Trop fort ! Résultat =>Passe la commande (copier-coller - copie-la jusqu'au disk4 final) :
Bloc de code:diskutil eraseVolume free null disk4s3 ; diskutil eraseVolume free null disk4s4 ; diskutil resizeVolume disk4s2 0b ; diskutil list disk4
- cette commande concatanée : a) supprime la 1ère partition de secours > b) supprime la 2è > c) récupère leur espace au volume SIERRA > d) affiche la configuration du disk4 seul
Poste l'ensemble de l'affichage retourné --> histoire de voir s'il n'y a pas de blocage dans l'enchaînement...
Last login: Sat Apr 27 20:30:33 on ttys000
Mac-Pro-de-pierre:~ pierrexxxx$ diskutil eraseVolume free null disk4s3 ; diskutil eraseVolume free null disk4s4 ; diskutil resizeVolume disk4s2 0b ; diskutil list disk4
Started erase on disk4s3 Recovery HD
Unmounting disk
Finished erase on disk4
Started erase on disk4s4 Recovery HD
Unmounting disk
Resizing to full size (fit to fill)
Started partitioning on disk4s2 PHOTO
Verifying the disk
Verifying file system
Volume was successfully unmounted
Performing fsck_hfs -fn -x /dev/rdisk4s2
Checking Journaled HFS Plus volume
Checking extents overflow file
Checking catalog file
Checking multi-linked files
Checking catalog hierarchy
Checking extended attributes file
Checking volume bitmap
Checking volume information
The volume PHOTO appears to be OK
File system check exit code is 0
Restoring the original state found as mounted
Resizing
Modifying partition map
Growing file system
Finished partitioning on disk4s2 PHOTO
/dev/disk4 (internal, physical):
#: TYPE NAME SIZE IDENTIFIER
0: GUID_partition_scheme *2.0 TB disk4
1: EFI EFI 209.7 MB disk4s1
2: Apple_HFS PHOTO 2.0 TB disk4s2
