Perte d'espace suite à la suppression d'une partition Bootcamp
Un très très grand merci, problème réglé !!
Started APFS operation
Aligning grow delta to 49 999 253 504 bytes and targeting a new physical store size of 499 898 105 856 bytes
Determined the maximum size for the targeted physical store of this APFS Container to be 499 897 077 760 bytes
Resizing APFS Container designated by APFS Container Reference disk1
The specific APFS Physical Store being resized is disk0s2
Verifying storage system
Using live mode
Performing fsck_apfs -n -x -l -S /dev/disk0s2
Checking the space manager
Checking the object map
Checking volume
The volume Macintosh HD was formatted by hfs_convert (945.200.129) and last modified by apfs_kext (945.275.7)
Checking the extent ref tree
Checking the fsroot tree
Checking volume
The volume Preboot was formatted by hfs_convert (945.200.129) and last modified by apfs_kext (945.275.7)
Checking volume
The volume Recovery was formatted by diskmanagementd (945.200.129) and last modified by apfs_kext (945.275.7)
Checking volume
The volume VM was formatted by apfs.util (945.200.129) and last modified by apfs_kext (945.275.7)
Verifying allocated space
warning: Overallocation Detected on Main device: (467+1) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (469+1) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (472+3) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (477+4) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (483+2) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (486+1) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (488+1) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (515+4) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (520+1) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (536+2) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (549+1) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (552+1) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (600+1) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (607+1) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (620+2) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (631+3) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (644+1) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (649+1) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (654+2) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (668+2) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (705+1) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (708+1) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (714+3) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (723+1) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (739+1) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (756+1) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (761+1) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (788+2) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (805+1) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (814+1) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (822+1) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (824+3) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (830+2) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (832+17) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (851+3) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (857+1) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (868+2) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (871+2) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (874+4) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (881+1) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (884+1) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (891+2) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (894+2) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (896+7) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (907+1) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (926+6) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (933+1) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (936+2) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (939+2) bitmap address (1191a03)
warning: Overallocation Detected on Main device: (943+4) bitmap address (1191a03)
too many warnings generated; suppressing subsequent ones
The volume /dev/disk0s2 appears to be OK
Growing APFS Physical Store disk0s2 from 449 898 852 352 to 499 898 105 856 bytes
Modifying partition map
Growing APFS data structures
Finished APFS operation
   0:      GUID_partition_scheme                        *500.1 GB   disk0
   2:                 Apple_APFS Container disk1         499.9 GB   disk0s2
/dev/disk1 (synthesized):
   0:      APFS Container Scheme -                      +499.9 GB   disk1
   1:                APFS Volume Macintosh HD            376.7 GB   disk1s1
   2:                APFS Volume Preboot                 29.3 MB    disk1s2
   3:                APFS Volume Recovery                507.4 MB   disk1s3
   4:                APFS Volume VM                      4.3 GB     disk1s4
Comme beaucoup ici j'ai voulu installer Windows à partir d'un ISO pour ma conjointe sur son mac (et j'y connais rien au mac) mais le process avait l'air simple, pas de bol ce n'est pas le cas a priori.
Résultat : disque dur partitionné avec disparition 1 To /2. (enfin cf. problème de tout le monde avant)
Oh Dieu du Mac macomaniac j'ai besoin de toi ( too much ???).
Voici ce que j'obtiens avec le diskutil :
diskutil list
   2:          Apple_CoreStorage Macintosh HD            510.4 GB   disk0s2
/dev/disk1 (internal, virtual):
   0:                  Apple_HFS Macintosh HD           +510.0 GB   disk1
                                 Logical Volume on disk0s2
                                 3223C64F-3C98-45CC-AA56-5CF929E6B066
                                 Unlocked Encrypted
   0:     FDisk_partition_scheme                        *15.5 GB    disk2
   1:               Windows_NTFS TOSHIBA                 15.5 GB    disk2s1
Je serais tenter d'essayer des trucs dis précédemment mais j'ai peur de faire un bêtise.
Comment récupérer l'intégralité de mon disque ?
Et comment puis-je faire pour installer Windows ?
Merci Beaucoup,
Bonne journée
Tristan
Bonjour Tristan
Passe la commande (copier-coller) :
diskutil coreStorage resizeStack 3223C64F-3C98-45CC-AA56-5CF929E6B066 0b ; diskutil list
  • qui récupère l'espace libre > puis réaffiche la configuration des disques
Poste le retour intégral de la commande (que je sache où ça bloque en cas d'échec).
Merci de ton aide :
diskutil list
                                 Unlocked Encrypted
iMac-de-Axelle:~ axellebertron$ diskutil coreStorage resizeStack 3223C64F-3C98-45CC-AA56-5CF929E6B066 0b ; diskutil list
The Core Storage Logical Volume UUID is 3223C64F-3C98-45CC-AA56-5CF929E6B066
Started CoreStorage operation
Checking prerequisites for resizing Logical-Physical volume stack
Growing Logical-Physical volume stack
Verifying file system
Using live mode
Performing live verification
Checking Journaled HFS Plus volume
Checking extents overflow file
Checking catalog file
Checking multi-linked files
Checking catalog hierarchy
Checking extended attributes file
Checking volume bitmap
Checking volume information
The volume Macintosh HD appears to be OK
File system check exit code is 0
Growing Core Storage Physical Volume from 510 362 574 848 to 999 345 127 424 bytes
Copying booter
Growing disk partition
Growing Core Storage data structures
Resizing Core Storage Physical Volume structures
Resized Core Storage Physical Volume to 999 345 127 424 bytes
Growing Logical Volume
Resizing Core Storage Logical Volume structures
Resized Core Storage Logical Volume to 998 982 549 504 bytes
Growing file system
Finished CoreStorage operation
   2:          Apple_CoreStorage Macintosh HD            999.3 GB   disk0s2
   3:                 Apple_Boot Recovery HD             650.0 MB   disk0s4
   0:                  Apple_HFS Macintosh HD           +999.0 GB   disk1
                                 Unlocked Encrypted
T'es un génie ça m'a l'air bon (crucifixion par Madame éviter +1)
Comme je fais pour installer mon Windows, stp ?
