Nov 22 16:52:18 localhost bootlog[37]: BOOT_TIME: 1258905129 0
Nov 22 16:52:19 localhost blued[38]: Apple Bluetooth daemon started
Nov 22 16:52:21 localhost mDNSResponder[26]: mDNSResponder mDNSResponder-212.1 (Jul 24 2009 22:34:12) starting
Nov 22 16:52:21 localhost com.apple.usbmuxd[20]: usbmuxd-176 built for iTunesNineDot on Sep 24 2009 at 16:11:05, running 32 bit
Nov 22 16:52:21 localhost configd[13]: BUG in libdispatch: 10A432 - 1656 - 0x993b
Nov 22 16:52:22 localhost configd[13]: bootp_session_transmit: bpf_write(en1) failed: Network is down (50)
Nov 22 16:52:22 localhost configd[13]: DHCP en1: INIT-REBOOT transmit failed
Nov 22 16:52:22 localhost configd[13]: network configuration changed.
Nov 22 16:52:22 imac-de-guillaume-touchais configd[13]: setting hostname to "imac-de-guillaume-touchais.local"
Nov 22 16:52:22 imac-de-guillaume-touchais configd[13]: Sleep: Platform Failure - AC
Nov 22 16:52:23 imac-de-guillaume-touchais /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow[27]: Login Window Application Started
Nov 22 16:52:27 imac-de-guillaume-touchais configd[13]: network configuration changed.
Nov 22 16:52:29 imac-de-guillaume-touchais loginwindow[27]: Login Window Started Security Agent
Nov 22 16:52:29 imac-de-guillaume-touchais loginwindow[27]: Login Window - Returned from Security Agent
Nov 22 16:52:29 imac-de-guillaume-touchais loginwindow[27]: USER_PROCESS: 27 console
Nov 22 16:52:29 imac-de-guillaume-touchais com.apple.launchd.peruser.501[74] (com.apple.ReportCrash): Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
Nov 22 16:52:32 imac-de-guillaume-touchais com.apple.launchd.peruser.501[74] (com.apple.Kerberos.renew.plist[98]): Exited with exit code: 1
Nov 22 16:52:32 imac-de-guillaume-touchais com.apple.launchd.peruser.501[74] (com.apple.CSConfigDotMacCert-@me.com-SharedServices[101]): Exited with exit code: 1
Nov 22 16:55:00 imac-de-guillaume-touchais [0x0-0x12012].org.mozilla.firefox[120]: Debugger() was called!
Nov 22 17:02:32 imac-de-guillaume-touchais /System/Library/CoreServices/CCacheServer.app/Contents/MacOS/CCacheServer[104]: No valid tickets, timing out
Voici ce qui est présent sur le system.log dans la console. Ne comprenant rien j'ai tout mis.
Merci en tout cas pour vos réponses. Je pense aller voir le SAV demain pour demander un changement contre un imac neuf car bug dans les trois premières ne m'inspire pas confiance.
---------- Nouveau message ajouté à 17h08 ---------- Le message précédent a été envoyé à 17h07 ----------
Nov 22 10:42:28 imac-de-guillaume-touchais mds[25]: (/.Spotlight-V100/Store-V1/Stores/C80D84DE-C789-45EF-A8C1-22B1BBDF7031)(Error) IndexCI in open_index_file:bad file size: 4096, min size 77760, live.2.indexIds
Nov 22 10:42:29 imac-de-guillaume-touchais configd[13]: network configuration changed.
Nov 22 10:42:33 imac-de-guillaume-touchais loginwindow[27]: Login Window Started Security Agent
Nov 22 10:42:33 imac-de-guillaume-touchais loginwindow[27]: Login Window - Returned from Security Agent
Nov 22 10:42:33 imac-de-guillaume-touchais loginwindow[27]: USER_PROCESS: 27 console
Nov 22 10:42:33 imac-de-guillaume-touchais com.apple.launchd.peruser.501[75] (com.apple.ReportCrash): Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
Nov 22 10:42:35 imac-de-guillaume-touchais com.apple.launchd.peruser.501[75] (com.apple.Kerberos.renew.plist[98]): Exited with exit code: 1
Nov 22 10:42:36 imac-de-guillaume-touchais com.apple.launchd.peruser.501[75] (com.apple.CSConfigDotMacCert-@me.com-SharedServices[101]): Exited with exit code: 1
Nov 22 10:48:26 imac-de-guillaume-touchais [0x0-0xf00f].org.mozilla.firefox[112]: Debugger() was called!
