etudiant69 a dit:
Applications>Utilitaire>Console>Fichier>Ouvrir l'historique système :zen:
Ah oui, tiens...
Voilà ce que j'ai trouvé sur les derniers instants avant le dernier KP :
Jul 17 18:02:51 localhost kernel[0]: hi mem tramps at 0xffe00000
Jul 17 18:02:51 localhost kernel[0]: PAE enabled
Jul 17 18:02:51 localhost kernel[0]: standard timeslicing quantum is 10000 us
Jul 17 18:02:51 localhost kernel[0]: vm_page_bootstrap: 250493 free pages
Jul 17 18:02:51 localhost kernel[0]: mig_table_max_displ = 71
Jul 17 18:02:51 localhost kernel[0]: Enabling XMM register save/restore and SSE/SSE2 opcodes
Jul 17 18:02:51 localhost kernel[0]: 87 prelinked modules
Jul 17 18:02:51 localhost kernel[0]: ACPI CA 20051117 [debug level=0 layer=0]
Jul 17 18:02:51 localhost kernel[0]: AppleACPICPU: ProcessorApicId=0 LocalApicId=0 Enabled
Jul 17 18:02:51 localhost kernel[0]: AppleACPICPU: ProcessorApicId=1 LocalApicId=1 Enabled
Jul 17 18:02:51 localhost kernel[0]: Copyright (c) 1982, 1986, 1989, 1991, 1993
Jul 17 18:02:51 localhost kernel[0]: The Regents of the University of California. All rights reserved.
Jul 17 18:02:51 localhost kernel[0]: using 2572 buffer headers and 2572 cluster IO buffer headers
Jul 17 18:02:51 localhost kernel[0]: IOAPIC: Version 0x20 Vectors 0:23
Jul 17 18:02:51 localhost kernel[0]: Started CPU 01
Jul 17 18:02:51 localhost kernel[0]: ACPI: System State [S0 S3 S4 S5] (S3)
Jul 17 18:02:51 localhost kernel[0]: Security auditing service present
Jul 17 18:02:51 localhost kernel[0]: BSM auditing present
Jul 17 18:02:51 localhost kernel[0]: disabled
Jul 17 18:02:51 localhost kernel[0]: rooting via boot-uuid from /chosen: 91D81682-48ED-43A4-ACBB-6BA2BE22599A
Jul 17 18:02:51 localhost kernel[0]: Waiting on <dict ID="0"><key>IOProviderClass</key><string ID="1">IOResources</string><key>IOResourceMatch</key><string ID="2">boot-uuid-media</string></dict>
Jul 17 18:02:51 localhost kernel[0]: USB caused wake event (EHCI)
Jul 17 18:02:51 localhost kernel[0]: FireWire (OHCI) Lucent ID 5811 PCI now active, GUID 0016cbfffedc9326; max speed s400.
Jul 17 18:02:51 localhost kernel[0]: Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@1F,2/AppleAHCI/AppleAHCIPort@2/IOAHCIDevice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/ST98823AS Media/IOGUIDPartitionScheme/Customer@2
Jul 17 18:02:51 localhost kernel[0]: BSD root: disk0s2, major 14, minor 2
Jul 17 18:02:51 localhost kernel[0]: jnl: replay_journal: from: 1451520 to: 389632 (joffset 0xa701000)
Jul 17 18:02:51 localhost kernel[0]: CSRHIDTransitionDriver:
robe:
Jul 17 18:02:51 localhost kernel[0]: CSRHIDTransitionDriver::start before command
Jul 17 18:02:51 localhost kernel[0]: CSRHIDTransitionDriver::stop
Jul 17 18:02:51 localhost kernel[0]: IOBluetoothHCIController::start Idle Timer Stopped
Jul 17 18:02:51 localhost kernel[0]: HFS: Removed 1 orphaned unlinked files
Jul 17 18:02:51 localhost kernel[0]: Jettisoning kernel linker.
Jul 17 18:02:51 localhost kernel[0]: Resetting IOCatalogue.