Content pour toi !
- en ce qui concerne l'installation de Windows et le type d'ISO à utiliser : il te faut attendre l'avis de Locke. N'installant ni n'utilisant Windows => je n'ai pas d'expérience sur ces questions.​
Dans quel Mac tu tentes une installation. Que dis /A propos de ce Mac ? Une copie écran de la fenêtre serait la bienvenue.
Il sort d'où ce fichier .iso, car il n'est pas officiel. Le vrai fichier .iso a pour nom exact Win10_1909_French_x64.iso et se télécharge légalement ici... https://www.microsoft.com/fr-fr/software-download/windows10ISO ...ce que mentionne très bien Apple là... https://support.apple.com/fr-fr/HT201468
Bonsoir Locke, merci de ton aide,
Voici pour le mac :
Et voici la nouvelle capture avec la bonne version :
bonne version ; ISO téléchargé puis copié sur la clé TOSHIBA, j'attends tes ordres ...
Encore merci pour ton aide
bonne version ; ISO téléchargé puis copié sur la clé TOSHIBA.
Pourquoi faire, ça ne sert à rien ! Tu n'as pas besoin de clé USB, ni non plus de téléchargé quoi que ce soit.
Tu as un iMac de 2017, que fait Assistant Boot Camp ? Une fois lancé il propose de sélectionner le fichier .iso, puis une taille de partition. Ensuite, il télécharge dans un espace virtuel les pilotes/drivers nécessaires et passe la main à la main à l'installateur de Windows. Sous Windows l'installation est classique, sauf qu'à un moment précis dans l'installation...
...il faudra impérativement sélectionner la partition ayant pour nom BOOTCAMP en majuscules, faire un double-clic sur Formater, accepter la suite et poursuivre l'installation. Une fois que l'installateur à terminé il repasse la main a Assistant Boot Camp qui installe les pilotes/drivers et efface l'espace virtuel dans lequel ils sont contenus. Le premier redémarrage se fera systématiquement et toujours sur la partition Windows. Pour démarrer sous macOS, il te faudra redémarrer en maintenant la touche alt, sélectionner l'icône de Macintosh HD et tu seras dans ta session.
Pour que ce soit macOS le système au démarrage, il te faut aller dans Préférences Système/Disque de démarrage, faire un clic sur le petit cadenas en bas à gauche, entrer ton mot de passe, sélectionner l'icône de Macintosh HD et un clic sur Redémarrer. Tu auras compris que pour avoir accès à la partition Windows, qu'il te faudra démarrer en maintenant la touche alt et sélectionner son icône.
Bonjour Locke
" Pourquoi faire, ça ne sert à rien ! Tu n'as pas besoin de clé USB, ni non plus de téléchargé quoi que ce soit. " Cette partie n'est pas clair pour moi.
J'ai cliqué sur Installé et même chose que précédemment :
Capture d’écran 2019-11-28 à 08.17.38.webpCapture d’écran 2019-11-28 à 08.21.33.webp
Au moins ce coup ci pas de "perte" de disque j'ai de nouveau mes 1 TO
Ma question : Comment arriver jusqu'a l'écran que tu montres ? Quel est le process ?
Merci de ton aide et bonne journée
De nouveau un echec, rien de branché, sauf la sourie (usb bluetooth) car à un moment il s'est mis à rechercher un périphérique sourie donc je l'ai reconnectée 5s le temps qu'il arrete de chercher.
Une autre idée ?
L'iso est sur le bureau il s'agit bien du Win10_1909_French_x64.iso
Echec c'est bien, mais qu'est-ce qui est affiché comme message d'erreur, à quel moment dans la fenêtre d'installation de Windows, est-ce le partitionnement se déroule bien en passant la main d'Assistant Boot Camp vers l'installateur de Windows, etc ?
Par défaut une Magic mouse ne sera pas reconnue, selon la génération de Mac il faut avoir un clavier et une souris filaire. Possédant les deux, à ce jour je n'ai jamais rencontré de problèmes, mais ça Apple ne le précise pas.
Bonjour Locke,
merci de ton retour,
L' ISO Windows à été télécharger aujourd'hui même depuis le site windows, comme indiqué dans la procédure Apple :
(https://help.apple.com/bootcamp/assistant/6.1/#/bcmp173b3bf2)
Voici l'écran de configuration avant le message d'erreur (qui apparait au bout de plusieurs minutes) :
Voici le message d'erreur qui s'affiche :
Le clavier est un clavier Apple et la souris est une une basique hp sans fils avec un dongle USB pour le bluetooth.
Merci pour ton aide
Non, elle ne sera pas reconnue en Bluetooth, il faut impérativement une souris filaire.
Sinon, recommence avec une vraie souris filaire et un taille de 128 Go, car ça démarre bien mais semble bloquer pour l'expansion du fichier .iso en interne.
J'ai trouvé une souris filaire que j'ai branché pour remplacer et j'ai testé :
malheureusement :
Riçen en USB, j'ai aussi testé 256Go sans succès.
D'autres idées ;) ?
