10.13 High Sierra Impossible de créer un volume de pré-démarrage pour l’installation apfs
Alors passe la commande (copier-coller) :
hdiutil attach ~/Downloads/High*
  • qui monte le volume de l'image-disque
Poste le retour
Last login: Wed Jan  1 20:59:19 on console
The default interactive shell is now zsh.
To update your account to use zsh, please run `chsh -s /bin/zsh`.
For more details, please visit https://support.apple.com/kb/HT208050.
MBP-de-Eric:~ eric$ diskutil list
   0:      GUID_partition_scheme                        *251.0 GB   disk0
   2:                 Apple_APFS Container disk1         250.7 GB   disk0s2
/dev/disk1 (synthesized):
   0:      APFS Container Scheme -                      +250.7 GB   disk1
                                 Physical Store disk0s2
   1:                APFS Volume Macintosh HD - Données  81.4 GB    disk1s1
   2:                APFS Volume Preboot                 101.1 MB   disk1s2
   3:                APFS Volume Recovery                528.5 MB   disk1s3
   4:                APFS Volume VM                      1.1 GB     disk1s4
   5:                APFS Volume Macintosh HD            11.0 GB    disk1s5
   0:     FDisk_partition_scheme                        *8.0 GB     disk2
   1:                  Apple_HFS El Capitan USB          8.0 GB     disk2s1
MBP-de-Eric:~ eric$ diskutil eraseDisk jhfs+ CLE gpt disk2
Started erase on disk2
Unmounting disk
Creating the partition map
Waiting for partitions to activate
Formatting disk2s2 as Mac OS Extended (Journaled) with name CLE
Initialized /dev/rdisk2s2 as a 7 GB case-insensitive HFS Plus volume with a 8192k journal
Mounting disk
Finished erase on disk2
MBP-de-Eric:~ eric$ hdiutil attach ~/Downloads/High*
/dev/disk3              GUID_partition_scheme
/dev/disk3s1            EFI
/dev/disk3s2            Apple_HFS                          /Volumes/High Sierra
MBP-de-Eric:~ eric$
Le volume High Sierra est bien monté.
- passe la commande (copier-coller) :​
sudo /Vol*/High*/Install*/C*/R*/createinstallmedia --volume /Vol*/CLE --applicationpath /Vol*/High*/Install* --nointeraction
  • à validation > une demande de password s'affiche (commande sudo) --> tape ton mot-de-passe de session admin en aveugle - aucun caractère ne se montrant à la frappe - et revalide
  • la commande configure le volume CLE en volume d'installation démarrable de High Sierra. CLE va être reformaté > renommé Install macOS High Sierra > cloné de l'installateur > des fichiers de démarrage de l'OS d'installation recelé vont être créés > enfin un chemin de démarrage inscrit sur l'en-tête du volume. Ça va prendre plusieurs minutes.
Poste le retour > lorsque tu auras récupéré l'invite de commande : MBP-de-Eric:~ eric$.
Unmounting disk
Mounting disk
/dev/disk3s1            EFI
MBP-de-Eric:~ eric$ sudo /Vol*/High*/Install*/C*/R*/createinstallmedia --volume /Vol*/CLE --applicationpath /Vol*/High*/Install* --nointeraction
Password:
Killed: 9
MBP-de-Eric:~ eric$
MBP-de-Eric:~ eric$
MBP-de-Eric:~ eric$
C'est la protection Gatekeeper (le Cerbère de la porte) qui fait des siennes. Passe la commande (copier-coller) :
sudo spctl --master-disable
  • qui désactive la protection Gatekeeper et autorise les applications téléchargées de : "N'importe où".
Cela fait > repasse la commande :
  • et poste le retour.
Unmounting disk
Mounting disk
/dev/disk3s1            EFI
Password:
Killed: 9
MBP-de-Eric:~ eric$
MBP-de-Eric:~ eric$
MBP-de-Eric:~ eric$ sudo spctl --master-disable
Password:
Erasing Disk: 0%... 10%... 20%... 30%...100%...
