Last login: Sun Feb 18 17:00:38 on console
MacBook-Pro-de-SYLVIE:~ sylviejacquot$ diskutil list
/dev/disk0 (internal):
#: TYPE NAME SIZE IDENTIFIER
0: GUID_partition_scheme 251.0 GB disk0
1: EFI EFI 314.6 MB disk0s1
2: Apple_APFS Container disk1 125.0 GB disk0s2
3: Apple_APFS Container disk2 125.7 GB disk0s3
/dev/disk1 (synthesized):
0: APFS Container Scheme - +125.0 GB disk1
Physical Store disk0s2
1: APFS Volume Macintosh HD 12.8 GB disk1s1
2: APFS Volume Preboot 22.9 MB disk1s2
3: APFS Volume Recovery 509.8 MB disk1s3
4: APFS Volume VM 1.1 GB disk1s4
/dev/disk2 (synthesized):
0: APFS Container Scheme - +125.7 GB disk2
Physical Store disk0s3
1: APFS Volume Restore 18.7 GB disk2s1
2: APFS Volume Preboot 22.9 MB disk2s2
3: APFS Volume Recovery 509.8 MB disk2s3
4: APFS Volume VM 2.1 GB disk2s4
diskutil ap resizeContainer disk1 120g free null 0b
MacBook-Pro-de-SYLVIE:~ sylviejacquot$ diskutil ap resizeContainer disk1 120g free null 0b
Started APFS operation
Resizing APFS Container designated by APFS Container Reference disk1
Verifying storage system
Using live mode
Performing fsck_apfs -n -x -l /dev/disk0s2
Checking volume
Checking the space manager
Checking the object map
warning: apfs_sb at apfs_fs_index (0): apfs_formatted_by.timestamp is invalid (1518970975000000000), is greater than current time (1518970814818375000)
Checking the fsroot tree
Checking the extent ref tree
Checking the snapshots
Verifying allocated space
warning: Overallocation Detected on Main device: (1742282+21) bitmap address (95568)
The volume /dev/disk0s2 appears to be OK
Shrinking APFS Physical Store disk0s2 from 124 999 999 488 to 120 000 000 000 bytes
Shrinking APFS data structures
APFS Container Resize error code is 49168
Error: -69606: A problem occurred while resizing APFS Container structures
diskutil list
Last login: Sun Feb 18 17:38:10 on console
2: Apple_APFS Container disk2 125.0 GB disk0s2
3: Apple_APFS Container disk1 125.7 GB disk0s3
0: APFS Container Scheme - +125.7 GB disk1
1: APFS Volume Restore 18.7 GB disk1s1
0: APFS Container Scheme - +125.0 GB disk2
1: APFS Volume Macintosh HD 13.6 GB disk2s1
4: APFS Volume VM 1.1 GB disk2s4
diskutil ap deleteContainer disk2 "Macintosh HD"
diskutil list
je ne sais pas ce que je fais. on verra bien
Last login: Sun Feb 18 18:11:27 on console
1: APFS Volume Macintosh HD 11.6 GB disk2s1
diskutil ap resizeContainer disk2 120g free null 0b
Last login: Sun Feb 18 18:18:28 on ttys000
MacBook-Pro-de-SYLVIE:~ sylviejacquot$ diskutil ap resizeContainer disk2 120g free null 0b
Resizing APFS Container designated by APFS Container Reference disk2
Using live mode
Checking volume
warning: apfs_sb at apfs_fs_index (0): apfs_formatted_by.timestamp is invalid (1518976241000000000), is greater than current time (1518974414540562000)
warning: Overallocation Detected on Main device: (1655246+21) bitmap address (94821)
hdiutil info
-bash-3.2# hdiutil info
framework : 480.30.2
driver : 10.13v480.30.2
images : 19
image-path : file:///1F6682F2-D940-31DD-BD5C-334CE0FF9ACD/BaseSystem.dmg
shadow-path : <none>
icon-path : <none>
image-type : <unknown>
system-image : false
blockcount : 4194024
blocksize : 512
writeable : TRUE
autodiskmount : <unknown>
removable : false
image-encrypted : <false>
mounting user : root
mounting mode : <unknown>
process ID : <in-kernel>
/dev/disk3 GUID_partition_scheme
/dev/disk3s1 48465300-0000-11AA-AA11-00306543ECAC /
image-path : ram://10240
icon-path : <none>
system-image : TRUE
blockcount : 10240
blocksize : <unknown>
writeable : TRUE
autodiskmount : false
removable : TRUE
/dev/disk4 /private/var/log
icon-path : <none>
system-image : TRUE
blockcount : 1024
writeable : TRUE
removable : TRUE
/dev/disk5 /Volumes
icon-path : <none>
system-image : TRUE
blockcount : 1024
writeable : TRUE
removable : TRUE
/dev/disk6 /private/var/tmp
icon-path : <none>
system-image : TRUE
blockcount : 1024
writeable : TRUE
removable : TRUE
/dev/disk7 /private/var/run
image-path : ram://4096
icon-path : <none>
system-image : TRUE
blockcount : 4096
writeable : TRUE
removable : TRUE
/dev/disk8 /private/tmp
icon-path : <none>
system-image : TRUE
blockcount : 1024
writeable : TRUE
removable : TRUE
/dev/disk9 /System/Installation
icon-path : <none>
system-image : TRUE
blockcount : 1024
writeable : TRUE
removable : TRUE
/dev/disk10 /private/var/db
image-path : ram://24576
icon-path : <none>
system-image : TRUE
blockcount : 24576
writeable : TRUE
removable : TRUE
/dev/disk11 /private/var/folders
icon-path : <none>
system-image : TRUE
blockcount : 4096
writeable : TRUE
removable : TRUE
/dev/disk12 /private/var/root/Library
image-path : ram://2048
icon-path : <none>
system-image : TRUE
blockcount : 2048
writeable : TRUE
removable : TRUE
/dev/disk13
icon-path : <none>
system-image : TRUE
blockcount : 4096
writeable : TRUE
removable : TRUE
/dev/disk14 /private/var/root/Library/Containers
icon-path : <none>
system-image : TRUE
blockcount : 1024
writeable : TRUE
removable : TRUE
/dev/disk15 /Library/Preferences
icon-path : <none>
system-image : TRUE
blockcount : 1024
writeable : TRUE
removable : TRUE
/dev/disk16 /Library/Preferences/SystemConfiguration
icon-path : <none>
system-image : TRUE
blockcount : 2048
writeable : TRUE
removable : TRUE
/dev/disk17 /Library/Keychains
image-path : ram://12288
icon-path : <none>
system-image : TRUE
blockcount : 12288
writeable : TRUE
removable : TRUE
/dev/disk18 /private/var/tmp/RecoveryTemp
icon-path : <none>
system-image : TRUE
blockcount : 12288
writeable : TRUE
removable : TRUE
/dev/disk19 /private/var/tmp/OSISPredicateUpdateProductTemp
icon-path : <none>
system-image : TRUE
blockcount : 1024
writeable : TRUE
removable : TRUE
/dev/disk20 /private/var/tmp/InstallerCookies
icon-path : <none>
system-image : TRUE
blockcount : 4096
writeable : TRUE
removable : TRUE
/dev/disk21 /Library/Logs/DiagnosticReports
-bash-3.2#
