Core Storage Information:
   LV UUID:                  D471B905-8B0B-48EB-9CA9-BF092127C063
   LVF UUID:                 AF1DA9DA-2809-4997-9578-128D7D0E72CC
   LVG UUID:                 D3743C0B-4069-488E-914B-FC234DFF8E46
   PV UUID (disk):           87BEA027-2DB6-440E-AC22-00DC14DDE0A7 (disk0s2)
   Fusion Drive:             No
   Encrypted:                Yes
-bash-3.2#
Au cas où, je l'ai fait aussi pour le disque dur externe
-bash-3.2# diskutil info /Volumes/"Clone"
   Device Identifier:        disk3s2
   Device Node:              /dev/disk3s2
   Whole:                    No
   Part of Whole:            disk3
   Volume Name:              Clone
   Mounted:                  Yes
   Mount Point:              /Volumes/Clone
   Partition Type:           Apple_HFS
   Type (Bundle):            hfs
   Journal:                  Journal size 81920 KB at offset 0x45e02000
   Booter Disk:              disk3s3
   Recovery Disk:            disk3s3
   Protocol:                 USB
   Volume UUID:              2462130E-0A2D-39E1-A701-097B20411684
   Disk / Partition UUID:    812020CD-40C7-4C76-80F2-C5A242DF3FA9
   Disk Size:                999.3 GB (999344099328 Bytes) (exactly 1951843944 512-Byte-Units)
   Volume Total Space:       999.3 GB (999344099328 Bytes) (exactly 1951843944 512-Byte-Units)
   Volume Used Space:        517.2 GB (517151875072 Bytes) (exactly 1010062256 512-Byte-Units) (51.7%)
   Volume Available Space:   482.2 GB (482192224256 Bytes) (exactly 941781688 512-Byte-Units) (48.3%)
   Read-Only Media:          No
   Device Location:          External
-bash-3.2#
Le volume est monté > en lecture et écriture > et un OS peut y être installé. Tous les feux sont au vert.
Mais tu as toujours dans le volume Macintosh HD un dossier macOS Install Data (de plus de 5 Go) > qui est le dossier résiduel de l'installation qui a avorté. La mention OS X montrant que ce n'est ni un dossier d'installation de Sierra ni de High Sierra (il y aurait macOS à la place de OS X)
Par la commande (à passer avec le plus grand soin) :
rm -rf /Volumes/"Macintosh HD 1"/"OS X Install Data"
  • en mettant bien "Macintosh HD 1" et "OS X Install Data" entre "" ; ne crée pas d'espace indû --> il n'y en a pas entre 1" et /"OS--
  • tu supprimes ce dossier parasite
=> si tu quittes à présent le Terminal > pour activer l'option : Ré-installer macOS (ou OS X) --> quel est l'OS qui t'est proposé à la ré-installation (ne démarre pas l'installation) ? - autre façon de le demander : par quelle combinaison de touches as-tu actuellement démarré ? - ⌘R ? - ⌘⌥R ? ⌘⌥⇧R ?
- et encore : quel était l'OS installé avant la tentative d'installation ?
J'ai bien exécuté la commande (j'espère puisqu'il ne m'a rien indiqué!) normalement ça devrait être bon. Si je vois pour réinstaller il me propose High Sierra. Avant j'ai essayé de réinstaller la version fournie avec mon mac il me semble que c'est Yosemite en appuyant sur Maj+Option+Commande+R (⌘⌥⇧R). Le dossier vient probablement de là. Puis comme ça ne fonctionnait pas (vu que je n'avais pas effacé le disque dur) j'ai fait Option+Commande+R (⌘⌥R). J'ai multiplié les tentatives avec espoir à vrai dire. Je suis bien contente de t'avoir trouvé sur ce forum!
Oui : ça devait être le dossier d'installation de «Yosemite».
