10.13 High Sierra Impossible de créer un volume de prédémarrage pour l'APFS
-bash-3.2# diskutil ap resizeContainer disk1 125g jhfs+ Restore 0b
Started APFS operation
Resizing APFS Container designated by APFS Container Reference disk1
Verifying storage system
Using live mode
Performing fsck_apfs -n -x -l /dev/disk0s2
Checking volume
Checking the space manager
Checking the object map
Checking the fsroot tree
Checking the extent ref tree
Checking the snapshots
Verifying allocated space
The volume /dev/disk0s2 appears to be OK
Shrinking APFS Physical Store disk0s2 from 250 685 575 168 to 124 999 999 488 bytes
Shrinking APFS data structures
Shrinking partition
Modifying partition map
Initialized /dev/rdisk0s3 as a 117 GB case-insensitive HFS Plus volume with a 16384k journal
Mounting disk
1 new disk created or changed due to APFS operation
Disk from APFS operation: disk0s3
Finished APFS operation
-bash-3.2#
Ça a l'air d'avoir marché. Passe la commande :
diskutil list
  • et poste le tableau pour vérification.
-bash-3.2# diskutil list
/dev/disk0 (internal):
   0:      GUID_partition_scheme                         251.0 GB   disk0
   2:                 Apple_APFS Container disk1         125.0 GB   disk0s2
   3:                  Apple_HFS Restore                 125.6 GB   disk0s3
/dev/disk1 (synthesized):
   0:      APFS Container Scheme -                      +125.0 GB   disk1
   1:                APFS Volume Macintosh HD            5.2 GB     disk1s1
   2:                APFS Volume Preboot                 22.5 MB    disk1s2
   3:                APFS Volume Recovery                509.8 MB   disk1s3
   4:                APFS Volume VM                      1.1 GB     disk1s4
/dev/disk2 (disk image):
   0:      GUID_partition_scheme                        +2.1 GB     disk2
   1:                  Apple_HFS OS X Base System        2.0 GB     disk2s1
/dev/disk3 (disk image):
/dev/disk4 (disk image):
/dev/disk5 (disk image):
/dev/disk6 (disk image):
/dev/disk7 (disk image):
/dev/disk8 (disk image):
/dev/disk9 (disk image):
/dev/disk10 (disk image):
   0:                            untitled               +12.6 MB    disk10
/dev/disk11 (disk image):
   0:                            untitled               +2.1 MB     disk11
/dev/disk12 (disk image):
/dev/disk13 (disk image):
/dev/disk14 (disk image):
/dev/disk15 (disk image):
/dev/disk16 (disk image):
/dev/disk17 (disk image):
/dev/disk18 (disk image):
/dev/disk19 (disk image):
/dev/disk20 (disk image):
   0:                            untitled               +2.1 MB     disk20
-bash-3.2#
Parfait ! --> voici la nouvelle partition avec son volume Restore -->
  • tu as peut-être deviné l'idée ? --> puisque tu ne peux pas démarrer par internet sur un OS indépendant du disque pour supprimer le Conteneur apfs --> eh bien ! tu vas ré-installer macOS dans un 1er temps dans un volume indépendant (= Restore) > ce qui te permettra d'effacer le Conteneur du haut du disque.
Quitte le Terminal > et lance l'option : "Ré-installer macOS" à destination du volume Restore. Tu n'auras qu'à prévenir quand tu auras ouvert une session dans le volume Restore démarré.
# note: je pensais que ton problème serait assez rapide à régler --> mais en fait on est embarqués dans une partie de campagne dominicale...
je suis sur la cession restore. je clique sur restore ?
j'ai cliqué sur restore et cela s'installe (reste 17 minutes )
le chargement vient de se terminer et l'ordinateur a redémarré tout seul la pomme est sur l'écran noire
il est indiqué installation dans environ 11 minutes.
Les ressources d'installation ont été téléchargées dans le volume Restore (5,2 Go en si peu de temps : tu dois avoir la fibre).
À présent > elles servent de source pour l'installation proprement dite de High Sierra dans le volume.
non pas la fibre mais le cable. il reste encore 7 minutes d'installation. Je fais quoi après ?
par avance merci beaucoup très sympa ton intervention "moi qui suis nulle et bin j'ai tout compris pour l'instant"
merci encore
:coucou: paulominou
Ton bonheur fait plaisir à voir > mais je suis là pour te dire que... ce n'est pas fini.
