Sujet unique Si « le serveur de récupération n’a pas pu être contacté » ou qu’il est « impossible de télécharger les composants supplémentaires »
Voilà
-bash-3.2# diskutil info disk15
   Device Identifier:        disk15
   Device Node:              /dev/disk15
   Whole:                    Yes
   Part of Whole:            disk15
   Device / Media Name:      OWC Mercury EXTREME Pro 6G SSD
   Volume Name:              MACOSX
   Mounted:                  Yes
   Mount Point:              /Volumes/MACOSX
   File System Personality:  Journaled HFS+
   Type (Bundle):            hfs
   Name (User Visible):      Mac OS Extended (Journaled)
   Journal:                  Journal size 24576 KB at offset 0x6f9000
   Content (IOContent):      Apple_HFS
   OS Can Be Installed:      Yes
   Recovery Disk:            disk0s3
   Protocol:                 SATA
   Volume UUID:              5BD2931E-01A8-3AC6-91ED-192AD04BC7A9
   Disk / Partition UUID:    0EE1CD9B-B7EA-4044-BD6E-8FCAC232F52B
   Total Size:               238.8 GB (238828126208 Bytes) (exactly 466461184 512-Byte-Units)
   Volume Free Space:        107.9 GB (107900362752 Bytes) (exactly 210742896 512-Byte-Units)
   Device Block Size:        512 Bytes
   Read-Only Media:          No
   Read-Only Volume:         No
   Removable Media:          No
   Solid State:              Yes
   Virtual:                  Yes
   OS 9 Drivers:             No
   Low Level Format:         Not supported
   This disk is a Core Storage Logical Volume (LV).  Core Storage Information:
   LV UUID:                  0EE1CD9B-B7EA-4044-BD6E-8FCAC232F52B
   LVF UUID:                 0E34A82F-974F-4389-AACC-05610A90FE43
   LVG UUID:                 7EE474BD-EC3F-4FFA-B4B6-0ABDFDA5949C
   Fusion Drive:             No
   Encrypted:                Yes
-bash-3.2# ls /Vol*/MAC*
.DS_Store            Volumes
.DocumentRevisions-V100        bin
.OSInstallerMessages        cores
.Spotlight-V100            dev
.TALRestoreApps            etc
.Trashes            home
.dbfseventsd            installer.failurerequests
.file                lost+found
.fseventsd            macOS Install Data
.vol                net
Applications            private
Library                sbin
Network                tmp
System                usr
Users                var
-bash-3.2# bless --info /Vol*/MC*
No mount point for /Vol*/MC*
Can't get mount point for /Vol*/MC*
-bash-3.2# bless --info /Vol*/MAC*
finderinfo[0]: 3040411 => Blessed System Folder is /Volumes/MACOSX/System/Library/CoreServices
finderinfo[1]: 4305266 => Blessed System File is /Volumes/MACOSX/System/Library/CoreServices/boot.efi
finderinfo[2]:      0 => Open-folder linked list empty
finderinfo[3]:      0 => No alternate OS blessed file/folder
finderinfo[4]:      0 => Unused field unset
finderinfo[5]: 3040411 => OS X blessed folder is /Volumes/MACOSX/System/Library/CoreServices
64-bit VSDB volume id:  0x7CDB3200AB9921A9
-bash-3.2#
Aucune modification en aucun point du volume MACOSX.
- passe la commande (copier-coller à rebours) :​
rm /Volumes/MACOSX/"macOS Install Data" ; ls /Vol*/MAC*
  • la commande supprime le dossier macOS Install Data de l'installation plantée (commande muette si elle passe) > puis réaffiche le tableau des objets de 1er rang du volume (afin qu'on vérifie si le dossier a bien été supprimé)
Poste le retour (liste mise à jour des items de MACOSX).
Salut,
Fait
-bash-3.2# rm /Volumes/MACOSX/"macOS Install Data" ; ls /Vol*/MAC*
rm: /Volumes/MACOSX/macOS Install Data: is a directory
.DS_Store            Volumes
.Spotlight-V100            dev
.TALRestoreApps            etc
.Trashes            home
.file                lost+found
.vol                net
Library                sbin
Network                tmp
System                usr
Users                var
-bash-3.2#
Pardon ! je me suis loupé dans ma commande de suppression en échappant l'option récursive -r de rigueur quand l'objet est un dossier.