Ce que je me demande, en fait, c'est si une ré-installation directe de High Sierra à destination du volume Macintosh HD ne réglerait pas les choses. Sans qu'il soit besoin d'effacer le volume > puis d'installer > et de récupérer enfin les données du volume Clone.
Est-ce que tu as déjà tenté de ré-installer directement High Sierra précédemment ?
Oui plusieurs fois...Même résultat: après l'installation le bureau ne s'ouvre pas la barre de chargement est complète mais ça ne bouge pas. Mais peut être que je peux re tenter maintenant que le fichier résiduel n'est plus là. Peut être que c'était lui qui posait problème. Si je vois que ça ne fonctionne toujours pas, je peux effacer sans risque maintenant vu que mes fichiers sont sur mon disque dur (mais il faudrait que j'efface l'image disque d'abord si j'ai bien compris)?
Bon d'accord. Il faut faire la totale.
Alors par la commande (toujours saisie consciencieusement) -->
rm -f /Volumes/Clone/"Macintosh HD.dmg"
  • tu supprimes l'image-disque qui grève le volume Clone
Cela fait > passe la commande :
hdiutil info
  • qui retourne la liste des images-disques actuellement utilisées
--> poste ce tableau ici --> c'est pour vérifier si tu es actuellement démarrée sur une image-disque en RAM indépendante du disque du Mac > ou sur une image-disque dépendante du volume Recovery HD du disque.
voici :
-bash-3.2# rm -f /Volumes/Clone/"Macintosh HD.dmg"
-bash-3.2# hdiutil info
framework       : 480.30.2
driver          : 10.13v480.30.2
images          : 19
image-path      : ramfile://478740408
shadow-path     : <none>
icon-path       : <none>
image-type      : <unknown>
system-image    : false
blockcount      : 4194056
blocksize       : 512
writeable       : TRUE
autodiskmount   : <unknown>
removable       : false
image-encrypted : <false>
mounting user   : root
mounting mode   : <unknown>
process ID      : <in-kernel>
/dev/disk1    GUID_partition_scheme
/dev/disk1s1    48465300-0000-11AA-AA11-00306543ECAC    /
image-path      : ram://10240
icon-path       : <none>
system-image    : TRUE
blockcount      : 10240
blocksize       : <unknown>
writeable       : TRUE
autodiskmount   : false
removable       : TRUE
/dev/disk4        /private/var/log
icon-path       : <none>
system-image    : TRUE
blockcount      : 1024
writeable       : TRUE
removable       : TRUE
/dev/disk5        /Volumes
icon-path       : <none>
system-image    : TRUE
blockcount      : 1024
writeable       : TRUE
removable       : TRUE
/dev/disk6        /private/var/tmp
icon-path       : <none>
system-image    : TRUE
blockcount      : 1024
writeable       : TRUE
removable       : TRUE
/dev/disk7        /private/var/run
image-path      : ram://4096
icon-path       : <none>
system-image    : TRUE
blockcount      : 4096
writeable       : TRUE
removable       : TRUE
/dev/disk8        /private/tmp
icon-path       : <none>
system-image    : TRUE
blockcount      : 1024
writeable       : TRUE
removable       : TRUE
/dev/disk9        /System/Installation
icon-path       : <none>
system-image    : TRUE
blockcount      : 1024
writeable       : TRUE
removable       : TRUE
/dev/disk10        /private/var/db
image-path      : ram://24576
icon-path       : <none>
system-image    : TRUE
blockcount      : 24576
writeable       : TRUE
removable       : TRUE
/dev/disk11        /private/var/folders
icon-path       : <none>
system-image    : TRUE
blockcount      : 4096
writeable       : TRUE
removable       : TRUE
/dev/disk12        /private/var/root/Library
image-path      : ram://2048
icon-path       : <none>
system-image    : TRUE
blockcount      : 2048
writeable       : TRUE
removable       : TRUE
/dev/disk13
icon-path       : <none>