Nov 22 10:52:35 imac-de-guillaume-touchais /System/Library/CoreServices/CCacheServer.app/Contents/MacOS/CCacheServer[104]: No valid tickets, timing out
Nov 22 11:42:45 imac-de-guillaume-touchais com.apple.backupd-auto[138]: Not starting scheduled Time Machine backup - time machine destination not resolvable.
Nov 22 12:22:52 imac-de-guillaume-touchais loginwindow[27]: loginwindow SleepWakeCallback WILL sleep
Nov 22 12:22:54 imac-de-guillaume-touchais configd[13]: PMConnection IPConfiguration com.apple.powermanagement.applicationresponse.slowresponse 1990 ms
Nov 22 12:22:54 imac-de-guillaume-touchais configd[13]: PMConnection mDNSResponder com.apple.powermanagement.applicationresponse.slowresponse 1993 ms
Nov 22 12:38:13 imac-de-guillaume-touchais loginwindow[27]: loginwindow SleepWakeCallback will power on, Currenttime:11/22/2009 12:38:13.011 PM - Waketime:11/22/2009 12:38:11.750 PM = Deltatime:1.261288106
Nov 22 12:38:20 imac-de-guillaume-touchais configd[13]: Sleep: Success - AC - Idle Sleep
Nov 22 12:38:20 imac-de-guillaume-touchais configd[13]: Wake: Success - AC - OHC1
Nov 22 12:38:20 imac-de-guillaume-touchais configd[13]: Hibernate Statistics
Nov 22 12:38:20 imac-de-guillaume-touchais com.apple.UserEventAgent-Aqua[94]: dontAutoLoad = EMPTY!
Nov 22 12:38:20 imac-de-guillaume-touchais configd[13]: network configuration changed.
Nov 22 12:38:20 imac-de-guillaume-touchais configd[13]: PMConnection AirPort configd plug-in com.apple.powermanagement.applicationresponse.slowresponse 7456 ms
Nov 22 12:38:20 imac-de-guillaume-touchais configd[13]: PMConnection IPConfiguration com.apple.powermanagement.applicationresponse.slowresponse 7456 ms
Nov 22 12:38:22 imac-de-guillaume-touchais configd[13]: network configuration changed.
Nov 22 12:38:38 imac-de-guillaume-touchais ntpd[18]: time reset -0.229469 s
Nov 22 12:38:43 imac-de-guillaume-touchais loginwindow[27]: spins were reported for this wake
Nov 22 12:38:46 imac-de-guillaume-touchais loginwindow[27]: loginwindow SleepWakeCallback WILL sleep
Nov 22 12:38:48 imac-de-guillaume-touchais configd[13]: network configuration changed.
Nov 22 12:38:52 imac-de-guillaume-touchais loginwindow[27]: loginwindow SleepWakeCallback will power on, Currenttime:11/22/2009 12:38:52.013 PM - Waketime:11/22/2009 12:38:50.750 PM = Deltatime:1.263416052
Nov 22 12:38:55 imac-de-guillaume-touchais mDNSResponder[26]: Note: RegisterInterface: Frequent transitions for interface en1 (192.168.0.12); network traffic reduction measures in effect
Nov 22 12:38:55 imac-de-guillaume-touchais mDNSResponder[26]: Note: RegisterInterface: Frequent transitions for interface en1 (FE80:0000:0000:0000:0226:08FF:FEF6:1B25); network traffic reduction measures in effect
Nov 22 12:38:57 imac-de-guillaume-touchais configd[13]: Sleep: Success - AC - Software Sleep
Nov 22 12:38:57 imac-de-guillaume-touchais configd[13]: Wake: Success - AC - OHC1
Nov 22 12:38:57 imac-de-guillaume-touchais configd[13]: Hibernate Statistics
Nov 22 12:38:57 imac-de-guillaume-touchais configd[13]: network configuration changed.
