Pas de problème.Salut Sophie.
Désolé ce soir j'ai piscine.
On voit ça demain ?
Merci.
On voit ça demain ?
-bash-3.2# diskutil list
#: TYPE NAME SIZE IDENTIFIER
0: GUID_partition_scheme *251.0 GB disk0
1: EFI EFI 209.7 MB disk0s1
2: Apple_APFS Container disk2 250.8 GB disk0s2
/dev/disk1 (disk image):
0: GUID_partition_scheme +2.1 GB disk1
1: Apple_HFS OS X Base System 2.0 GB disk1s1
/dev/disk2 (synthesized):
0: APFS Container Scheme - +250.8 GB disk2
Physical Store disk0s2
1: APFS Volume Macintosh HD 207.7 GB disk2s1
2: APFS Volume Preboot 16.7 MB disk2s2
3: APFS Volume Recovery 520.8 MB disk2s3
/dev/disk3 (disk image):
0: untitled +5.2 MB disk3
/dev/disk4 (disk image):
0: untitled +524.3 KB disk4
/dev/disk5 (disk image):
0: untitled +524.3 KB disk5
/dev/disk6 (disk image):
0: untitled +524.3 KB disk6
/dev/disk7 (disk image):
0: untitled +2.1 MB disk7
/dev/disk8 (disk image):
0: untitled +524.3 KB disk8
/dev/disk9 (disk image):
0: untitled +524.3 KB disk9
/dev/disk10 (disk image):
0: untitled +12.6 MB disk10
/dev/disk11 (disk image):
0: untitled +2.1 MB disk11
/dev/disk12 (disk image):
0: untitled +1.0 MB disk12
/dev/disk13 (disk image):
0: untitled +2.1 MB disk13
/dev/disk14 (disk image):
0: untitled +524.3 KB disk14
/dev/disk15 (disk image):
0: untitled +524.3 KB disk15
/dev/disk16 (disk image):
0: untitled +1.0 MB disk16
/dev/disk17 (disk image):
0: untitled +6.3 MB disk17
/dev/disk18 (disk image):
0: untitled +6.3 MB disk18
/dev/disk19 (disk image):
0: untitled +524.3 KB disk19
/dev/disk20 (disk image):
0: untitled +2.1 MB disk20
-bash-3.2# diskutil cs list
No CoreStorage logical volume groups found
-bash-3.2# diskutil ap list
APFS Container (1 found)
+-- Container disk2 CA966A09-3850-4F5B-9F36-CA0B1E18E3A7
APFS Container Reference: disk2
Capacity Ceiling (Size): 250790436864 B (250.8 GB)
Capacity In Use By Volumes: 208386469888 B (208.4 GB) (83.1% used)
Capacity Available: 42403966976 B (42.4 GB) (16.9% free)
+-< Physical Store disk0s2 7CBBE1FC-093F-4514-90EF-9D9D09A1092C
| APFS Physical Store Disk: disk0s2
| Size: 250790436864 B (250.8 GB)
+-> Volume disk2s1 A5573524-F3C3-347E-8E13-60F41740BBBF
| APFS Volume Disk (Role): disk2s1 (No specific role)
| Name: Macintosh HD (Case-insensitive)
| Mount Point: /Volumes/Macintosh HD
| Capacity Consumed: 207710642176 B (207.7 GB)
| Encrypted: No
+-> Volume disk2s2 BD34776D-0C7A-478C-BB1D-3FC740C75279
| APFS Volume Disk (Role): disk2s2 (Preboot)
| Name: Preboot (Case-insensitive)
| Mount Point: Not Mounted
| Capacity Consumed: 16723968 B (16.7 MB)
| Encrypted: No
+-> Volume disk2s3 571AA5FA-8C79-4A30-85B8-9C8D19757260
APFS Volume Disk (Role): disk2s3 (Recovery)
Name: Recovery (Case-insensitive)
Capacity Consumed: 520765440 B (520.8 MB)
Encrypted: No
-bash-3.2#
j'ai le même problème je pense, jeanjd63.
