10.14 Mojave Mojave et Fusion Drive ... impossible d'en venir à bout
   2:                 Apple_APFS Container disk2         121.1 GB   disk0s2
   0:      GUID_partition_scheme                        *1.0 TB     disk1
   2:                 Apple_APFS Container disk2         878.9 GB   disk1s2
   3:                  Apple_HFS BROL                    121.0 GB   disk1s3
/dev/disk2 (synthesized):
   0:      APFS Container Scheme -                      +1000.0 GB  disk2
                                 Physical Stores disk0s2, disk1s2
   1:                APFS Volume boot                    79.4 GB    disk2s1
   2:                APFS Volume Preboot                 42.7 MB    disk2s2
   3:                APFS Volume Recovery                512.4 MB   disk2s3
   4:                APFS Volume VM                      2.1 GB     disk2s4
   5:                APFS Volume scratchPSD              880.6 KB   disk2s5
   6:                APFS Volume scratchAI               884.7 KB   disk2s6
   7:                APFS Volume OIM                     603.2 GB   disk2s7
   0:     FDisk_partition_scheme                        *2.0 TB     disk3
   1:                  Apple_HFS LaCie                   2.0 TB     disk3s1
Le volume a été créé. Passe la commande :
diskutil info /Volumes/BROL
  • et poste le tableau d'informations.
Nadine:~ macmacoo$ diskutil info /Volumes/BROL
   Device Identifier:         disk1s3
   Device Node:               /dev/disk1s3
   Whole:                     No
   Part of Whole:             disk1
   Volume Name:               BROL
   Mounted:                   Yes
   Mount Point:               /Volumes/BROL
   Partition Type:            Apple_HFS
   File System Personality:   Journaled HFS+
   Type (Bundle):             hfs
   Name (User Visible):       Mac OS Extended (Journaled)
   Journal:                   Journal size 16384 KB at offset 0x388000
   Owners:                    Enabled
   OS Can Be Installed:       Yes
   Media Type:                Generic
   Protocol:                  SATA
   SMART Status:              Verified
   Volume UUID:               54358E44-A526-3637-98EC-8886E0A07459
   Disk / Partition UUID:     5B30C27F-99B2-4FE0-95C1-AF728D22F648
   Partition Offset:          879086665728 Bytes (1716966144 512-Byte-Device-Blocks)
   Disk Size:                 121.0 GB (120983982080 Bytes) (exactly 236296840 512-Byte-Units)
   Device Block Size:         512 Bytes
   Volume Total Space:        121.0 GB (120983982080 Bytes) (exactly 236296840 512-Byte-Units)
   Volume Used Space:         222.7 MB (222662656 Bytes) (exactly 434888 512-Byte-Units) (0.2%)
   Volume Free Space:         120.8 GB (120761319424 Bytes) (exactly 235861952 512-Byte-Units) (99.8%)
   Allocation Block Size:     4096 Bytes
   Read-Only Media:           No
   Read-Only Volume:          No
   Device Location:           Internal
   Removable Media:           Fixed
   Solid State:               No
   Hardware AES Support:      No
Passe les commandes :
sudo su
echo "UUID=54358E44-A526-3637-98EC-8886E0A07459 /Users hfs rw" > /private/etc/fstab
cat /private/etc/fstab
  • qui éditent fstab en "faveur" de BROL
Poste le retour de la 3è.
Bien. Redémarre > loge-toi comme maco -->
  • si ça foire encore : tes 3 volumes auxiliaires sont affichés mais pas BROL
  • si ça marche : tous les volumes sont affichés
=> bilan ?
Bon d'accord. Je ne sais pas si c'est un bogue du Fusion Style apfs --> mais l'instruction fstab n'est validée ni pour un volume apfs interne > ni pour un volume jhfs+ externe.
Solution à ton problème : plus de volume OIM séparé > réinjection du contenu des Users de LaCie dans les Users de boot (dont le dossier nadine) -->
- qu'est-ce que tu en penses ?​
Quelque chose m'échappe : Mojave a été installé et les 4 volumes montent bien
Pourquoi faut-il supprimer OIM?
Désolée il est tard, je n'arrive plus à réfléchir
Cela dit, je m'en moque de OIM, je souhaiterais juste une config stable et efficace. J'ai eu l'habitude d'avoir des volumes séparés mais c'est peut-être de la vieille école...
On ne peut pas faire monter OIM at: /Users. Rien qu'at: /Volumes (répertoire par défaut). Monté at: /Volumes > OIM ne te sert pas > car tu ne peux pas ouvrir de session sur le dossier nadine qu'il contient.
On peut modifier le chemin d'ouverture de session au dossier nadine dans OIM monté at: /Volumes. Mais il y a aussi dans ce volume des contenus qui doivent servir à tes applications. Qu'elles ont l'habitude d'aller chercher at: /Users. Déplacer simplement ces autres éléments dans /Users ?
