Restored session: Dim 25 nov 2018 23:14:32 CET
Nadine:~ macmacoo$ diskutil ap resizeContainer disk2 1t jhfs+ BROL 0b ; diskutil list
Started APFS operation
Aligning shrink delta to 121 118 199 808 bytes and targeting a new physical store size of 878 876 930 048 bytes
Determined the minimum size for the targeted physical store of this APFS Container to be 703 832 301 568 bytes
Resizing APFS Container designated by APFS Container Reference disk2
The specific APFS Physical Store being resized is disk1s2
Verifying storage system
Using live mode
Performing fsck_apfs -n -x -l -S /dev/disk0s2
Checking the fusion superblock
Checking the space manager
Checking the object map
Checking the Fusion data structures
Checking volume
The volume boot was formatted by hfs_convert (945.200.129) and last modified by apfs_kext (945.200.129)
Checking the extent ref tree
Checking the fsroot tree
Checking volume
The volume Preboot was formatted by hfs_convert (945.200.129) and last modified by apfs_kext (945.200.129)
Checking volume
The volume Recovery was formatted by diskmanagementd (945.200.129) and last modified by apfs_kext (945.200.129)
Checking volume
The volume VM was formatted by apfs.util (945.200.129) and last modified by apfs_kext (945.200.129)
Checking volume
The volume scratchPSD was formatted by diskmanagementd (945.200.129) and last modified by apfs_kext (945.200.129)
Checking volume
The volume scratchAI was formatted by diskmanagementd (945.200.129) and last modified by apfs_kext (945.200.129)
Checking volume
The volume OIM was formatted by diskmanagementd (945.200.129) and last modified by apfs_kext (945.200.129)
Verifying allocated space
Performing deferred repairs
The volume /dev/disk0s2 appears to be OK
Shrinking APFS Physical Store disk1s2 from 999 995 129 856 to 878 876 930 048 bytes
Shrinking APFS data structures
Shrinking partition
Modifying partition map
Initialized /dev/rdisk1s3 as a 113 GB case-insensitive HFS Plus volume with a 16384k journal
Mounting disk
1 new disk created or changed due to APFS operation
Disk from APFS operation: disk1s3
Finished APFS operation
512.4 MB disk2s3
4: APFS Volume VM 2.1 GB disk2s4
5: APFS Volume scratchPSD 880.6 KB disk2s5
6: APFS Volume scratchAI 884.7 KB disk2s6
7: APFS Volume OIM 603.2 GB disk2s7
#: TYPE NAME SIZE IDENTIFIER
0: FDisk_partition_scheme *2.0 TB disk3
1: Apple_HFS LaCie 2.0 TB disk3s1