Passe la commande :
diskutil list
  • et poste le tableau --> tu vas vite voir pourquoi -
   3:                 Apple_APFS Container disk2         125.7 GB   disk0s3
/dev/disk2 (synthesized):
   0:      APFS Container Scheme -                      +125.7 GB   disk2
                                 Physical Store disk0s3
   1:                APFS Volume Restore                 13.7 GB    disk2s1
   2:                APFS Volume Preboot                 22.9 MB    disk2s2
   3:                APFS Volume Recovery                509.8 MB   disk2s3
   4:                APFS Volume VM                      1.1 GB     disk2s4
   0:      GUID_partition_scheme                        +2.1 GB     disk3
   1:                  Apple_HFS OS X Base System        2.0 GB     disk3s1
   0:                            untitled               +5.2 MB     disk4
   0:                            untitled               +2.1 MB     disk8
   0:                            untitled               +524.3 KB   disk10
   0:                            untitled               +12.6 MB    disk11
   0:                            untitled               +2.1 MB     disk12
   0:                            untitled               +1.0 MB     disk13
   0:                            untitled               +2.1 MB     disk14
   0:                            untitled               +524.3 KB   disk16
   0:                            untitled               +1.0 MB     disk17
   0:                            untitled               +6.3 MB     disk19
   0:                            untitled               +524.3 KB   disk20
/dev/disk21 (disk image):
   0:                            untitled               +2.1 MB     disk21
-bash-3.2#
Hé ! tu n'es pas obligée d'aller chercher le Terminal de la session de secours ! Tu en as un dans l'OS accessible de ta session d'utilisatrice. Dans lequel tu es sûre de ne pas être démarrée sur le volume Recovery du Conteneur n°1.
Va à : Menu  > Disque de démarrage > Restore --> re-démarre. Une fois dans ta session > va à : Applications > Utilitaires > lance le Terminal.app (c'est le Terminal de l'OS).
Passe la commande :
diskutil list
  • et poste le tableau --> je veux être sûr que le Conteneur du haut est toujours disk1 à partir de ce démarrage.
excuse
Last login: Sun Feb 18 16:11:11 on console
MacBook-Pro-de-SYLVIE:~ sylviejacquot$ diskutil list
   2:                 Apple_APFS Container disk2         125.0 GB   disk0s2
   3:                 Apple_APFS Container disk1         125.7 GB   disk0s3
   0:      APFS Container Scheme -                      +125.7 GB   disk1
   1:                APFS Volume Restore                 13.7 GB    disk1s1
   2:                APFS Volume Preboot                 22.9 MB    disk1s2
   0:      APFS Container Scheme -                      +125.0 GB   disk2
   1:                APFS Volume Macintosh HD            5.2 GB     disk2s1
   2:                APFS Volume Preboot                 22.5 MB    disk2s2
J'ai bien fait de vérifier --> le Conteneur du haut est indexé disk2 à partir d'un démarrage sur celui du bas !
Passe la commande (en copier-coller = confort...) :
diskutil ap deleteContainer disk2 "Macintosh HD"
  • cette commande supprime le Conteneur du haut et remonte un volume Macintosh HD au format Apple_HFS+
Si tu n'as pas eu de message d'erreur > poste le tableau retourné par un nouveau :
diskutil list
MacBook-Pro-de-SYLVIE:~ sylviejacquot$ diskutil ap deleteContainer disk2 "Macintosh HD"
Started APFS operation on disk2
Deleting APFS Container with all of its APFS Volumes
Unmounting Volumes
Unmounting Volume "Macintosh HD" on disk2s1
Unmounting Volume "Preboot" on disk2s2
Unmounting Volume "Recovery" on disk2s3
Unmounting Volume "VM" on disk2s4
Deleting Volumes
Deleting Container
Wiping former APFS disks
Switching content types
Reformatting former APFS disks
Initialized /dev/rdisk0s2 as a 116 GB case-insensitive HFS Plus volume with a 16384k journal
Mounting disk
Disk from APFS operation: disk0s2
Finished APFS operation on disk2
   2:                  Apple_HFS Macintosh HD            124.9 GB   disk0s2
Parfait.
Tu devines la suite ? - tu te connectes à l'AppStore > tu télécharges un installateur de High Sierra --> tu déclenches l'installation à la fin à destination du volume Macintosh HD.
Tu n'auras pas d'erreur touchant le volume de prédémarrage ce coup-ci. Tu pourras créer un compte à toi à la fin et tu ouvriras un session dans le volume Macintosh HD.
Signale-le alors. Il ne restera plus qu'à supprimer le Conteneur du bas (Restore) - qui t'aura tenu lieu d'équivalent de démarrage par internet - et à récupérer son espace.
je suis en train de télécharger high sierra. pour tout te dire je ne devine rien je vais à l'aveugle car je ne sais pas ce que je fais, mais ça me va bien car ça marche
Simplement que ton volume Restore ne fait que 120 Go (la moitié du disque). Comme il est situé en bas de disque > on ne peut pas l'agrandir vers le haut. Alors je te fais ré-installer un OS dans le volume du haut (Macintosh HD) > qui lui pourra être agrandi aux 120 Go de Restore une fois ce dernier supprimé. Et tu auras un seul volume de 250 Go.
  • c'est une variante du jeu de tric-trac - pas plus malin.