Nov 22 12:38:58 imac-de-guillaume-touchais WindowServer[55]: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
Nov 22 12:38:58 imac-de-guillaume-touchais com.apple.WindowServer[55]: Sun Nov 22 12:38:58 imac-de-guillaume-touchais.local WindowServer[55] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
Nov 22 12:39:05 imac-de-guillaume-touchais ntpd[18]: time reset +1.268711 s
Nov 22 12:39:23 imac-de-guillaume-touchais loginwindow[27]: no spins reported for this wake
Nov 22 12:39:23 imac-de-guillaume-touchais [0x0-0x19019].backupd-helper[181]: Not starting Time Machine backup after wake - failed to resolve alias to backup volume
Nov 22 12:45:24 imac-de-guillaume-touchais loginwindow[27]: loginwindow SleepWakeCallback WILL sleep
Nov 22 12:45:26 imac-de-guillaume-touchais configd[13]: network configuration changed.
Nov 22 13:17:41 imac-de-guillaume-touchais loginwindow[27]: loginwindow SleepWakeCallback will power on, Currenttime:11/22/2009 1:17:41.016 PM - Waketime:11/22/2009 1:17:39.750 PM = Deltatime:1.266039908
Nov 22 13:17:48 imac-de-guillaume-touchais configd[13]: Sleep: Success - AC - Software Sleep
Nov 22 13:17:48 imac-de-guillaume-touchais configd[13]: Wake: Success - AC - OHC1
Nov 22 13:17:48 imac-de-guillaume-touchais configd[13]: Hibernate Statistics
Nov 22 13:17:48 imac-de-guillaume-touchais configd[13]: network configuration changed.
Nov 22 13:18:11 imac-de-guillaume-touchais loginwindow[27]: no spins reported for this wake
Nov 22 13:18:11 imac-de-guillaume-touchais [0x0-0x1e01e].backupd-helper[206]: Not starting Time Machine backup after wake - failed to resolve alias to backup volume
Nov 22 13:26:39 imac-de-guillaume-touchais firefox-bin[112]: kCGErrorIllegalArgument: _CGSFindSharedWindow: WID 69
Nov 22 13:26:39 imac-de-guillaume-touchais firefox-bin[112]: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
Nov 22 13:26:39 imac-de-guillaume-touchais firefox-bin[112]: kCGErrorIllegalArgument: CGSRemoveSurface: Invalid window 0x45
Nov 22 13:26:39 imac-de-guillaume-touchais [0x0-0xf00f].org.mozilla.firefox[112]: Sun Nov 22 13:26:39 imac-de-guillaume-touchais.local firefox-bin[112] <Error>: kCGErrorIllegalArgument: _CGSFindSharedWindow: WID 69
Nov 22 13:26:39 imac-de-guillaume-touchais [0x0-0xf00f].org.mozilla.firefox[112]: Sun Nov 22 13:26:39 imac-de-guillaume-touchais.local firefox-bin[112] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
Nov 22 13:26:39 imac-de-guillaume-touchais [0x0-0xf00f].org.mozilla.firefox[112]: Sun Nov 22 13:26:39 imac-de-guillaume-touchais.local firefox-bin[112] <Error>: kCGErrorIllegalArgument: CGSRemoveSurface: Invalid window 0x45
Nov 22 13:30:17 imac-de-guillaume-touchais com.apple.backupd-auto[219]: Not starting scheduled Time Machine backup - time machine destination not resolvable.
Nov 22 14:20:45 localhost com.apple.launchd[1]: *** launchd[1] has started up. ***
Nov 22 14:20:48 localhost DirectoryService[15]: Improper shutdown detected
Nov 22 14:20:53 localhost fseventsd[31]: event logs in /.fseventsd out of sync with volume. destroying old logs. (11135 9 13111)
Nov 22 14:20:53 localhost fseventsd[31]: log dir: /.fseventsd getting new uuid: 6FD62C2B-E709-4B60-93BF-128439944780
Désolé je viens de m'apercevoir que j'avais muis des heures ou l'imac n'a pas coupé.
