J'AI UN PROBLEME AVEC MES DEUX PRISES FIREWIRE SUR L'ARRIERE DE MON POWER MAC G4 1,2 GHZ.JE RENCONTRAIS DE PLUS EN PLUS DE PROBLEME AVEC MES PERIPHERIQUES.JE NE POUVAIS PLUS BRANCHER DEUX CHOSES EN MEME TEMPS SANS QUE CELA PLANTE OU FIGE OU NE MARCHE PAS, COMME BRANCHER UNE ISIGHT ET UN DD EXT OU UN IPOD ETC...JE NE PEUX UTILISER Q'UNE SEULE PRISE EN MEME TEMPS POUR QUE CELA MARCHE, MAIS MAINTENANT MON DD EXT NE MONTE PLUS SUR LES DEUX PRISES...CELA SE DEGRADE DE PLUS EN PLUS ...LE DD EXT MARCHE TRES BIEN SUR MON IBOOK G4.
FAUT-IL SEULMENT REMPLACER LES DEUX PRISES FIREWIRE ?? CELA CE FAIT-IL ? SANS RISQUE ? ET OU SE PROCURER LES PIECES ?
MERCI D'AVANCE POUR VOTRE SOUTIENS ....