system-image    : TRUE
blockcount      : 4096
writeable       : TRUE
removable       : TRUE
/dev/disk14        /private/var/root/Library/Containers
icon-path       : <none>
system-image    : TRUE
blockcount      : 1024
writeable       : TRUE
removable       : TRUE
/dev/disk15        /Library/Preferences
icon-path       : <none>
system-image    : TRUE
blockcount      : 1024
writeable       : TRUE
removable       : TRUE
/dev/disk16        /Library/Preferences/SystemConfiguration
icon-path       : <none>
system-image    : TRUE
blockcount      : 2048
writeable       : TRUE
removable       : TRUE
/dev/disk17        /Library/Keychains
image-path      : ram://12288
icon-path       : <none>
system-image    : TRUE
blockcount      : 12288
writeable       : TRUE
removable       : TRUE
/dev/disk18        /private/var/tmp/RecoveryTemp
icon-path       : <none>
system-image    : TRUE
blockcount      : 12288
writeable       : TRUE
removable       : TRUE
/dev/disk19        /private/var/tmp/OSISPredicateUpdateProductTemp
icon-path       : <none>
system-image    : TRUE
blockcount      : 1024
writeable       : TRUE
removable       : TRUE
/dev/disk20        /private/var/tmp/InstallerCookies
icon-path       : <none>
system-image    : TRUE
blockcount      : 4096
writeable       : TRUE
removable       : TRUE
/dev/disk21        /Library/Logs/DiagnosticReports
-bash-3.2#
J'aime lire cette ligne -->
  • qui dit que le statut de l'image-disque (BaseSystem.dmg) sur laquelle le Mac est démarré est ramfile = fichier résident de la RAM.
Il va être temps de faire le ménage sur le disque. Passe la commande :
diskutil umount force /Volumes/"Macintosh HD"
  • qui démonte le volume Macintosh HD
Puis la commande (pour toi) :
diskutil cs list
  • qui réaffiche le tableau du CoreStorage. Tout en haut > à droite de la rubrique Logical Volume Group > tu sélectionnes l'UUID = D3743C0B-4069-488E-914B-FC234DFF8E46 et par ⌘C tu le copies dans le presse-papier.
Tu passes la commande :
diskutil cs deleteLVG D3743C0B-4069-488E-914B-FC234DFF8E46
  • où par ⌘V tu colles l'UUID en fin de commande. Cette commande supprime le CoreStorage et remonte un volume standard intitulé Untitled sur la partition disk0s2
Si tu n'as pas eu de message d'erreur > repasse encore un :
diskutil list
  • et poste le tableau.
Ahah! Bah moi j'ai eu l'impression de faire un truc méga important là et pourtant je ne sais pas du tout ce que je fais. Je te suis à l'aveugle.
-bash-3.2# diskutil umount force /Volumes/"Macintosh HD"
Unmount failed for /Volumes/Macintosh HD
-bash-3.2# diskutil umount force /Volumes/"Macintosh HD 1"
Volume Macintosh HD on disk22 force-unmounted
-bash-3.2# diskutil cs list
CoreStorage logical volume groups (1 found)
+-- Logical Volume Group D3743C0B-4069-488E-914B-FC234DFF8E46
    Status:       Online
    Size:         499248103424 B (499.2 GB)
    Free Space:   8486912 B (8.5 MB)
    +-< Physical Volume 87BEA027-2DB6-440E-AC22-00DC14DDE0A7
    |   Index:    0
    |   Disk:     disk0s2
    |   Status:   Online
    +-> Logical Volume Family AF1DA9DA-2809-4997-9578-128D7D0E72CC
        Encryption Type:         AES-XTS
        Encryption Status:       Unlocked
        Conversion Status:       Complete
        High Level Queries:      Fully Secure
        |                        Passphrase Required
        |                        Accepts New Users
        |                        Has Visible Users
        |                        Has Volume Key
        +-> Logical Volume D471B905-8B0B-48EB-9CA9-BF092127C063
            Disk:                  disk22
            Status:                Online
            Size (Total):          498887294976 B (498.9 GB)