Je suis connectée sur le forum comme tu as dit de le faire et j'ai copié la première partie que tu as demandé aux deux autres personnes. La voici :
Bloc de code:-bash-3.2# diskutil list /dev/disk0 (internal, physical): #: TYPE NAME SIZE IDENTIFIER 0: GUID_partition_scheme *1.0 TB disk0 1: EFI EFI 209.7 MB disk0s1 2: Apple_HFS So 999.3 GB disk0s2 3: Apple_Boot Recovery HD 650.0 MB disk0s3 /dev/disk1 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: GUID_partition_scheme +2.1 GB disk1 1: Apple_HFS OS X Base System 2.0 GB disk1s1 /dev/disk2 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +5.2 MB disk2 /dev/disk3 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +524.3 KB disk3 /dev/disk4 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +524.3 KB disk4 /dev/disk5 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +524.3 KB disk5 /dev/disk6 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +2.1 MB disk6 /dev/disk7 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +524.3 KB disk7 /dev/disk8 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +524.3 KB disk8 /dev/disk9 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +12.6 MB disk9 /dev/disk10 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +2.1 MB disk10 /dev/disk11 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +1.0 MB disk11 /dev/disk12 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +2.1 MB disk12 /dev/disk13 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +524.3 KB disk13 /dev/disk14 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +524.3 KB disk14 /dev/disk15 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +1.0 MB disk15 /dev/disk16 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +6.3 MB disk16 /dev/disk17 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +6.3 MB disk17 /dev/disk18 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +524.3 KB disk18 /dev/disk19 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +2.1 MB disk19 -bash-3.2#
Par avance merci pour ton aide
Sophie
Bloc de code:-bash-3.2# diskutil list /dev/disk0 (internal, physical): #: TYPE NAME SIZE IDENTIFIER 0: GUID_partition_scheme *251.0 GB disk0 1: EFI EFI 209.7 MB disk0s1 2: Apple_APFS Container disk2 250.8 GB disk0s2 /dev/disk1 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: GUID_partition_scheme +2.1 GB disk1 1: Apple_HFS OS X Base System 2.0 GB disk1s1 /dev/disk2 (synthesized): #: TYPE NAME SIZE IDENTIFIER 0: APFS Container Scheme - +250.8 GB disk2 Physical Store disk0s2 1: APFS Volume Macintosh HD 207.7 GB disk2s1 2: APFS Volume Preboot 16.7 MB disk2s2 3: APFS Volume Recovery 520.8 MB disk2s3 /dev/disk3 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +5.2 MB disk3 /dev/disk4 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +524.3 KB disk4 /dev/disk5 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +524.3 KB disk5 /dev/disk6 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +524.3 KB disk6 /dev/disk7 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +2.1 MB disk7 /dev/disk8 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +524.3 KB disk8 /dev/disk9 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +524.3 KB disk9 /dev/disk10 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +12.6 MB disk10 /dev/disk11 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +2.1 MB disk11 /dev/disk12 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +1.0 MB disk12 /dev/disk13 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +2.1 MB disk13 /dev/disk14 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +524.3 KB disk14 /dev/disk15 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +524.3 KB disk15 /dev/disk16 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +1.0 MB disk16 /dev/disk17 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +6.3 MB disk17 /dev/disk18 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +6.3 MB disk18 /dev/disk19 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +524.3 KB disk19 /dev/disk20 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: untitled +2.1 MB disk20 -bash-3.2# diskutil cs list No CoreStorage logical volume groups found -bash-3.2# diskutil ap list APFS Container (1 found) | +-- Container disk2 CA966A09-3850-4F5B-9F36-CA0B1E18E3A7 ==================================================== APFS Container Reference: disk2 Capacity Ceiling (Size): 250790436864 B (250.8 GB) Capacity In Use By Volumes: 208386469888 B (208.4 GB) (83.1% used) Capacity Available: 42403966976 B (42.4 GB) (16.9% free) | +-< Physical Store disk0s2 7CBBE1FC-093F-4514-90EF-9D9D09A1092C | ----------------------------------------------------------- | APFS Physical Store Disk: disk0s2 | Size: 250790436864 B (250.8 GB) | +-> Volume disk2s1 A5573524-F3C3-347E-8E13-60F41740BBBF | --------------------------------------------------- | APFS Volume Disk (Role): disk2s1 (No specific role) | Name: Macintosh HD (Case-insensitive) | Mount Point: /Volumes/Macintosh HD | Capacity Consumed: 207710642176 B (207.7 GB) | Encrypted: No | +-> Volume disk2s2 BD34776D-0C7A-478C-BB1D-3FC740C75279 | --------------------------------------------------- | APFS Volume Disk (Role): disk2s2 (Preboot) | Name: Preboot (Case-insensitive) | Mount Point: Not Mounted | Capacity Consumed: 16723968 B (16.7 MB) | Encrypted: No | +-> Volume disk2s3 571AA5FA-8C79-4A30-85B8-9C8D19757260 --------------------------------------------------- APFS Volume Disk (Role): disk2s3 (Recovery) Name: Recovery (Case-insensitive) Mount Point: Not Mounted Capacity Consumed: 520765440 B (520.8 MB) Encrypted: No -bash-3.2#
Meme problème!!! La misère....
Je vais essayer de réinstaller avec la dernière sauvegarde de Times...
Bonjour,Ok
As-tu des sauvegardes et sinon as-tu un disque externe disponible?