- donc repasse la commande éditée :​
rm -rf /Volumes/MACOSX/"macOS Install Data" ; ls /Vol*/MAC*
  • incluant les options -rf (récursivité et forçage de la suppression)
=> et reposte le retour.
Pas de problème ;)
-bash-3.2# rm -rf /Volumes/MACOSX/"macOS Install Data" ; ls /Vol*/MAC*
.DS_Store            Volumes
.Spotlight-V100            dev
.TALRestoreApps            etc
.Trashes            home
.file                lost+found
.fseventsd            net
.vol                private
Applications            sbin
Library                tmp
Network                usr
System                var
Users
-bash-3.2#
Dossier d'installation plantée bien supprimé cette fois-ci.
- passe encore la commande (copier-coller à rebours - copie-la bien jusqu'au --setBoot final) :​
bless --folder /Volumes/MACOSX/System/Library/CoreServices --file /Volumes/MACOSX/System/Library/CoreServices/boot.efi --setBoot
  • la commande réécrit le chemin de démarrage du volume (en le faisant pointer sur le lanceur boot.efi de l'OS en place) > et inscrit en NVRAM (via l'option --setBoot) une préférence de démarrage automatique pour l'EFI (le programme de boot primaire du Mac) suivant le même chemin
La commande est muette (retour direct de -bash-3.2#) si elle passe => est-ce que ça a été le cas ?
Alors tente ta chance -->
- va au Menu  > Redémarrer (et pas Disque de démarrage cette fois-ci) > et redémarre sans options au clavier​
=> décris ce qui se sera passé après le déverrouillage du volume logique en prélude de démarrage...
Salut,
J'entre mon mot de passe, et je reçoit le message d'erreur (voir image ci bas)
J'ai tenté à plusieurs reprise et toujours le même message
    96,3 KB · Affichages: 164
Il paraît donc clair que la distribution de l'OS dans le volume MACOSX a été corrompue par les installations avortées antérieures.
- quel est l'OS qui était installé dans MACOSX : High Sierra ? - et quel est l'OS proposé à la réinstallation quand tu démarres via ⌘R ?​
Salut,
J'avais El capitan, j'ai voulu faire une mise à jour vers High sierra, et voilà que les problèmes ont commencés
Quand j'essaie de réinstaller ça me propose OS X EL Capitan 10.11
Refais une tentative à présent que le dossier de l'installation foirée a été supprimé -->
- tu reviens dans la session de secours > dans l'Utilitaire de disque tu re-déverrouilles MACOSX pour le remonter > enfin tu relances l'option : "Réinstaller OS X" => à destination de MACOSX
Raconte ce qui se sera passé...
Note : si ça ne fonctionne toujours pas => alors ce sera le plan B.
Salut,
Bon j'ai été sur Utilitaire de disque,
J'ai déverrouillé MACOSX et il a été monté.
Par la suite j'ai relancé la réinstallation . Mais le même problème,
Une fenêtre advertisement me mentionne :
''Pour télécharger et restaurer OS X, l'admissibilité de votre ordinateur sera vérifiée auprès d'Apple.''
Je clique sur ''Continuer''
Et je reçois le même message d'erreur:
''Un téléchargement nécessaire est manquant''
Je suis donc prêt à passer au plan B ;)
Le message : ''Un téléchargement nécessaire est manquant'' peut signifier => que les ressources de réinstallation d'El Capitan ne sont pas disponibles sur le serveur Apple de récupération. Donc tu ne peux pas les télécharger en préambule d'une réinstallation.
- question : aurais-tu un autre Mac qui permettrait de confectionner une clé d'installation démarrable d'El Capitan (ou de High Sierra) ?​
Le plan B consiste déjà à recopier le volume MACOSX => au volume d'un DDE USB pour en sauvegarder les données.
- il s'agirait ensuite de reformater MACOSX > réinstaller l'OS > récupérer les données du clone à la fin via l'Assistant de migration. Soit le procédé des « 4 r ».​
Il faudrait d'abord que tu disposes d'un DDE USB permettant de créer un volume dédié d'environ 160 Go. Ensuite il faudrait qu'après reformatage du volume-cible de la réinstallation => tu puisses télécharger du serveur Apple de récupération les ressources de réinstallation d'El Capitan.