            Revertible:            Yes (unlock and decryption required)
            LV Name:               Macintosh HD
            Content Hint:          Apple_HFS
-bash-3.2# diskutil cs deleteLVG D3743C0B-4069-488E-914B-FC234DFF8E46
Started CoreStorage operation
Unmounting Logical Volumes
Destroying Logical Volume Group
Erasing disk0s2
Initialized /dev/rdisk0s2 as a 465 GB case-insensitive HFS Plus volume with a 40960k journal
Mounting disk
Finished CoreStorage operation
-bash-3.2# diskutil list
   0:      GUID_partition_scheme                        *500.1 GB   disk0
   2:                  Apple_HFS Untitled                499.2 GB   disk0s2
/dev/disk1 (disk image):
   0:     FDisk_partition_scheme                        *4.0 GB     disk2
   1:             Windows_FAT_32 USB VAL                 4.0 GB     disk2s1
   0:      GUID_partition_scheme                        *1.0 TB     disk3
   2:                  Apple_HFS Clone                   999.3 GB   disk3s2
   3:                 Apple_Boot Recovery HD             650.0 MB   disk3s3
/dev/disk4 (disk image):
   0:                            untitled               +5.2 MB     disk4
/dev/disk5 (disk image):
/dev/disk6 (disk image):
/dev/disk7 (disk image):
/dev/disk8 (disk image):
   0:                            untitled               +2.1 MB     disk8
/dev/disk9 (disk image):
/dev/disk10 (disk image):
   0:                            untitled               +524.3 KB   disk10
/dev/disk11 (disk image):
   0:                            untitled               +12.6 MB    disk11
/dev/disk12 (disk image):
   0:                            untitled               +2.1 MB     disk12
/dev/disk13 (disk image):
   0:                            untitled               +1.0 MB     disk13
/dev/disk14 (disk image):
   0:                            untitled               +2.1 MB     disk14
/dev/disk15 (disk image):
/dev/disk16 (disk image):
   0:                            untitled               +524.3 KB   disk16
/dev/disk17 (disk image):
   0:                            untitled               +1.0 MB     disk17
/dev/disk18 (disk image):
/dev/disk19 (disk image):
   0:                            untitled               +6.3 MB     disk19
/dev/disk20 (disk image):
   0:                            untitled               +524.3 KB   disk20
/dev/disk21 (disk image):
   0:                            untitled               +2.1 MB     disk21
-bash-3.2#
Je refais la manip que j'ai déjà faite du coup ? (Peut être n'as tu pas vu la suite du tableau que j'ai posté? )
Erasing disk0s2
Mounting disk
-bash-3.2#
Non : c'est moi qui ai fait une erreur de saisie de message. Je suis en train de te répondre. Tout va bien.
Tout s'est bien déroulé.
Tu peux encore passer la commande cosmétique :
diskutil rename disk0s2 "Macintosh HD"
  • et tu as un volume renommé Macintosh HD > dans un format Mac OS étendu (journalisé) > sur la partition principale disk0s2.
  • tu n'as plus qu'à quitter le Terminal et à lancer l'option "Ré-installer macOS" à destination du volume Macintosh HD.
  • en fin d'installation > il t'est demandé si tu veux récupérer des données --> tu coches la case : "À partir d'un autre Mac" et tu indiques le volume Clone. L'«Assistant de migration» va récupérer ton compte (et tes données) > les applications tierces et divers réglages.
=> tu n'auras qu'à dire à la fin si tout s'est bien passé et si tu as récupéré ta session dans l'OS High Sierra.
Réactions: noyaudecerise
Super merci beaucoup! Je suis en train de télécharger je te tiens au courant (yen a pour 3h et 59 minutes) J'espère que ça va le faire! En tout cas c'était vraiment très sympa de m'aider et de m'accorder autant de temps. Je te souhaite une bonne soirée!