Copying installer files to disk...
Copy complete.
Making disk bootable...
Copying boot files...
Copy complete.
Done.
MBP-de-Eric:~ eric$
La clé est prête -->
- éjecte-la de ton Mac. Branche-la à l'autre Mac. Démarre-le la touche "alt" pressée pour obtenir l'écran de choix du volume de démarrage. Choisis : Install macOS High Sierra (volume de la clé) > démarre dessus. Tu obtiens un écran affichant une fenêtre de 4 Utilitaires macOS (identique à celui d'une session de secours).​
Tu trouves le Terminal à la même place que dans une session de secours (barre de menus supérieure de l'écran > menu : Utilitaires).
- passe une commande :​
diskutil list
  • et poste le (haut du) tableau des disques => que je revoie la configuration du disque interne.
-bash-3.2# diskutil list
   0:      GUID_partition_scheme                        *250.1 GB   disk0
   2:                  Apple_HFS Machintosh HD           249.7 GB   disk0s2
/dev/disk1 (external, physical):
   0:      GUID_partition_scheme                        *8.0 GB     disk1
   2:                  Apple_HFS Install macOS High S... 7.7 GB     disk1s2
/dev/disk2 (disk image):
   0:      GUID_partition_scheme                        +2.1 GB     disk2
   1:                  Apple_HFS OS X Base System        2.0 GB     disk2s1
/dev/disk3 (disk image):
/dev/disk4 (disk image):
/dev/disk5 (disk image):
/dev/disk6 (disk image):
/dev/disk7 (disk image):
/dev/disk8 (disk image):
/dev/disk9 (disk image):
/dev/disk10 (disk image):
   0:                            untitled               +12.6 MB    disk10
/dev/disk11 (disk image):
   0:                            untitled               +4.2 MB     disk11
/dev/disk12 (disk image):
/dev/disk13 (disk image):
/dev/disk14 (disk image):
/dev/disk15 (disk image):
/dev/disk16 (disk image):
/dev/disk17 (disk image):
/dev/disk18 (disk image):
/dev/disk19 (disk image):
/dev/disk20 (disk image):
   0:                            untitled               +2.1 MB     disk20
-bash-3.2#
Au fait quelle est la commande pour réactivier Gatekeeper? Parce qe vu que je suis nul j'ai pas envie que n'importe quoi soit installé sur mon ordinateur ;)
C'est la commande :
sudo spctl --master-enable
  • qui réactive Gatekeeper.
Je vois que tu as un volume Macintosh HD standard sur le disque interne -->
- dans la fenêtre des 4 Utilitaires macOS > lance l'option : "Réinstaller macOS" => et choisis Macintosh HD comme destination lorsque cela te sera proposé.​
=> est-ce que l'installation se lance ? - je pose la question > car des problèmes de péremption des certificats d'application Apple internes aux installateurs qu'on peut avoir archivés => compliquent leur utilisation pour lancer une installation.
C'est la commande :
Le disque interne est un SSD et mer ci pour la commande de Gatekeeper
Il me dit que la copie de l'application Installer macOS High Sierra est endommagée et ne peut pas servir à installer macOS...
Relance le Terminal et passe la commande :
date
  • qui affiche la date & l'heure à l'horloge du Système d'installation démarré (paramètres empruntés au démarrage à l'horloge de la carte-mère)
Poste le retour.
date
Poste le retour.
-bash-3.2# date
Jeu  2 jan 2020 07:33:13 UTC
-bash-3.2#
On va reculer la date avant le 14 Février 2016 - date de péremption des certificats Apple => pour voir si ça débloque l'installation.
- passe la commande :​
date 0101233816
  • qui inscrit la date du 1er Janvier 2016 à 23H 38'
Poste le retour.
date 0101233816
Poste le retour.
Il ne veut pas charger de page internet maintenant que la date est changée. Le message c'est "Localized string not found vendredi 1 janvier 2016