Branche-le au Mac. Laisse passer quelques secondes que le disque soit connecté.
- passe la commande :​
diskutil list ; df -H
  • qui affiche : la confifguration des disques & l'occupation des volumes montés
Poste le double retour.
Voilà,
-bash-3.2# diskutil list ; df -H
   0:      GUID_partition_scheme                        *480.1 GB   disk0
   1:                        EFI EFI                     213.8 MB   disk0s1
   2:          Apple_CoreStorage MACOSX                  239.2 GB   disk0s2
   3:                 Apple_Boot Recovery HD             658.0 MB   disk0s3
/dev/disk1 (disk image):
   0:     FDisk_partition_scheme                        *2.0 TB     disk2
   1:               Windows_NTFS Seagate Expansion Drive 2.0 TB     disk2s1
/dev/disk3 (disk image):
/dev/disk4 (disk image):
/dev/disk5 (disk image):
/dev/disk6 (disk image):
/dev/disk7 (disk image):
/dev/disk8 (disk image):
/dev/disk9 (disk image):
   0:                            untitled               +6.3 MB     disk9
/dev/disk10 (disk image):
   0:                            untitled               +2.1 MB     disk10
/dev/disk11 (disk image):
   0:                            untitled               +1.0 MB     disk11
/dev/disk12 (disk image):
   0:                            untitled               +524.3 KB   disk12
/dev/disk13 (disk image):
   0:                            untitled               +524.3 KB   disk13
/dev/disk14 (disk image):
   0:                            untitled               +1.0 MB     disk14
/dev/disk15 (disk image):
   0:                            untitled               +6.3 MB     disk15
Offline
                                 Logical Volume MACOSX on disk0s2
                                 Locked Encrypted
Filesystem     Size   Used  Avail Capacity iused      ifree %iused  Mounted on
/dev/disk1s1   2.0G   1.3G   721M    64%  315037     176074   64%   /
devfs          198k   198k     0B   100%     668          0  100%   /dev
/dev/disk3     5.2M   2.0M   3.3M    38%     479        799   37%   /private/var/log
/dev/disk4     524k   147k   377k    29%      34         92   27%   /Volumes
/dev/disk5     524k   143k   381k    28%      33         93   26%   /private/var/tmp
/dev/disk6     524k   160k   365k    31%      37         89   29%   /private/var/run
/dev/disk7     524k   147k   377k    29%      34         92   27%   /System/Installation
/dev/disk8     524k   254k   270k    49%      60         66   48%   /private/var/db
/dev/disk9     6.3M   2.8M   3.5M    45%     677        857   44%   /private/var/folders
/dev/disk10    2.1M   213k   1.9M    11%      50        460   10%   /private/var/root/Library
/dev/disk12    524k   172k   352k    33%      40         86   32%   /Library/Preferences
/dev/disk13    524k   164k   360k    32%      38         88   30%   /Library/Preferences/SystemConfiguration
/dev/disk14    1.0M   176k   872k    17%      41        213   16%   /Library/Keychains
/dev/disk15    6.3M   176k   6.1M     3%      41       1493    3%   /private/var/tmp/RecoveryTemp
/dev/disk0s3   650M   562M    81M    88%  138793      19897   87%   /Volumes/Image Volume
/dev/disk2s1   2.0T   291G   1.7T    15%   60687 1669071917    0%   /Volumes/Seagate Expansion Drive
-bash-3.2#
Mais juste une petite précision, c'est n'est pas très grave si je perds mes données. Ce qui je veux, c'est de pouvoir réutiliser mon MacBook
Ton DDE -->
  • n'a pas les bons paramètres pour un repartitionnement non destructeur du volume existant : table de partition MBR (désignée par : FDisk_partition_scheme) & type de partition Windows_NTFS (annonçant un format soit NTFS > soit exFAT).
Aurais-tu un PC qui te permettrait de télécharger une image-disque hébergeant un installateur d'El Capitan ? => une fois l'image-disque obtenue > tu pourrais la transporter au Mac via une clé USB > et on pourrait depuis la session de secours configurer la clé en clé d'installation démarrable d'El Capitan. Tu pourrais alors lancer une réinstallation du volume MACOSX.