@ Mak Whopper
En attendant de connaître l'issue de la ré-installation / récupération nocturne initiée par noyaudecerise --> je peux ce matin revenir à loisir au cas que tu as exposé au message #131 en fournissant excellemment sur un plateau des tableaux d'informations.
La configuration de ton disque de 1 To est simple et sobre -->
   2:                  Apple_HFS Macintosh HD            999.3 GB   disk0s2
--> pas d'activation de «FileVault» ni de présence d'un système de stockage CoreStorage Chiffré > mais un volume Macintosh HD au format jhfs+ flanqué de sa partition de secours sur le RecoveryOS duquel tu as démarré.
376 Go de données dans le volume Macintosh HD > ce qui laisse 623 Go d'espace libre. Un volume monté > en lecture et écriture (non verrouillé en lecture seule) > dans lequel un OS peut être installé (ou restauré). Formellement parlant : tout est en ordre. Il doit simplement y avoir un problème logiciel interne au volume Macintosh HD : un plantage du processus d'installation dont il reste à se représenter la nature.
Je t'invite à apporter un complément d'informations en passant la commande :
ls /Volumes/"Macintosh HD"
  • qui liste les objets de 1er niveau présents dans l'espace-racine du volume
et en postant ici le tableau retourné.
Et en répondant à quelques questions subsidiaires : quel est l'OS qui était installé sur le disque avant la tentative de mise-à-niveau à High Sierra ? - as-tu une sauvegarde des données de Macintosh HD ou aucune ?
Réactions: Mak Whopper
Bonjour @macomaniac ! Le transfert de fichiers vient tout juste de se terminer. Tout va pour le mieux! J'ai tout récupéré, mon mac est opé... Bref je ne sais comment te remercier! C'est génial, je respire ! Merci donc pour ta disponibilité et ta bienveillance. Je te souhaite en passant une très bonne année 2018!
:coucou: noyaudecerise
Ravi pour toi. Tu commences donc bien l'année et je t'adresse mes meilleurs vœux.
Tu as dû me trouver un tantinet (et même immensément) précautionneux hier soir > à multiplier indéfiniment les commandes informatives. C'est qu'il y avait des particularités (une image-disque énorme dans le volume restauré > un dossier d'installation OS X Base System sans correspondance avec High Sierra - notamment) qui demandaient réflexion.
Je pense que tu gagnerais à avoir une sauvegarde régulièrement mise à jour.
Oui pour la sauvegarde on ne m'y reprendra plus, je vais bien y veiller! Je comprends que tu aies été précautionneux et c'est tant mieux, j'avais aussi besoin d'être rassurée et d'être sûre d'où j'allais. Donc vraiment, ça a été parfait !
Bonsoir Macomaniac,
Tout d'abord, je te remercie pour le temps que tu m'accorderas.
Je vais commencer par répondre à tes questions subsidiaires :
- Mon ancien OS était "Sierra" (v10.12)
- Je n'ai pas de sauvegarde de mes fichiers, mais je dispose d'un DDE vierge de 320Go (système fat32), qui est légérement trop petit pour une sauvegarde. Je pense cependant pouvoir trouver un dossier conséquent pouvant être supprimé.
Dernière information utile, sur safari (en mode "obtenir de l'aide en ligne"), lorsque je maintien cmd+O (la lettre), je distingue tous mes dossiers, et mes fichiers. Je peux t'envoyer un screenshot si tu le souhaites, via mon mobile.
Tu trouveras ci-dessous le tableau résultant de la commande :
-bash-3.2# ls /Volumes/"Macintosh HD"
.DS_Store                Users
.DocumentRevisions-V100            Volumes
.IAProductInfo                cores
.OSInstallerMessages            dev
.PKInstallSandboxManager-SystemSoftware    etc
.Spotlight-V100                home
.Trashes                macOS Install Data
.fseventsd                net
.hotfiles.btree                opt
.vol                    private
Network                    tmp
Recovered Items                var
-bash-3.2#