Jul 17 18:02:51 localhost kernel[0]: Matching service count = 4
Jul 17 18:02:51 localhost kernel[0]: AppleACPILPC:: waiting for platform plugin
Jul 17 18:02:51 localhost kernel[0]: AppleACPILPC:: register successful
Jul 17 18:02:51 localhost kernel[0]: at_obdev_KUC: at_obdev_registerSyscalls FAILED
Jul 17 18:02:51 localhost kernel[0]: Previous Shutdown Cause: 3
Jul 17 18:02:51 localhost kernel[0]: mac 10.3 phy 6.1 radio 10.2
Jul 17 18:02:51 localhost kernel[0]: IPv6 packet filtering initialized, default to accept, logging disabled
Jul 17 18:02:51 localhost mDNSResponder-108 (Jan 14 2006 02: 59:21)[33]: starting
Jul 17 18:02:51 localhost memberd[40]: memberd starting up
Jul 17 18:02:51 localhost lookupd[44]: lookupd (version 369.5) starting - Mon Jul 17 18:02:51 2006
Jul 17 18:02:52 localhost diskarbitrationd[39]: disk0s2 hfs F548E635-AF0E-32EB-B233-93433A1377A4 Megumi /
Jul 17 18:02:54 localhost DirectoryService[45]: Launched version 2.1 (v353.2)
Jul 17 18:02:55 localhost kernel[0]: yukonosx: Ethernet address 00:16:cb:cb:05:03
Jul 17 18:02:55 localhost launchd: Server 351b in bootstrap 1103 uid 0: "/usr/sbin/lookupd"[44]: exited abnormally: Hangup
Jul 17 18:02:55 localhost kernel[0]: AirPort_Athr5424: Ethernet address 00:16:cb:ba:21:b7
Jul 17 18:02:56 localhost kernel[0]: [HCIController][setupHardware] AFH Is Supported
Jul 17 18:02:56 Megumi configd[37]: setting hostname to "Megumi.local"
Jul 17 18:02:56 Megumi kernel[0]: display: Not usable
Jul 17 18:02:56 Megumi lookupd[68]: lookupd (version 369.5) starting - Mon Jul 17 18:02:56 2006
Jul 17 18:02:56 Megumi /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow: Login Window Application Started
Jul 17 18:02:58 Megumi kernel[0]: AppleYukon - en0 link active, 10-Mbit, half duplex
Jul 17 18:02:58 Megumi loginwindow[70]: Login Window Started Security Agent
Jul 17 18:03:00 Megumi launchd: Server 0 in bootstrap 1103 uid 0: "/usr/sbin/lookupd"[68]: exited abnormally: Hangup
Jul 17 18:03:00 Megumi lookupd[102]: lookupd (version 369.5) starting - Mon Jul 17 18:03:00 2006
Jul 17 18:03:00 Megumi configd[37]: executing /System/Library/SystemConfiguration/Kicker.bundle/Contents/Resources/enable-network
Jul 17 18:03:00 Megumi configd[37]: posting notification com.apple.system.config.network_change
Jul 17 18:03:00 Megumi lookupd[104]: lookupd (version 369.5) starting - Mon Jul 17 18:03:00 2006
Jul 17 18:03:00 Megumi sudo: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/kextload /System/Library/Extensions/speedit.kext
Jul 17 18:03:02 Megumi kernel[0]: SpeedIt Kext is loading!
Jul 17 18:03:02 Megumi kernel[0]: Supported states
Jul 17 18:03:03 Megumi mDNSResponder: Adding browse domain local.
Jul 17 18:03:04 Megumi configd[37]: target=enable-network: disabled
Jul 17 18:03:15 Megumi diskarbitrationd[39]: disk0s3 msdos 00000000-0000-0000-0000-000000000000 WIN XP /Volumes/WIN XP
Tarul a dit:
a mon avis cela doit remonter soit au démarrage de la machine soit a ta dernire tentative de monter un répertoire partagé.
Je seraisq vriament étonné que ce soit camba qui te fasse planté comme ça
M'étonnerait aussi... Pis c'est vrai que je me connecte assez souvent sur ce répertoire partagé sans qu'il se passe quoi que ce soit de bizarre. Je ne sais pas trop...