Donc tu branches ton DDE et tu refais un rapport :Bonjour,
Merci pour ta réponse
Pas de sauvegarde (je sais...:/) Mais un disque externe oui.
diskutil list
0: GUID_partition_scheme *250.1 GB disk3
1: EFI EFI 209.7 MB disk3s1
2: Microsoft Basic Data BOB 249.8 GB disk3s2
-bash-3.2#
-bash-3.2# df -H
Filesystem Size Used Avail Capacity iused ifree %iused Mounted on
/dev/disk1s1 2.0G 1.3G 728M 64% 44922 4294922357 0% /
devfs 206k 206k 0B 100% 696 0 100% /dev
/dev/disk2 5.2M 1.1M 4.2M 21% 21 4294967258 0% /private/var/log
/dev/disk4 524k 147k 377k 29% 5 4294967274 0% /Volumes
/dev/disk5 524k 147k 377k 29% 7 4294967272 0% /private/var/tmp
/dev/disk6 524k 160k 365k 31% 12 4294967267 0% /private/var/run
/dev/disk7 2.1M 143k 2.0M 7% 2 4294967277 0% /private/tmp
/dev/disk8 524k 143k 381k 28% 2 4294967277 0% /System/Installation
/dev/disk9 524k 299k 225k 58% 20 4294967259 0% /private/var/db
/dev/disk10 13M 2.7M 9.9M 22% 70 4294967209 0% /private/var/folders
/dev/disk11 2.1M 1.7M 422k 80% 141 4294967138 0% /private/var/root/Library
/dev/disk13 2.1M 143k 2.0M 7% 2 4294967277 0% /private/var/root/Library/Containers
/dev/disk14 524k 180k 344k 35% 9 4294967270 0% /Library/Preferences
/dev/disk15 524k 164k 360k 32% 6 4294967273 0% /Library/Preferences/SystemConfiguration
/dev/disk16 1.0M 184k 864k 18% 5 4294967274 0% /Library/Keychains
/dev/disk17 6.3M 176k 6.1M 3% 2 4294967277 0% /private/var/tmp/RecoveryTemp
/dev/disk18 6.3M 176k 6.1M 3% 2 4294967277 0% /private/var/tmp/OSISPredicateUpdateProductTemp
/dev/disk19 524k 143k 381k 28% 2 4294967277 0% /private/var/tmp/InstallerCookies
/dev/disk20 2.1M 143k 2.0M 7% 2 4294967277 0% /Library/Logs/DiagnosticReports
/dev/disk0s2 999G 153G 846G 16% 860527 4294106752 0% /Volumes/So
/dev/disk3s2 250G 62G 188G 25% 0 0 100% /Volumes/BOB
-bash-3.2#
Voilà c'est fait.Ok ça va rentrer (150 Go à sauver).
Vide ton DDE et fais signe quand c'est fait.
-bash-3.2#
Bien au contraire Tous les noms de mes fichiers qui se sauvegardent (dont un bon nombre de trucs que je pensais avoir viré ), ça m'apaiseT'es pas trop énervée?
Donc maintenant tu vas donner les retours des 2 commandes :
df -H
et
ls -l /Volumes/Save_Mac_HD
-bash-3.2# df -H
devfs 206k 206k 0B 100% 698 0 100% /dev
/dev/disk2 5.2M 1.5M 3.8M 28% 22 4294967257 0% /private/var/log
/dev/disk9 524k 303k 221k 58% 20 4294967259 0% /private/var/db
/dev/disk10 13M 2.7M 9.9M 22% 81 4294967198 0% /private/var/folders
/dev/disk11 2.1M 2.0M 123k 95% 286 4294966993 0% /private/var/root/Library
/dev/disk13 2.1M 348k 1.7M 17% 49 4294967230 0% /private/var/root/Library/Containers
/dev/disk16 1.0M 176k 872k 17% 5 4294967274 0% /Library/Keychains
/dev/disk3s2 250G 158G 92G 64% 751048 4294216231 0% /Volumes/Save_Mac_HD
-bash-3.2#
-bash-3.2# ls -l /Volumes/Save_Mac_HD
total 32
drwxrwxr-x+ 74 root admin 2516 Nov 12 12:23 Applications
drwxr-xr-x+ 68 root wheel 2312 Nov 15 19:39 Library
drwxr-xr-x@ 2 root wheel 68 Nov 2 12:49 Network
drwxr-xr-x@ 4 root wheel 136 Oct 25 16:31 System
drwxr-xr-x@ 6 root admin 204 Nov 2 12:49 Users
drwxr-xr-x@ 3 root wheel 102 Nov 16 17:36 Volumes
drwxr-xr-x@ 38 root wheel 1292 Oct 25 16:37 bin
drwxrwxr-t@ 2 root admin 68 Nov 2 12:49 cores
dr-xr-xr-x@ 2 root wheel 68 Nov 2 12:49 dev
lrwxr-xr-x@ 1 root wheel 11 Nov 2 12:47 etc -> private/etc
dr-xr-xr-x@ 2 root wheel 68 Nov 24 2016 home
-rw-r--r--@ 1 root wheel 313 Sep 1 01:09 installer.failurerequests
drwxr-xr-x@ 7 root wheel 238 Nov 17 19:59 macOS Install Data
dr-xr-xr-x@ 2 root wheel 68 Oct 17 2014 net
drwxr-xr-x@ 6 root wheel 204 Nov 2 12:49 private
drwxr-xr-x@ 63 root wheel 2142 Nov 2 12:48 sbin
lrwxr-xr-x@ 1 root wheel 11 Nov 2 12:47 tmp -> private/tmp
drwxr-xr-x@ 9 root wheel 306 Oct 25 16:22 usr
lrwxr-xr-x@ 1 root wheel 11 Nov 2 12:48 var -> private/var
-bash-3.2#