- il se fait trop tard pour moi. Je jette l'éponge. Il y a donc plusieurs sortes de solutions possibles qui elles marcheront.​
La nuit porte conseil...
Je te remercie pour ta grande disponibilité et tout le temps que tu as consacré à mon cas si spécial.
Il faut que je trouve une solution, quitte à tout reparamétrer au niveau des applis...
Bonjour macomaniac,
Je comprends.
Si tu penses qu’il y a une solution facile à mettre en place, (encore toutes mes excuses pour le temps passé, je ne pensais pas que ça allait être si long!), je veux bien la tenter.
Tu me proposais :
J'ai pensé à un procédé qui ne mange pas de pain : laisser OIM tel quel > monté à part. Dans Users > créer autant de liens symboliques qu'il y a d'objets dans OIM (11 en tout) --> pointant directement aux originaux de OIM. Au lieu qu'OIM monte aux Users > ce seront les Users qui pointeront OIM -->
Franchement ça dépasse mes compétence, je n'y connais rien à l'architecture d'un disque.
Ces liens correspondent à mes dossiers?
Je te fais confiance et je ne suis pas borné non plus à garder mon ancienne configuration, apparemment les scratch disks sont toujours utilisés pour optimiser les performances d'Adobe CC, le reste...
Passe d'abord la commande :
sudo rm -rf /Users/nadine
  • la commande supprime le dossier nadine vide qui avait été créé à la volée précédemment dans les Users
=> elle passe sans commentaire --> exact ?
J'ai dû autoriser Terminal à accéder à mes contacts
Nadine:~ macmacoo$ sudo rm -rf /Users/nadine
Password:
rm: /Users/nadine/Pictures: Operation not permitted
rm: /Users/nadine/Library/Application Support/CallHistoryTransactions: Operation not permitted
rm: /Users/nadine/Library/Application Support/com.apple.TCC: Operation not permitted
rm: /Users/nadine/Library/Application Support/CallHistoryDB: Operation not permitted
rm: /Users/nadine/Library/Application Support: Operation not permitted
rm: /Users/nadine/Library/IdentityServices: Operation not permitted
rm: /Users/nadine/Library/Preferences/com.apple.homed.notbackedup.plist: Operation not permitted
rm: /Users/nadine/Library/Preferences/com.apple.universalaccess.plist: Operation not permitted
rm: /Users/nadine/Library/Preferences/com.apple.homed.plist: Operation not permitted
rm: /Users/nadine/Library/Preferences: Operation not permitted
rm: /Users/nadine/Library/Messages: Operation not permitted
rm: /Users/nadine/Library/HomeKit: Operation not permitted
rm: /Users/nadine/Library/Mail: Operation not permitted
rm: /Users/nadine/Library/Safari: Operation not permitted
rm: /Users/nadine/Library/Suggestions: Operation not permitted
rm: /Users/nadine/Library/Containers/com.apple.Safari: Operation not permitted
rm: /Users/nadine/Library/Containers/com.apple.mail: Operation not permitted
rm: /Users/nadine/Library/Containers: Operation not permitted
rm: /Users/nadine/Library/PersonalizationPortrait: Operation not permitted
rm: /Users/nadine/Library/Metadata/CoreSpotlight: Operation not permitted
rm: /Users/nadine/Library/Metadata: Operation not permitted
rm: /Users/nadine/Library/Cookies: Operation not permitted
rm: /Users/nadine/Library/Caches/com.apple.safaridavclient: Operation not permitted
rm: /Users/nadine/Library/Caches/CloudKit/com.apple.Safari: Operation not permitted
rm: /Users/nadine/Library/Caches/CloudKit: Operation not permitted
rm: /Users/nadine/Library/Caches/com.apple.Safari: Operation not permitted
rm: /Users/nadine/Library/Caches: Operation not permitted
rm: /Users/nadine/Library: Operation not permitted
rm: /Users/nadine: Operation not permitted
Nadine:~ macmacoo$
C'est un coup du SIP (protocole de sécurisation). Redémarre > les 2 touches ⌘R (cmd R) pressées de l'écran noir à la  = démarrage sur l'OS de secours.
Tu obtiens un écran avec une fenêtre de 4 Utilitaires macOS --> va à la barre de menus supérieure de l'écran > menu Utilitaires > lance le Terminal. Passe la commande :
csrutil disable
  • qui désactive le SIP
Quitte le Terminal. Menu  > Disque de démarrage > boot => reloge-toi comme maco. Repasse la commande :
  • retour ?
Enchaîne avec la commande :
ls /Volumes/OIM
  • qui liste les objets d'OIM
Poste cette liste.
